You can also add the line
console.log(today.toLocaleDateString(), today.toLocaleDateString("sv-SE"))
before that line to get the two different date formats logged to the console.
It works.
Thank you very much!
It is an awesome widget!!!
Great!
Iāll update the file on github.
After installing this widget, I had the same issue as @daekka, and got a 401 error. However, I had to fix it by putting https://xxx.duckdns.org:5050 in cors_allowed_origins.
So, now the graph widget is loaded in my dashboard, however, the graph is empty.
I think Iāve got everything correct in my *.dash and variables.yaml files, so I donāt understand why the graph doesnāt show any dataā¦
Du you have the history component configured in configuration.yaml?
Yes I have. Within HA I can see the history data of all entities.
Can you post the widget definition?
This is what I currently have set in my *.dash file:
graph:
widget_type: hagraph
entities:
- sensor.temp_sensor_livingroom_temperature # The entity_id to be plotted.
units: "Ā°C" # The unit_of_measurement for your sensors/entities
titles:
- Living room temperature # Title of the trace.
time: 1d # Time interval to plot. you can combine w, d, h and m as 2w1d3h20m (This would be 2 weeks, 1 day, 3 hours and 20 minutes)
title: Temperatures # Widget title
value_in_legend: 1
fill: "tozeroy" # options are "none" | "tozeroy" | "tozerox" | "tonexty" | "tonextx" | "toself"
colorIndex: 0 # A number between 0 and 11. 12 colors for the traces are predefined and the colorIndex defines
# which is used for the first trace. If more than 12 traces/entities are specified, the colors are rotated.
Ok, looks fine. I have uploaded a new basegraph.js file to github with some additional logging. If you download it and add
log: 1
to your widget definition, it will log both the request sent to HA and the result so we can see whats wrong.
Ok, did that. I assume you want to see what my browser console says?
Object { message: "Invalid datetime" }
Ok, what is your locale, i.e. how do you write a date? 2019-01-01 or 01/01/2019 etc?
https://xxx.duckdns.org/api/history/period/2019-03-23T11:53:32 AM?authSig=xxx
I see that thereās space between 11:53:32 and AM. Could that be the issue?
Yes, the AM and space shouldāt be there at all. Iāll have a look later but itās definetely just a locale issue and should be easy to fix.
I made a small change in basehagraph.js, just to test:
return today.toLocaleDateString(āsv-SEā) + āTā + today.toLocaleTimeString(āsv-SEā)
Now the browser console says:
https://xxx.duckdns.org/api/history/period/2019-03-23T13:37:02?authSig=xxx
But it also says:
ālength: 0
ā__proto__: Array []
New value for sensor.cpu_temperature: 52.6 [application.js:2955:4]
Slight improvement then. Can you post the part at the end of the url? There should be
&filter_entity_id=
at the end of the url and I like to see that part. The authSig part is also not very secret since it expires after 20 seconds. Please also try to paste the url in a browser and see what you get.
Thanks, I forgot to add the locale for the time string.
https://xxx.duckdns.org/api/history/period/2019-03-23T14:12:34?authSig=eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI1ZjkwMDQ2NzU4Yzc0Zjc4YTI0NDJiZGYzYmRiNDNmNSIsInBhdGgiOiIvYXBpL2hpc3RvcnkvcGVyaW9kLzIwMTktMDMtMjNUMTQ6MTI6MzQiLCJpYXQiOjE1NTM2MDk1NTMsImV4cCI6MTU1MzYwOTU3M30.KNCzpRlxtxttAUTERR9GZp1fbfe7OlEWQ41jMvAeA0Q&filter_entity_id=sensor.cpu_temperature
Iām at work now, so if I paste the url in a browser, I get a 401 error.
Just a thought: Deakkaās url has a port specified, :8123
, in it and your url do not include any port, i.e.
https://xxx.duckdns.org:8123/api/history/period/18/3/2019T17:45:54?
