502 Bad Gateway Zigbee2mqtt
If you really expect support on the issues you encounter please format your config properly to make it readable for us. As for yaml indentations matter! How this is done I have already outlined in my previous post.
Additionally at your first post you told us that you try to configure Z2M using a SONOFF Zigbee 3.0 USB Dongle Plus. Your latest post shows the configuration for the ConBee II which you copy/pasted 1:1 from krskrab config above… :roll_eyes:
We need to see your Z2M configuration. Properly formated.
@fleskefjes asked you about the integration Zigbee Home Automation (also referred to as ZHA) which is different to the Zigbee2MQTT add-on. And as fleskefjes has already pointed it out you can not run both of the above against the same coordinator.
Yep already tried
Edit just fixed it just updated home assistant but now encountering
When using lights with alexa
