Try keeping the ACM-2 plugged in at the same time. I wonder since your unit seemingly only uses RS485 for the WiFi module, it asks/polls for status updates rather than being fed them. Maybe also push buttons on the wall controller (and or WiFi controller when plugged in too) to see updates.
Can also try swapping around the A/B leads incase its the wrong way around, but I would to expect at least gibberish showing up in the logs. When Iâve hooked up things incorrectly in the past I see random incorrect data come through. Be it the RS485 module not being powered correctly or an A/B lead not connected correctly.
Failing all that the next step is to stick an Oscilloscope or Logic analyser on the RO side of the RS485 module. Or run the ESP32 direct with Arduino dumping the contents coming in from the the RS485 to serial out. Or a USB to RS485 adaptor and plug into a computer direct to the RS485 BUS to print out any contents.
Also what model is your indoor/outdoor units?
Iâll try it out and see how it goes.
The model of the indoor unit is SRG171E-0100
@a.barkho21 Can I please ask you to repost the NodeRed flow (or let me know if it is just me that cannot access the pastebin location), the link seems to be down. thanks in advance
I changed the link, try it now, let me know if it doesnt work.
@a.barkho21 Please disregard my earlier post about not being able to resolve the link, i just discovered my home internet provider is blocking the site for some reason⌠I have copied the NodeRed code using another connection⌠Thanks again.
Could I ask that you also post your card yaml if you get a chance, thanksâŚ
Controls Card
type: vertical-stack
cards:
- square: false
type: grid
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_power_switch
show_state: true
- type: vertical-stack
cards:
- type: entity
entity: sensor.ac_compressor
icon: mdi:air-conditioner
- graph: none
type: sensor
entity: sensor.inside_temp_ac
detail: 1
cards:
- type: entity
entity: input_select.aircon_mode
icon: mdi:auto-mode
- type: entity
entity: input_select.aircon_fan_speed
cards:
- show_name: false
show_icon: true
type: button
tap_action:
action: call-service
service: input_select.select_option
entity_id:
- input_select.aircon_fan_speed
option: Low
icon: mdi:fan-speed-1
hold_action:
action: none
icon_height: 40px
- show_name: false
show_icon: true
type: button
tap_action:
entity_id:
option: Med
icon: mdi:fan-speed-2
hold_action:
action: none
icon_height: 40px
- show_name: false
show_icon: true
type: button
tap_action:
entity_id:
option: High
icon: mdi:fan-speed-3
hold_action:
action: none
icon_height: 40px
- graph: none
type: sensor
entity: input_number.aircon_setpoint
detail: 1
icon: mdi:thermometer-check
cards:
- show_name: true
show_icon: true
type: button
tap_action:
service: input_number.increment
entity_id: input_number.aircon_setpoint
data: {}
icon: mdi:thermometer-plus
- show_name: true
show_icon: true
type: button
tap_action:
service: input_number.decrement
data: {}
icon: mdi:thermometer-minus
columns: 3
Zone Card
cards:
- square: true
type: grid
cards:
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_1
icon: mdi:human-male-female-child
show_state: true
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_2
icon: mdi:white-balance-sunny
show_state: true
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_3
icon: mdi:garage-variant
show_state: true
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_4
icon: mdi:bookshelf
name: Study and Pantry
show_state: true
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_5
icon: mdi:bed-king-outline
name: Mumâ & âDads ââRoom
show_state: true
- show_name: true
show_icon: true
type: button
tap_action:
action: toggle
entity: input_boolean.aircon_zone_6
icon: mdi:bed-single-outline
name: Andrew & Ashys Room
show_state: true
I was recently looking at doing this, great work. I have an ESP Classic ducted system I think. I looked at the BMS card and the wifi, but was just outside the budget for the convenience factor. I have ESP32s and the RS485 module youâre using, as well as the one with the automatic flow logic and polyfuses/clamping diodes. Is there any reason you used the basic module? Can the other module work with your code? Happy to provide you with some logs when I hook it all up.
Yeah the other module should work too, havenât tested recently. Might need to set a spare pin for write control in configuration just to let the code work. I have the more complex modules too. But I also broke a few of them when they were connected to the AC when starting out, so I donât trust them. But I can make some changes and test so that they will work out of the box with esphome configuration.
Thank you for all your help. I have this up and running using your API method.
thanks again
Can anyone share their complete code for the modbus version. I Have installed the card in the out door unit and connected it via a waveshare rs485 > ethernet converter.
Ive used Darrens code above however am getting a number of errors
Logger: homeassistant.config
Source: config.py:1293
First occurred: 3:08:29 PM (1 occurrences)
Last logged: 3:08:29 PM
âââInvalid config for âmodbusâ at configuration.yaml, line 142: âautoâ is an invalid option for âmodbusâ, check: modbus->0->climates->0->hvac_mode_register->values->auto, please check the docs at Modbus - Home Assistant Invalid config for âmodbusâ at configuration.yaml, line 143: âcoolâ is an invalid option for âmodbusâ, check: modbus->0->climates->0->hvac_mode_register->values->cool, please check the docs at Modbus - Home Assistant Invalid config for âmodbusâ at configuration.yaml, line 144: âheatâ is an invalid option for âmodbusâ, check: modbus->0->climates->0->hvac_mode_register->values->heat, please check the docs at Modbus - Home Assistant Invalid config for âmodbusâ at configuration.yaml, line 145: âfan_onlyâ is an invalid option for âmodbusâ, check: modbus->0->climates->0->hvac_mode_register->values->fan_only, please check the docs at Modbus - Home Assistantâââ
Logger: homeassistant.setup
Source: setup.py:221
Setup failed for âmodbusâ: Invalid config.