I tried adding the port 8123, but nothing changesā¦
Hello Tomas,
thanks for your widget!
Unfortunately for me its not working.
The Dashboard site ist just blank, without any graph. The Java-Console gives the following Infos:
Fehler beim Verarbeiten des Wertes fĆ¼r '-webkit-text-size-adjust'. Deklaration ignoriert. extheating_application.css:4:29
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. extheating_application.css:37:22
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. extheating_application.css:125:22
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. extheating_application.css:136:22
Unbekannte Eigenschaft '-moz-border-radius'. Deklaration ignoriert. extheating_application.css:199:21
Unbekannte Eigenschaft '-moz-osx-font-smoothing'. Deklaration ignoriert. all.css:10:27
Unbekannte Eigenschaft '-moz-osx-font-smoothing'. Deklaration ignoriert. materialdesignicons.min.css:1:682
'none', URL oder Filterfunktion erwartet, aber 'FlipH' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. materialdesignicons.min.css:1:199277
'none', URL oder Filterfunktion erwartet, aber 'FlipV' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. materialdesignicons.min.css:1:199378
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:48:9
'none', URL oder Filterfunktion erwartet, aber 'alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:667:10
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:1044:9
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:1051:9
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:1055:9
'none', URL oder Filterfunktion erwartet, aber 'Alpha(' gefunden. Fehler beim Verarbeiten des Wertes fĆ¼r 'filter'. Deklaration ignoriert. jquery-ui.css:1307:10
Fehler beim Verarbeiten des Wertes fĆ¼r 'shape-rendering'. Deklaration ignoriert. rickshaw.min.css:1:3749
Source-Map-Fehler: Error: request failed with status 404
Ressourcen-Adresse: http://192.168.0.33:5050/css/materialdesignicons.min.css
Source-Map-Adresse: materialdesignicons.css.map
My appdaemon.yaml looks like (Appdaemon 4.0):
logs:
error_log:
filename: errors.log
log_generations: 1
main_log:
filename: appdaemon.log
log_generations: 1
appdaemon:
disable_apps: 1
total_threads: 10
app_dir: apps
latitude: 51.6747074
longitude: 8.347194
elevation: 81
time_zone: Europe/Berlin
api_key: XXXXXXXX
plugins:
HASS:
type: hass
ha_url: http://192.168.0.33:8123
token: eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJjNzZkN2JjMzEzNmI0ZDg0YjBmNDk4M2U3YjU5NDEzZCIsImlhdCI6MTYwNDU5OTAxMSwiZXhwIjoxOTE5OTU5MDExfQ.dGVahzJMqaMGnETDLBgS-6K9G_kzSwAaAWL2_Jkqs2g
hadashboard:
dash_url: http://192.168.0.33:5050
dash_compile_on_start: 1
dash_force_compile: 1
http:
Important parts of the configuration.yaml:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
history:
use_include_order: true
include:
entities:
- sun.sun
- sensor.current_temperature_wohnzimmer
- sensor.current_temperature_schlafzimmer
- sensor.current_temperature_bad_oben
- sensor.current_temperature_bad_unten
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
http:
base_url: 192.168.0.33:8123
cors_allowed_origins:
- http://192.168.0.33:5050
- http://192.168.0.33:8123
homeassistant:
auth_providers:
- type: legacy_api_password
api_password: testpw
- type: homeassistant
- type: trusted_networks
trusted_networks:
- 192.168.0.0/24
Dashboard-Config:
title: extendedheating
widget_dimensions: [170, 170]
widget_margins: [1, 1]
columns: 20
mvp:
entities:
units: "Ā°C"
titles:
- "Bad oben"
time: 2h
title: "Temperaturen Heizung"
value_in_legend: 1
fill: "none"
log: 1
layout:
- mvp(7x1)
Can you please have a look and give me some tips to get it work?
Thanks in advance!
Christian
