I am having similar issues with a custom component in the new version of Home assistant.
i tired to seek help through the post by @balloob above but as its a custom component i canât get help from home assistant and the author @daemondazz of the component is not replying.
any help would be much appreciated.
Home Assistant release with the issue:
0.88.1 onward Last working Home Assistant release (if known):
0.87
Description of problem:
As of 0.88.1 a warning is shown:
Your configuration contains extra keys that the platform does not support (but were silently accepted before 0.88). Please find and remove the following.This will become a breaking change.
[name], [host], [password]. (See /config/configuration.yaml, line 70).
[name], [host], [password]. (See /config/configuration.yaml, line 74).
[name], [host], [password]. (See /config/configuration.yaml, line 78).
[name], [host], [password]. (See /config/configuration.yaml, line 82).
Iâm sorry for being the bearer of bad news. Iâve used this analogy before. Going to balloob for a custom component is like talking with apple about why the google maps app doesnât work. It seems as if the developer abandoned this component. So youâll need to fix it, get the dev to fix it, or get someone else to make a new repo with the fixes. Good luck.
I totally get your point about going to balloob and only did this as it was suggested above to report it.
Iâm not very experienced in coding but am more then willing to try an fix it myself, just no idea how to.
that why Iâm posting here, Iâm hoping someone with more experience and knowledge may be able to help guide me in the right direction. It has been suggested elsewhere that the ânameâ âhostâ and âpasswordâ may not be in the âfully_kioskâ configuration schema but have no idea what this is or how to add them.
Icon is not a valid field. Take a look at the page you linked. Do you see âiconâ listed? Itâs not even a valid option for the base sensor class. It should be configured in the customize section.
thanks, both fields arenât valid apparently. moved them to the customize.
have three more though in my report, that are not found in the sensor platforms anywhere I can find manually⌠Would there be an nifty script command to find the icon and unit_of_measurement fields in the config files?
this isnât much help without further locating the issue:
[Info] Installed homeassistant==0.90.2, check config now
[Error] Wrong config found!
Testing configuration at /tmp/config
WARNING:homeassistant.helpers.config_validation:Your configuration contains extra keys that the platform does not support.
Please remove [icon].
WARNING:homeassistant.components.http:Configuring api_password via the http component has been deprecated. Use the legacy api password auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#legacy-api-password
WARNING:homeassistant.components.http:Configuring trusted_networks via the http component has been deprecated. Use the trusted networks auth provider instead. For instructions, see https://www.home-assistant.io/docs/authentication/providers/#trusted-networks
Please remove [icon], [unit_of_measurement].
Failed config
General Errors:
- Platform not found: binary_sensor.hue
- Platform not found: sensor.hue
- Platform not found: device_tracker.hue
sorry, I meant the top 3 icon warnings. The others are self-explanatoryâŚWould need and love some extra help from HA to locate these
the bottom warning about the [icon] and [unit_of_measurement] was the erroneous statistics sensor which I now repaired and reran the conf checker on successfully:
Failed config
General Errors:
Successful config (partial)
Itâs not a bug. They revamped the system so that unused fields are completely ignored. All icon handling is done through customize. Just look in the docs for that, Icon is not listed as an option, only name and entities.
sure, appreciate that, but since the light group is what it is, a group, it is rather counter intuitive to not allow for the icon: to be a valid option. filed an issue to see what gives:
