Hi, how can I run queries on my MariaDB database from inside a Python script if I cannot import python libraries in HASS?
Impossible. Checkout the SQL component
I’m using the new SQL component, but it only allows me to get 1 value. I would need more complex queries to the DB.
What’s the query? I was assuming you were talking about the python scripts component in my earlier answers. Otherwise you can import sqlalchemy
That’s right, I want to run queries from the python scripts component, but I cannot import anything in python scripts (in HASS).
I want to get daily statistics from my energy counter so later I can work the data. For example gather all the data at the end of the day and send it somewhere.
Example Query:
select
DATE(created) Date
ROUND(SUM(state)/1000, 1) Consumption
from states
where entity_id = ‘sensor.energy_counter’
group by Date
order by Date
You have a couple of options:
- Write a normal python script (not using the python_scripts component of course) then use a command line sensor
- Use the API - but some processing of the returned data would be required, perhaps a python_script could be used for the processing
- Try this suggestion and just use a restful_sensor
For processing data checkout my data-detective, which you could import to do some processing.
Please post your progress
Cheers
Thanks robmarkcole! I went for the first option and it worked!
My configuration.yaml:
shell_command:
script1: "python3 /config/python_scripts/script1.py"
My /config/python_scripts/script1.py:
import MySQLdb
logfile = open("script1.log","w")
database = MySQLdb.connect("core-mariadb","MY_USER","MY_PASSWORD","homeassistant")
cursor = database.cursor()
query = """select
DATE(created) `Day`,
ROUND(SUM(state)/1000, 1) `Consumption`
from states
where entity_id = 'sensor.energy_counter'
group by `Day`
order by `Day`"""
cursor.execute(query)
for row in cursor.fetchall():
day = row[0]
consumption = row[1]
logfile.write("%s -> %s\n" % (day, consumption))
database.close()
logfile.close()
Cheers!
Hello, you can use this script execution to show in a card template?