I have made a number of corrections to the code Modbus starts with no errors now, yet to be tested.
Still interested in anyones completed code for the Actron Modbus version
Cheers,
Edit: I have everything working, code is below for anyones benefit, Im using the waveshare rs485 to ethernet converter and the ICUNO-MOD card in a Actron Classic 2.
Setting on BMS card _Serial address 1, Data parity None, Baud rate 9600
Basic BMS control setting on outdoor unit, Menu> Set> Ctrs> 3 (wall control still works in this mode)
for some reason my indoor temperature was displaying as 3000c when first configure to read 851 so i changed it to 6001 which is the wall control temperature.
modbus:
- type: tcp
host: 192.168.4.254
port: 8899
climates:
- name: Actron classic
address: 6001
precision: 1
scale: 0.1
target_temp_register: 102
max_temp: 30
min_temp: 16
temp_step: 0.5
temperature_unit: C
hvac_onoff_register: 1
hvac_mode_register:
address: 101
values:
state_off: 0
state_auto: 3
state_cool: 2
state_heat: 1
state_fan_only: 4
slave: 1
switches:
- name: Bedrooms zone
slave: 1
address: 5001
verify:
address: 5001
input_type: holding
- name: Living room zone
slave: 1
address: 5002
verify:
address: 5002
input_type: holding
- name: Comms and Laundry zone
slave: 1
address: 5003
verify:
address: 5003
input_type: holding
sensors:
- name: Actron indoor temperature
unit_of_measurement: °C
precision: 1
scale: 0.1
slave: 1
address: 6001
- name: Actron Outside
precision: 1
scale: 0.1
slave: 1
address: 852
- name: Actron Fan Mode
input_type: holding
address: 4
slave: 1
scale: 1
min_value: 0
max_value: 4
- name: Actron Fan Controls
input_type: holding
address: 105
slave: 1
scale: 1
min_value: 0
max_value: 1
- name: Aircon Compressor 1 Demand
unit_of_measurement: "%"
scale: 0.1
slave: 1
address: 1104
- name: Aircon Compressor 1 Speed
scale: 0.1
slave: 1
address: 1105
- name: Aircon Outdoor Coil 1 Temperature
scale: 0.1
slave: 1
address: 1201
- name: Aircon Indoor Coil Temperature
scale: 0.1
slave: 1
address: 1301
- name: Aircon Indoor Coil 1 Fan 1 Speed Percentage
scale: 0.1
slave: 1
address: 1311
- name: Aircon Indoor Coil 1 Fan 1 Speed RPM
unit_of_measurement: RPM
slave: 1
address: 1312
binary_sensors:
- name: Aircon Compressor 1 Running Status
slave: 1
address: 1101
input_type: holding
- name: Aircon Compressor 1 Heating
slave: 1
address: 1102
input_type: holding
- name: Aircon Compressor 1 Unit Defrosting
slave: 1
address: 1107
input_type: holding
Iâm interested to hear if you got this working?
@awulf - great work and thank you for sharing your work on the Actron485 control.
Iâve been trying to implement this solution and canât get it working and seem to have an error similar to a.barkho21.
[22:16:27][C][actron485.climate:226]: Actron485 Status:
[22:16:27][C][actron485.climate:227]: Receiving Data: NO
- My ESP32 and RS485 module are wired up to the Air Conditioner
- The ESP32 has been configured and integrated with home assistant - this appears to be OK
When I try and control the Air Conditioner from home assistant, the controls and status are not working. Iâve turned the AC on from the wall panel, the AC can be controlled as normal from the wall panel but no inidication or control works in home assistant.
I would appreciate your assistance.
ESPhome code
esphome:
friendly_name: Actron AC
platformio_options:
lib_extra_dirs: /config/
libraries:
Actron485
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "[redacted]"
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "[redacted]"
password: "[redacted]"
captive_portal:
external_components:
- source: github://awulf/Actron485
#external_components:
# - source:
# type: local
# path: /config/actron485/components
# Adds fan component per zone (required)
fan:
# UART settings for Actron485 (required)
uart:
rx_pin: GPIO27
tx_pin: GPIO26
baud_rate: 4800
climate:
- platform: actron485
name: "Actron Climate Controller"
write_enable_pin: GPIO25 # Write Enable pin for the RS-485 communication
esp_fan_available: true # For Systems with ESP Auto mode, adds Auto fan mode.
ultima: # For ULTIMA Systems only, adds climate controls per zone.
available: false
adjust_master_target: true # Adjust master target temperature to allow the targeted zone temperature.
logging_mode: ALL
zones:
- number: 1
- number: 2
- number: 3
- number: 4
LOGS
`INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/esphome-web-66825c.yaml...
