It would be helpful to be able to (re)calculate the history for a helper sensor; if you have changed the configuration or added an entirely new configuration, you must wait for new data to be recorded before you can verify if the new configuration is correct.
Perhaps a feature to preview what the new configuration would have calculated based on historical data? That still would leave out sensors that cannot be added through the UI and must be manually configured.
Perhaps calculate the values for the last configurable amount of time when there is a new/modified helper sensor definition, and explicitly flag it as test data?
Hmm. A button you can click to request that historical data be (re)evaluated using the current sensor definition, even if you can’t configure the sensor in the UI?
A configuration help request that expresses surprise that this is not already a feature.
