A sensor to list unavailable devices
So, in case anyone else wants it, here is the final full code – tested, tidied up and annotated.
Thanks to all of you for your help and to others on the forum and elsewhere on the internet who made contributions to this subject.
## Unavailable Entities Sensor
## 05-Feb-2024 | Andy Symons | created
## Credit: based loosely on https://github.com/jazzyisj/unavailable-entities-sensor/blob/main/README.md
## The sensor provides lists related to real devices, not internal entities, helpers, automations etc.,
## Entities with state 'unknown' are not counted, because it is possible for a device to have a sub-entity that is
##    unknown while the device itself is available.
## The STATE simply gives the count of unavailable entities.
## The long results have to be attributes because the state cannot contain more than 255 characters:
##   ATTRIBUTE 'entity_id_list' contains a list of unavailable entities using their entity ids, which may or may not have been set by the user.
##   ATTRIBUTE 'entity_name_list' contains a list of unavailable entities using their friendly names as assigned by the user.
##   ATTRIBUTE 'device_name_list contains a list of the devices that are unavailable, which is to say having one or more entities that are unavailable,
##      using their friendly names as assigned by the user.
template:
  - sensor:
      name: "Unavailable Entities"
      unique_id: unavailable_entities
      icon: "{{ iif(states(this.entity_id)|int(-1) > 0,'mdi:alert-circle','mdi:check-circle') }}"
      state_class: measurement
      unit_of_measurement: entities
      # The entity state is the count of unavailable entites
      state: >
        {{ states
        | selectattr('domain','in',['binary_sensor', 'climate', 'light', 'sensor', 'switch'])
        | selectattr('state', 'in', ['unavailable'])
        | map(attribute='entity_id')
        | unique
        | list
        | count
      # The long results have to be attributes because the state cannot contain more than 255 characters.
      attributes:
        ## A list of unavailable entities using their entity ids (which mnay or may not have been set by the user).
        entity_id_list: >-
          {{ states
          | reject('match', 'None')
          | list
          | sort
          | join('\n')
        ## A list of unavailable entities using their friendly names as assigned by the user.
        entity_name_list: >-
          {{ states
          | map('state_attr', 'friendly_name')
          | list
          | sort
          | join('\n')
        ## A list of the devices that are unavailable, using their friendly names as assigned by the user.
        device_name_list: >-
          {{ states
          | map('device_attr', 'name_by_user')
          | unique
          | list
          | sort
          | join('\n')
# HOW THE ATTRIBUTE TEMPLATES WORK
#  -- Taking device_name_list as an example...
# {{ states                                                        -- all the states (entities) in the system
#    | selectattr('domain','in',['binary_sensor', 'climate', etc.  -- filter only the entities for real devices
#    | selectattr('state', 'in', ['unavailable'])                  -- filter only entities that are unavailable
#    | map(attribute='entity_id')                                  -- get the entity id from the record
#    | map('device_attr', 'name_by_user')                          -- map the entity id onto the device name
#    | reject('match', 'None')                                     -- take out names 'None' (meaning there is no name, so not a device)
#    | unique                                                      -- take out duplicates (devices usually have several entities)
#    | list                                                        -- make into a list (in the template sense)
#    | sort                                                        -- put them in alphabetical order
#    | join('\n')                                                  -- take out extraneous punctuation for a tidy output
This web page is colouring the last few lines incorrectly; it’s just comment and will be fine when you paste it into a YAML file.
If you use this sensor code, please …