INFO Starting log output from 192.168.1.6 using esphome API
INFO Successfully connected to actron-ac-esphome @ 192.168.1.6 in 0.103s
INFO Successful handshake with actron-ac-esphome @ 192.168.1.6 in 0.096s
[22:16:27][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 10 2024, 22:14:00
[22:16:27][C][wifi:577]: WiFi:
[22:16:27][C][wifi:409]: Local MAC: 10:52:1C:66:82:5C
[22:16:27][C][wifi:414]: SSID: ''[redacted]
[22:16:27][C][wifi:415]: IP Address: 192.168.1.6
[22:16:27][C][wifi:417]: BSSID: [redacted]
[22:16:27][C][wifi:418]: Hostname: 'actron-ac-esphome'
[22:16:27][C][wifi:420]: Signal strength: -50 dB ââââ
[22:16:27][C][wifi:424]: Channel: 11
[22:16:27][C][wifi:425]: Subnet: 255.255.255.0
[22:16:27][C][wifi:426]: Gateway: 192.168.1.1
[22:16:27][C][wifi:427]: DNS1: 192.168.1.1
[22:16:27][C][wifi:428]: DNS2: 0.0.0.0
[22:16:27][C][logger:447]: Logger:
[22:16:27][C][logger:448]: Level: DEBUG
[22:16:27][C][logger:449]: Log Baud Rate: 115200
[22:16:27][C][logger:451]: Hardware UART: UART0
[22:16:27][C][uart.arduino_esp32:137]: UART Bus 1:
[22:16:27][C][uart.arduino_esp32:138]: TX Pin: GPIO26
[22:16:27][C][uart.arduino_esp32:139]: RX Pin: GPIO27
[22:16:27][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[22:16:27][C][uart.arduino_esp32:143]: Baud Rate: 4800 baud
[22:16:27][C][uart.arduino_esp32:144]: Data Bits: 8
[22:16:27][C][uart.arduino_esp32:145]: Parity: NONE
[22:16:27][C][uart.arduino_esp32:146]: Stop bits: 1
[22:16:27][C][actron485.climate:571]: ClimateTraits:
[22:16:27][C][actron485.climate:572]: [x] Visual settings:
[22:16:27][C][actron485.climate:573]: - Min temperature: 16.0
[22:16:27][C][actron485.climate:574]: - Max temperature: 30.0
[22:16:27][C][actron485.climate:575]: - Temperature step:
[22:16:27][C][actron485.climate:576]: Target: 0.5
[22:16:27][C][actron485.climate:577]: Current: 0.1
[22:16:27][C][actron485.climate:578]: - Min humidity: 30
[22:16:27][C][actron485.climate:579]: - Max humidity: 99
[22:16:27][C][actron485.climate:581]: [x] Supports current temperature
[22:16:27][C][actron485.climate:593]: [x] Supports action
[22:16:27][C][actron485.climate:596]: [x] Supported modes:
[22:16:27][C][actron485.climate:598]: - OFF
[22:16:27][C][actron485.climate:598]: - COOL
[22:16:27][C][actron485.climate:598]: - HEAT
[22:16:27][C][actron485.climate:598]: - FAN_ONLY
[22:16:27][C][actron485.climate:598]: - AUTO
[22:16:27][C][actron485.climate:601]: [x] Supported fan modes:
[22:16:27][C][actron485.climate:603]: - AUTO
[22:16:27][C][actron485.climate:603]: - LOW
[22:16:27][C][actron485.climate:603]: - MEDIUM
[22:16:27][C][actron485.climate:603]: - HIGH
[22:16:27][C][actron485.climate:616]: [x] Supported custom presets:
[22:16:27][C][actron485.climate:618]: - Continuous Fan
[22:16:27][C][actron485.climate:618]: - Standard Fan
[22:16:27][C][captive_portal:088]: Captive Portal:
[22:16:27][C][mdns:115]: mDNS:
[22:16:27][C][mdns:116]: Hostname: actron-ac-esphome
[22:16:27][C][ota:096]: Over-The-Air Updates:
[22:16:27][C][ota:097]: Address: actron-ac-esphome.local:3232
[22:16:27][C][ota:103]: OTA version: 2.
[22:16:27][C][api:139]: API Server:
[22:16:27][C][api:140]: Address: actron-ac-esphome.local:6053
[22:16:27][C][api:142]: Using noise encryption: YES
[22:16:49][D][actron485.climate:027]: Time to Send
[22:17:50][D][climate:011]: 'Actron Climate Controller' - Setting
[22:17:50][D][climate:015]: Mode: COOL
[22:17:50][D][climate:396]: 'Actron Climate Controller' - Sending state:
[22:17:50][D][climate:399]: Mode: COOL
[22:17:50][D][climate:401]: Action: OFF
[22:17:50][D][climate:419]: Current Temperature: nan°C
[22:17:50][D][climate:425]: Target Temperature: nan°C
[22:18:01][D][climate:011]: 'Actron Climate Controller' - Setting
[22:18:01][D][climate:015]: Mode: FAN_ONLY
[22:18:01][D][climate:396]: 'Actron Climate Controller' - Sending state:
[22:18:01][D][climate:399]: Mode: FAN_ONLY
[22:18:01][D][climate:401]: Action: OFF
[22:18:01][D][climate:419]: Current Temperature: nan°C
[22:18:01][D][climate:425]: Target Temperature: nan°C
[22:20:09][I][ota:117]: Boot seems successful, resetting boot loop counter.
