Try it without the single quotes around your API key.
Thank you works perfectly now! I kept trying different things and “restarting” but only after I shut down and turned on again that it fully worked.
Thank you for your help and patience.
No worries. Enjoy!
- alias: Oprire AC
platform: template
value_template: "{{ states('sensor.time') == (state_attr('input_datetime.oprire_ac', 'timestamp') | int | timestamp_custom('%H:%M', False)) }}"
- service: climate.turn_off
entity_id: climate.gree_ac
- alias: Pornire AC
platform: template
value_template: "{{ states('sensor.time') == (state_attr('input_datetime.pornire_ac', 'timestamp') | int | timestamp_custom('%H:%M', False)) }}"
- service: climate.turn_on
- service: climate.set_hvac_mode
hvac_mode: cool
- service: climate.set_temperature
temperature: 24
- service: climate.set_swing_mode
entity_id: climate.gree.ac
swing: Fixed in the middle-low possition
- service: climate.set_fan_mode
fan_mode: medium
I see that you are using a Gree A/C unit. I am curious as to what type of HA integration you are using to control it? I have a Lennox mini-split which I believe is the same or similar to the Gree.
thanks
The plugin can be found in HACS
to connect HVAC I had to get the encryption key, the mac address and set a fixed IP, the encryption key I obtained with the help of a routed phone in which I installed an application, (you can find details on the forums)
Thanks for your reply but unfortunately my unit only supports IR and not Wi-Fi.
Actually, I am currently using a Broadlink Mini 3 to control it but it is a bit of a hassle as I have to program the IR codes for every possible combination of mode/fan/temp.
Thanks for your replies.
Thanks for sharing your codes. Used it and adjust to my environment and conditions. Since I don’t have central air but split system units. I added the season integration and add condition to only turn on the AC during summer.
Thanks a lot for your example! It helped me a lot to get it started (with changes regarding the Canadian climate… Lol). I wanted to know if you knew a way to send the parameters below in one shot? (my Fujitsu unit bip for every command receive…). I see on the API documentation of the Sensibo they use acStates and some json but I don’t know how to send that request.
Hi @PierreCa… sorry, I just put up with the multiple beeps on my system. One option (if you don’t really change the temp/fan/swing setting much) would be to just use service: climate.turn_on
which would turn it on with whatever setting were used last time.
Hi @AussieByrd
Would you be able to post some more info as to where to put the snippets you had in the first post?
I am very new to this and have not learned the file structure and don’t know where to put stuff.
Hi @TomW1605, if you’re just starting out just probably don’t have a terribly complicated setup yet, so just put the sensors in your configuration.yaml
file (temperature sensors, threshold sensors) and automations in your automations.yaml
file.
I actually have a pretty large setup, so I use packages
to separate out aspects of my config. All of my A/C config are in a climate_control.yaml
file in a packages
folder (the folder sits in the same folder as the configuration.yaml
file. If you’re interested in using this approach, you just need to add the following to your configuration.yaml
file:
packages: !include_dir_named packages
Just bear in mind that if using packages
you need to include automation:
before the - alias:
lines with adjusted indents) in my snippets, like this:
automation:
- alias: downstairs_ac_on_after_645pm
initial_state: true
thanks @AussieByrd
at the moment i am mostly interested in (for now) is getting the sensors working and because i had no sensors in my config file i was missing the line above - platform: template
but i found that so all good.
also thanks for the stuff about automation i will almost certainly set that up soon
My easy automation setup:
automations.yaml
## Climate On Every Day If it is colder than the set value ##
- id: '1640257485912'
alias: Clima On 08:00-23:00 - 19.7 C
description: Clima On 08:00-23:00 - 19.7 C
- type: temperature
platform: device
device_id: ab68b2ca8d58eb61fb0299572713f840
entity_id: sensor.living_room_sensor_temperature ## You Sensor ##
domain: sensor
below: 19.7
- platform: time
at: 08:10
- condition: time
after: 08:00
before: '23:00'
weekday:
- mon
- tue
- wed
- thu
- fri
- sat
- sun
entity_id: climate.1ebaf356 # You A/C #
temperature: 29
hvac_mode: heat
fan_mode: low
## Climate Off Climate shuts off when the correct temperature is reached. ##
alias: Clima Off 09:00 - 19.5 C
description: Clima Off 09:00 - 19.5 C
- type: temperature
platform: device
domain: sensor
above: 20.3
- platform: time
at: '09:00'
condition: []
Just wanted to ask here before I start digging deeper myself:-)
Usecase:
- Air - Air heat pump (cooling/heating) placed in my hallway connected to a Sensibo Air integrated into Home assistant.
- Temperature sensor in the kitchen to be used as thermostat “actual temp/process value”
- Use for example Target temperature adjustment depending on second temperature sensor to calculate the offset of the kitchen “actual temperature” compared to the heat pump temp sensor.
- Setting the heat pump Setpoint value to the calculated one using the offset above
- Using a standard Lovelayce thermostat card controlling the thermostat BUT using the calculated values in it (for WAF - end user shouldn’t see the magic behind)
Question: The use case seems to be one that other ppl would have faced before so asking if someone has done this?
I have used HA for a very long time but never had to really go down the drain of template sensors, advanced scripting etc. How can this be done in the “right way” according to the overall HA functionality? It’s the last bullet that bothers me, ie the Lovelace end user UI:-)
Note: The Sensibo air has this slave sensor, but it can only be used to trigger actions, not being used as described in the use case above.
Hi Fredric
There are probably a few ways you could approach this - the best option may come down to how big and how consistent the offset is between your ‘sensor’ temperature and your ‘system’ (i.e. internal heat-pump sensor) temperature is.
If the offset is not large, and you just want the heat-pump to keep running until the ‘sensor’ temperature is in a comfortable range, you could just use my setup (the top few posts here), using the ‘sensor’ temperature as the input (entity_id
) for the binary_sensory
. This is what I actually do.
If the offset in too large for this, but is consistent (e.g. the difference in always 2 degrees), you could just set the heat-pump to target the offset comfort level (i.e. if you are comfortable at ‘sensor’ temp of 21 degrees, but the ‘system’ temp is always 2 degrees higher, just set it to 23 degrees.
If the offset is large and inconsistent, you’ll probably need to set up a new template sensor that calculates the offset in real time (e.g. ‘sensor’ temp - ‘system’ temp), and then use a data template that calculates your adjusted target temperature using both your ‘sensor’ comfort level temperature and the current offset value from your template sensor.
Good luck!
Thanks for your answer.
Well, it is not constant and might differ significantly over time. The thing I am trying to simulate is for the ac/heat pump to use an external sensor as the actual value.
The offset will vary depending on mode as well, going from positive to negative depending on heat or cold operations.
I think the template linked above (simple offset calculation) is a start but maybe I will have to write my own custom climate to be able to use a standard thermostat card for the UI
Hi again, I think I found what I was looking for (if anyone else has the same question as me).
There was an updated variant of the blueprint linked above stored here:
This Blueprint uses a separate thermostat (a dummy one in my case) as set value input, calculates the difference between a temp sensor and the requested set value, and then set another climate entity set value using the calculated offset.
