88.0 complains about keys that are not supported , while they are?
Yes of course. Here is my log
2019-02-21 09:10:30 WARNING (MainThread) [homeassistant.loader] You are using a custom component for custom_updater which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-02-21 09:10:38 WARNING (MainThread) [homeassistant.helpers.config_validation] Your configuration contains extra keys that the platform does not support.
Please remove [icon]. (See /home/homeassistant/.homeassistant/configuration.yaml, line 59).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 29).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 35).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 41).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 47).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 64).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 88).
2019-02-21 09:10:41 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sensor.google_fit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2019-02-21 09:10:41 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change sensor/google_fit.py to google_fit/sensor.py. This will stop working soon.
2019-02-21 09:10:41 WARNING (MainThread) [homeassistant.helpers.config_validation] Your configuration contains extra keys that the platform does not support.
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 113).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 124).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 135).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 146).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 157).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 168).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 179).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 190).
Please remove [initial]. (See /home/homeassistant/.homeassistant/mqtt/sensor.yaml, line 201).
2019-02-21 09:10:42 WARNING (MainThread) [homeassistant.helpers.config_validation] Your configuration contains extra keys that the platform does not support.
Please remove [name]. (See /home/homeassistant/.homeassistant/configuration.yaml, line 162).
2019-02-21 09:10:43 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change sensor/google_fit.py to google_fit/sensor.py. This will stop working soon.
2019-02-21 09:10:46 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