[22:20:09][D][esp32.preferences:114]: Saving 1 preferences to flash...
[22:20:09][D][esp32.preferences:143]: Saving 1 preferences to flash: 0 cached, 1 written, 0 failed
A few updates trying to get the Actron RS485 integration working by @awulf (GitHub - awulf/Actron485: PlatformIO library to control Actron Air Conditioners directly via the RS485 bus).
Progress however its not working yetâŚ
I changed the power supply to the RS485 module to give it 5V (using 3.3V yesterday).
With this change, I get the following which is progress from yesterday.
[13:22:42][C][actron485.climate:226]: Actron485 Status:
[13:22:42][C][actron485.climate:227]: Receiving Data: YES
Iâm now recieving data however indication and controls are not working. Indication, AC modes, fan speed, various temperatures are constantly changing when looking at the climate card in home assistant. The values are not real and are gibberish.
The log file (copied below), is also recieving a lot of information but are unknown messages�
I also tried swapping the A and B wires from the Actron card and the RS485 module as suggested bu awulf in an earlier post.
Appreciate if anyone can assist.
Thanks in advance.
ESPhome code
esphome:
platformio_options:
libraries:
Actron485
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
encryption:
key: "[redacted]"
ota:
wifi:
ap:
ssid: "[redacted]"
captive_portal:
# - source:
# type: local
fan:
uart:
rx_pin: GPIO27
tx_pin: GPIO26
baud_rate: 4800
climate:
available: false
adjust_master_target: false # Adjust master target temperature to allow the targeted zone temperature.
logging_mode: ALL
zones:
- number: 1
- number: 2
- number: 3
- number: 4
logs
INFO Successfully connected to actron-ac-esphome @ 192.168.1.6 in 0.052s
INFO Successful handshake with actron-ac-esphome @ 192.168.1.6 in 0.099s
[13:22:42][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 10 2024, 22:14:00
[13:22:42][C][wifi:577]: WiFi:
[13:22:42][C][wifi:409]: Local MAC: 10:52:1C:66:82:5C
[13:22:42][C][wifi:414]: SSID: '[redacted]'[redacted]
[13:22:42][C][wifi:415]: IP Address: 192.168.1.6
[13:22:42][C][wifi:417]: BSSID: [redacted][redacted]
[13:22:42][C][wifi:418]: Hostname: 'actron-ac-esphome'
[13:22:42][C][wifi:420]: Signal strength: -55 dB ââââ
[13:22:42][C][wifi:424]: Channel: 11
[13:22:42][C][wifi:425]: Subnet: 255.255.255.0
[13:22:42][C][wifi:426]: Gateway: 192.168.1.1
[13:22:42][C][wifi:427]: DNS1: 192.168.1.1
[13:22:42][C][wifi:428]: DNS2: 0.0.0.0
[13:22:42][C][logger:447]: Logger:
[13:22:42][C][logger:448]: Level: DEBUG
[13:22:42][C][logger:449]: Log Baud Rate: 115200
[13:22:42][C][logger:451]: Hardware UART: UART0
[13:22:42][D][actron485.climate:027]: Unknown Message received
[13:22:42][D][actron485.climate:027]: 51 18 30 80 05 97 00 06 77 23 28 69 EB A1 9F 27 15 CF 1D C5 60 29 37 9D AD DA A8 9F C7 11 05 98 26 10 A4 E9 4A 9B 22 29 F5 22 56 88 72 41 52 A1 40 A9 18 E3 17 48 50 41 0A FF C8 42 BC DD 18 22
[13:22:42][D][actron485.climate:027]: 40 A8 E4 22 A5 C1 E2 84 40 02 0C 56 13 57 43 0E 88 3E 66 42 02 30 EA 04 03 8E 58 66 17 C9 80 0C C4 28 0A A0 DF 7B 0C 20 04 68 8A 00 20 00 35 03 26 00 31 BE BE 1C 05 40
