i’ m not shure what you want to achieve. On each state change of your sensor the new value will be displayed, that is by design. If you don’t want to see each change you can do a time_pattern trigger like this:
alias: send states to ehmtx by time
- platform: time_pattern
# You can also match on interval. This will match every 5 minutes
minutes: "/5"
condition: []
- service: esphome.ehmtx8266_screen_t # must correspond to your device name
icon_name: 'power' # again your icon
duration: 1 # in minutes
text: >-
{{ states.sensor.energia_assorbita.state}} {{states.sensor.energia_assorbita.state.attributes.unit_of_measurement}}
This will read the sensor every five minutes and display its value for one minute.
thank you very much you really help me a lot, another question, I’m inserting the icons as you did, but I didn’t understand how to make them animate? the file is a * .gif but on the screen it is reproduced static, I would like to understand if I’m wrong? keep in mind that I get the icons from Lametric. Thanks in advance
I have a question. I own a flexible RGB 8x32 panel. What is the best way to fasten it to a solid board so that it does not deform? What do you use? Is it enough to fasten it with double-sided adhesive tape? Will the temperature not matter during this installation? Thank you.
Downloaded gif 240x240 does not work after compilation.
On PC win10 animation works, but after compiling esp has only one image test = new display::Animation(uint8_t_6, 8, 8, 1, display::IMAGE_TYPE_RGB24);
I used your 8x8 and it works well on RPI4 8Gb after compilation rain = new display::Animation(uint8_t_4, 8, 8, 5, display::IMAGE_TYPE_RGB24);
Can gif be scaled down to 8x8 on PC so it doesn’t lose animation?
all major image manipulation software is able to scale gifs without loosing the animation, like gimp.
I tried paint on my windows 10 PC, with this tool you lose the animation as in your test. So, use gimp.
I have one more question: the bottom row of LEDs shows the days of the week. Our first day of the week is Monday, but the indicator shows Sunday. Is it possible to modify it so that the first three LEDs on the left are activated as the first day of the week, Monday?
Thanks for the great component, it works perfectly
I wanted to use automatic brightness control with the BH1750 sensor, but an error occurs during compilation. The sensor works well on its own. Where am I making mistake?
- platform: bh1750
name: "Jas led 8x32"
address: 0x23
update_interval: 5s
on_value:
then:
lambda: |-
if (x > 200) then
id(rgb8x32)->set_brightness(50);
} else {
id(rgb8x32)->set_brightness(250);
Compiling /data/led-8x32/.pioenvs/led-8x32/src/main.cpp.o
/config/esphome/led-8x32.yaml: In lambda function:
/config/esphome/led-8x32.yaml:261:20: error: 'then' was not declared in this scope
261 | if (x > 200) then
*** [/data/led-8x32/.pioenvs/led-8x32/src/main.cpp.o] Error 1
Each with it’s own esp? I was thinking hooking like two of this 8x32 matrixes on one esp in series to get for example a 16x32 or a 8x64 matrix display?
Each display has 256 pixels so not sure what the limit (probably memory) is for a esp82xx or a esp32
Yes,
but it should be possible.
But there are realy some limitiations in the hardware. E.G. the fontscrolling. Esphome has no method to limit the text to the needed parts so it uses a lot of memory for the text in RAM. Other parts like the icons will also consume a lot of memory 8x8 vs. 16x16 icons == 4 times RAM and flash…
Perhaps i will give it a try but only the 8x64 style…
Since my pull requests to the esphome core are approved now, some important parts of my esphome-component will be officially available with the upcoming esphome release 2022.5!
Then i am able to clean up a little bit and release the version 1.0 of my component. Then my rgb565-branch will become “main” which makes it much easier to use it.
thanx to @jesserockz