[13:22:42][C][uart.arduino_esp32:137]: UART Bus 1:
[13:22:42][C][uart.arduino_esp32:138]: TX Pin: GPIO26
[13:22:42][C][uart.arduino_esp32:139]: RX Pin: GPIO27
[13:22:42][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[13:22:42][C][uart.arduino_esp32:143]: Baud Rate: 4800 baud
[13:22:42][C][uart.arduino_esp32:144]: Data Bits: 8
[13:22:42][C][uart.arduino_esp32:145]: Parity: NONE
[13:22:42][C][uart.arduino_esp32:146]: Stop bits: 1
[13:22:42][C][actron485.climate:571]: ClimateTraits:
[13:22:42][C][actron485.climate:572]: [x] Visual settings:
[13:22:42][C][actron485.climate:573]: - Min temperature: 16.0
[13:22:42][C][actron485.climate:574]: - Max temperature: 30.0
[13:22:42][C][actron485.climate:575]: - Temperature step:
[13:22:42][C][actron485.climate:576]: Target: 0.5
[13:22:42][C][actron485.climate:577]: Current: 0.1
[13:22:42][C][actron485.climate:578]: - Min humidity: 30
[13:22:42][C][actron485.climate:579]: - Max humidity: 99
[13:22:42][C][actron485.climate:581]: [x] Supports current temperature
[13:22:42][C][actron485.climate:593]: [x] Supports action
[13:22:42][C][actron485.climate:596]: [x] Supported modes:
[13:22:42][C][actron485.climate:598]: - OFF
[13:22:42][C][actron485.climate:598]: - COOL
[13:22:42][C][actron485.climate:598]: - HEAT
[13:22:42][C][actron485.climate:598]: - FAN_ONLY
[13:22:42][C][actron485.climate:598]: - AUTO
[13:22:42][C][actron485.climate:601]: [x] Supported fan modes:
[13:22:42][C][actron485.climate:603]: - AUTO
[13:22:42][C][actron485.climate:603]: - LOW
[13:22:42][C][actron485.climate:603]: - MEDIUM
[13:22:42][C][actron485.climate:603]: - HIGH
[13:22:42][C][actron485.climate:616]: [x] Supported custom presets:
[13:22:42][C][actron485.climate:618]: - Continuous Fan
[13:22:42][C][actron485.climate:618]: - Standard Fan
[13:22:42][D][actron485.climate:027]: DC 64 05 A4 00 16 93 AD FD 02 D4 0E 21 C2 63 E4 1A 33 03 00 2D BD 0C 36 C0 0F 98 A0 74 31 8C 8E 48 E0 AE 05 0E 00 1B 7B 40 00 23 E9 D8 88 19 0A 1F 66 40 F0 4A 4E B2 C0 7C 31 F1 80 29 A2 B0 96
[13:22:43][C][captive_portal:088]: Captive Portal:
[13:22:43][D][actron485.climate:027]: Unknown Message received
[13:22:43][D][actron485.climate:027]: 51 65 0B C3 00 01 52 CA 8B 0F C1 20 F0 51 00 86 51 91 D5 E4 20 55 20 77 C3 A3 02 B8 41 29 08 23 57 CE 40 48 29 71 53 41 C0 8C 5B 5C 18 78 50 1F 54 5C 2E 6B 16 04 04 0C
[13:22:43][C][mdns:115]: mDNS:
[13:22:43][C][mdns:116]: Hostname: actron-ac-esphome
[13:22:43][C][ota:096]: Over-The-Air Updates:
[13:22:43][C][ota:097]: Address: actron-ac-esphome.local:3232
[13:22:43][C][ota:103]: OTA version: 2.
[13:22:43][C][api:139]: API Server:
[13:22:43][C][api:140]: Address: actron-ac-esphome.local:6053
[13:22:43][C][api:142]: Using noise encryption: YES
[13:22:43][D][actron485.climate:027]: 30 E8 40 04 42 C7 00 AE 99 43 4A 61 08 00 58 F2 18 1C 41 64 2C 22 C1 D1 1D A2 72 0D 9A 00 5E C9 14 43 01 4B 49 2A 00 26 07 02 40 01 E7 64 57 79 30 E9 0F 41 48 71 75 B7 08 02 8E 00 14 00 A0 32
[13:22:43][D][actron485.climate:027]: 4B 45 08 50 C0 2C 87 1A 50 C1 B7 39 00 EC AE F5 11 50 E4 D9 46 42 78 8E B0 11 88 47 34 A8 88 02 09 75 54 48 3C 98 8C 6D 2A 58 90 AF 18 81 29 81 0A EF 62 81 90 05 41 A8
[13:22:43][D][actron485.climate:027]: 01 05 5A 12 4F 07 74 0E 15 BC 97 F8 75 56 98 40 BD 43 84 61 B2 DC E8 31 98 32 64 1B 19 16 82 69 C3 11 A8 4A 97 1A 57 1C 62 B6 F9 42 00 C2 AC 06 04 64 01 65 04 93 88 B1 6A 33 0A 00 14 51 00 40
[13:22:43][D][actron485.climate:027]: 56 C7 4C 02 2C E3 FE 20 10 0A 37 EE 01 C8 2E 8D 8B B4 18 BC C0 FF 60 31 E9 0B DD 6B A9 28 53 63 01 A7 E3 49 80 8F F7 81 C4 13 E6 FE 04 86 AC 10 30 F0 B3 39 3F 66 10 CF
[13:22:43][D][actron485.climate:027]: C: Zone: 4, Temp Offset: 7.90
[13:22:43][D][actron485.climate:027]: D4 A9 20 4F 53 44 54 19 8D 20 0A E0 75 5E C1 C7 9C D1 AE 02 C3 26 34 C5 8A 1F 74 74 55 C0 33 4B FA 00 00 E8 05 10 88 80 09 25 95 19 D1 45 F1 16 9C E8 F6 17 00 34 BC 06 67 07 A0 74 16 A2 06 E0
[13:22:43][D][actron485.climate:027]: 00 43 00 00 58 78 C9 00 0E 30 D6 12 10 45 49 40 C7 00 06 FC 38 18 00 89 FE 94 80 C8 90 66 18 56 0B 49 CF D3 81 37 45 52 72 A6 A9 AA CF 73 A9 4F E7 89 80 A0 62 26 08 60
[13:22:43][D][actron485.climate:027]: C: Zone: 7, Temp Offset: 9.40
[13:22:43][D][actron485.climate:027]: F7 CD 72 5E AD 47 08 AA 4B 55 57 63 D0 BE C9 3C 32 00 50 14 DB 27 1C 82 7B 89 83 69 90 4C 62 31 A2 E5 42 1C 13 60 1D 48 4A 20 40 AB 98 F1 80 7E 22 00 80 60 0D 89 1D A2 81 27 2A 00 C0 D4 CA 32
[13:22:44][D][actron485.climate:027]: Unknown Message received
[13:22:44][D][actron485.climate:027]: 03 40 14 60 3A C4 64 97 09 28 92 DA 77 CF 8F 54 04 D6 CD C2 04 08 85 B8 40 0C 6C DA 3B 52 9A 83 AA 9F D7 91 CF 6B A9 B1 1A A1 66 F3 A9 08 9F F3 2B EF CB 43 22 52 98 B0
[13:22:44][D][actron485.climate:027]: F0 AF 35 00 FC 80 80 B1 22 0B 93 81 1C 3D 15 00 06 08 C6 07 80 5C 98 B0 F3 01 11 C6 67 31 51 A4 63 6A 75 60 22 13 89 C1 20 24 B4 BF D6 48 44 E6 A2 10 31 4A E7 17 B0 1E B0 02 4B 70 80 30 5A 0B
[13:22:44][D][actron485.climate:027]: 01 0C C3 E3 7E 36 04 FE C0 C0 E0 FF 9E 9F E7 51 AF 6A A9 9B 1A 31 B0 C0 6D 0B 26 02 2E 9C 1C 82 32 36 62 26 0C FD 20 D5 EE 83 54 39 F7 51 B0 9A 09 1B 3A A9 CF B3 55 28
[13:22:44][D][actron485.climate:027]: M: Zone: 4, Set Point: 16.00, Temp: 46.20, SP Range: 0.50-27.00, Zone: Off, Damper Pos: 0%, ??Adjusting??
[13:22:44][D][actron485.climate:027]: 94 CE 23 C1 E0 76 9D A0 08 9D 6B 88 92 32 7F 17 3F CF 44 DD C4 28 86 AE 62 D9 B1 04 1C 0B A1 04 0A 6C 10 DF 14 64 00 A4 22 60 C1 AA 83 36 87 00 10 04 F5 01 0C B5 DB 0A B6 58 03 6A C1 58 8A 18
[13:22:44][D][actron485.climate:027]: C: Zone: 6, Temp Offset: -8.80
[13:22:44][D][actron485.climate:027]: E6 2B 29 A8 D1 EB 14 05 D5 EC 00 30 1F FD 80 9F EE 32 54 EF 3A A9 60 DC 73 7F A9 00 01 91 64 C0 04 8C 00 E0 0F 10 A5 B7 3B 42 35 AA 32 50 BD 76 16 68 94 F3 80 4F F7 85
[13:22:44][D][actron485.climate:027]: 54 35 4E 01 DB 28 08 08 10 DC 46 00 64 C0 F0 C0 54 9A 68 66 94 9C 03 29 78 DC 7D 24 14 73 FD B2 08 C7 01 55 85 7C A4 89 FB 6A 01 2C 10 BD 6A 00 3A B8 13 A2 86 C0 61 02 02 E0 F2 77 63 EC F0 00
[13:22:44][D][actron485.climate:027]: 05 10 A1 70 B4 EF A6 00 80 BA 07 05 20 A8 C0 78 69 6A 0E 00 4C 22 0C 73 58 8F C7 55 A8 D4 3A A1 36 59 73 52 40 68 93 2C 20 44 3E 8B 3F 66 A0 7F 23 54 A8 16 97 10 A0 9B
[13:22:45][D][actron485.climate:027]: M: Zone: 4, Set Point: 29.00, Temp: 0.10, SP Range: 25.50-6.00, Zone: Off, Damper Pos: 20%
[13:22:45][D][actron485.climate:027]: A4 01 04 73 3A 8C A4 DA 36 5F 01 3A E5 40 23 80 C7 97 60 20 81 AC 04 00 51 E5 1A 99 92 8D 07 3A E2 50 0E A7 15 0B 3A 04 20 0E 02 01 9C AD 43 98 33 99 FC D6 84 C7 45 40 0D 30 18 38 E0 32 00 00
[13:22:45][D][actron485.climate:027]: B0 22 86 C8 46 05 14 F4 AA CE A8 FA 44 92 C6 3B 29 3F DD F2 12 9F 54 A8 31 E7 24 DF F3 A1 41 F4 A9 99 33 55 0A 9F F3 81 C0 13 F7 6D 11 48 8C 10 64 0C C6 5E 1F 7D AA 6C
[13:22:45][D][actron485.climate:027]: M: Zone: 2, Set Point: 28.50, Temp: 3.60, SP Range: 10.00-31.00, Zone: On, Compr. Mode: Off, Damper Pos: 40%
[13:22:45][D][actron485.climate:027]: B2 24 48 54 79 3E 20 80 59 D8 B3 84 CE 3A A9 27 8E B3 2C 45 4A 39 38 03 95 6F 81 09 01 52 41 6C ED C7 67 85 F1 FE 80 D0 C2 C4 3A CC 4D A0 C4 61 D8 6E 81 FC CC C0 30 25 08 03 CB 81 39 9C 00 0F
[13:22:45][D][actron485.climate:027]: Unknown Message received
[13:22:45][D][actron485.climate:027]: 4E 01 0C 88 38 24 29 92 5E 15 49 00 E4 C2 65 08 08 D7 69 C3 00 0D 38 55 CD 3B 02 A8 9F 93 05 8F D3 01 AA CF 73 A9 CF 33 12 00 BD 57 53 A8 66 50 C0 42 96 C7 42 80 80 00
[13:22:45][D][actron485.climate:027]: 9F 07 48 00 63 D8 4D 02 AF 9D 11 C3 07 22 87 10 80 54 82 89 F3 A6 32 17 19 04 E9 D6 0C 29 16 03 9B 00 17 02 A5 52 12 C2 30 07 90 D2 08 D8 F0 B0 48 2F FA 64 01 12 45 FB E4 C1 80 F4 7B 45 81 4C
[13:22:45][D][actron485.climate:027]: 30 B1 B6 24 8A A1 27 F0 85 56 5C 18 24 4A 32 5B 9B 01 80 97 9C C0 4A BB C0 60 44 04 D8 3B 42 CF 0F 54 A1 52 A9 CF F3 A9 08 9B 73 AB 5F C3 43 39 E7 55 E0 B7 C3 A0 C5 24
[13:22:46][D][actron485.climate:027]: Unknown Message received
[13:22:46][D][actron485.climate:027]: 03 26 12 98 BE 24 20 24 2E 0A 12 BA AD 78 96 04 9D C4 2A 0B 4A 5C 35 0C 28 3D C4 04 40 48 6A 08 00 84 51 6E E0 81 9E 20 C5 30 8A 16 81 BD 49 A4 CC 37 58 3E 16 44 0F 33 E0 7B DA 97 06 70 E8 B0
[13:22:46][D][actron485.climate:027]: 39 A8 01 3D 48 92 C4 0B 93 37 0A 01 DA 46 86 CF F3 21 40 A8 A7 D3 A4 BC 0C F4 4D 53 18 34 77 A8 4A D8 7B 97 EA 0F 4E 20 F4 A9 68 66 86 9B F3 25 40 A8 CF D7 55 D7 91 A9
[13:22:46][D][actron485.climate:027]: 00 AA C7 27 14 20 00 5B 00 04 21 DB 88 03 49 95 0E 28 20 F7 B0 42 9B 00 3F F2 70 87 01 66 19 AE A9 F2 2E 01 04 82 42 22 ED 64 80 85 30 04 A1 8E 00 82 F2 40 E9 C3 C2 08 22 02 79 19 B8 70 AC BF
[13:22:46][D][actron485.climate:027]: C: Zone: 1, Temp Offset: 1.50
[13:22:46][D][actron485.climate:027]: F1 46 74 0F 6B 19 74 A2 EF 03 02 98 47 BF 18 52 C7 7F DF E7 26 9D 3B 0B AD ED 0B BF 96 E4 02 E4 72 94 C0 F0 8E 0E FB 78 D5 D4 EA 14 AA F3 77 80 54 3F D6 42 5E 3A 01 CF
[13:22:46][D][actron485.climate:027]: C: Zone: 6, Set Point: 2.50, Temp: 71.30(Pre:60.80), Mode: Off
[13:22:46][D][actron485.climate:027]: E6 05 00 9A D6 05 04 1F 3B 85 80 14 60 41 A2 87 08 21 35 0C 0A B2 CC 14 01 28 98 1A C0 C4 38 4A 07 B0 84 CD 98 89 3C 02 83 46 00 44 28 5A 31 50 08 D9 41 4C 39 8A D4 66 00 F6 18 D2 2F A1 E0 BC
[13:22:46][D][actron485.climate:027]: 0B 5A 80 02 BC FD 27 04 60 44 92 E9 A0 06 CE E1 48 55 05 AF 80 E3 7E CF 98 49 00 9B F7 29 80 33 D4 A9 C0 18 5B 2C 24 C4 33 B0 60 44 CC BB 1F 4B A0 00 CF 63 A9 B8 9A 82
[13:22:46][D][actron485.climate:027]: 55 B9 F7 14 04 5B D2 98 A4 EA 68 BB 61 DA A1 22 42 00 3C 0C 67 70 23 86 2B 09 42 01 B9 3F B0 01 9C 98 21 2C 2D C1 2F 02 94 03 94 EC 84 84 84 62 71 0F 9C 2D 2B 64 E0 03 00 0C 02 B0 00 20 A0 97
[13:22:46][D][actron485.climate:027]: 00 00 24 B3 24 78 B5 85 34 0D 22 01 54 D5 CB BC 30 53 C0 F0 80 03 40 4F 33 15 14 40 CE 03 CF D6 09 A0 35 27 14 00 D9 1A 02 35 E7 02 14 7A 81 80 A2 90 6D D4 10 C4 98 5B
[13:22:47][D][actron485.climate:027]: Unknown Message received
[13:22:47][D][actron485.climate:027]: 6E 21 10 B1 E5 A9 1F FD 1C A8 66 E8 08 02 92 32 4A AA 0A 01 9C 52 23 27 C3 63 1C B7 16 34 AE 4D 21 00 1D 7B 6F 30 05 90 6E 24 26 39 46 3C D9 60 7C 9C F9 A6 00 40 20 E0 B3 BE 10 B6 C0 58 00 32
[13:22:47][D][actron485.climate:027]: E0 6D 16 95 00 A0 55 32 26 E9 96 02 D0 5E CA 92 F1 56 93 60 1A 90 40 24 E0 D9 FB 40 55 67 3A 09 39 4B 09 5B F3 A9 E8 6E 83 5F F3 A1 50 9B D3 41 6B 25 88 66 22 CF 43 22
[13:22:47][D][actron485.climate:027]: 07 B4 F3 98 FF 71 73 93 E0 46 4C 47 11 1C A9 1B B2 44 0C 24 1F 49 FE 16 F1 78 16 2C 52 B2 23 12 00 A8 32 87 59 98 89 46 71 37 5C 10 AD F5 E5 00 B0 6E 10 6D 6C C0 B5 AA 00 E0 1C 60 E6 80 E0 68
[13:22:47][D][actron485.climate:027]: 70 3A 79 10 B8 57 88 92 A2 58 6B 7F 07 55 D3 D3 A1 67 EA A1 0C 25 A3 8F B6 08 E9 1E FF 30 08 C8 16 8B B2 BC 3F 9F F3 A1 00 E7 3A A9 D7 9A A9 CF F3 01 28 CF 73 A9 CF 37
[13:22:47][D][actron485.climate:027]: M: Zone: 6, Set Point: 7.50, Temp: 0.00, SP Range: 9.50-26.50, Zone: Off, Damper Pos: 40%
[13:22:47][D][actron485.climate:027]: 86 00 08 53 0F 35 83 06 19 A1 80 E4 C0 00 C1 78 98 95 0D F8 1A 16 67 58 AE B2 4F 0D 00 60 FE 59 10 09 81 C7 C6 02 80 A0 E0 50 68 CE F8 61 11 40 80 88 0F CA 05 42 7E B7 4C 61 96 36 D8 00 28 54
[13:22:47][D][actron485.climate:027]: 90 59 00 C0 0C 1E 10 17 2C 20 37 22 05 2A CE CF 48 42 32 98 4B F1 FF A8 55 8F 9A 0B BD D1 A1 20 E1 AB 78 40 20 08 E0 C5 22 3B E7 55 E4 92 A7 A0 54 D6 52 E9 3F E6 02 5B
[13:22:48][D][actron485.climate:027]: Unknown Message received
[13:22:48][D][actron485.climate:027]: 1B 29 D4 EF 1A A9 08 F8 33 10 21 25 D9 6F 12 2E 82 66 EB 98 9E 1C DB B1 11 4C EE 7F E4 46 84 8C EB E1 18 A2 03 76 1C 7E C1 8B 8E 02 50 CF 28 2A 03 55 60 37 49 C8 9D 77 08 32 40 D8 1E 14 49 19
[13:22:48][D][actron485.climate:027]: 05 8D 35 02 D8 52 86 02 4C 19 AE 0B 16 68 5D BB A4 55 85 58 5A 10 1F FF 59 9B 09 80 AF 3A A9 02 9B 73 AB FE 41 30 14 98 C9 18 60 34 14 00 1F FB 10 54 CF 3B 09 A8 9F B3
[13:22:48][D][actron485.climate:027]: 13 AF F3 A1 08 FF 88 40 54 9D 8F 20 61 C0 C7 84 30 7C 14 56 41 04 E4 15 15 AA 2A 1A CD AA 45 49 06 F9 A6 61 31 00 07 00 43 09 21 98 50 B6 C5 87 C3 8E 00 C0 60 B3 26 78 A6 62 B0 36 00 00 A0 B0
[13:22:48][D][actron485.climate:027]: 07 10 0C 81 D5 41 1C 26 F5 F4 F0 82 10 40 3B 08 4A C4 D8 4B 8F 71 14 00 E0 80 4B E8 DB 3F 35 A7 04 15 67 1A 09 69 34 A9 CF F3 A1 02 4C A3 D3 10 00 F0 30 80 0C 6C D8 6B
[13:22:48][D][actron485.climate:027]: 40 E4 CB 18 49 31 E7 85 E1 6B 35 D0 A1 41 A8 0A 6C 31 01 66 4C 01 25 D8 CD 01 28 62 5F 39 08 22 4C 27 08 94 38 99 30 C5 0C 09 FF 46 30 31 19 2B CC C0 13 80 C3 1B C6 BF A3 1D 06 00 00 18 B0 4A
[13:22:48][D][actron485.climate:027]: 07 00 66 B3 0A 80 28 D2 08 48 55 85 5B 00 F7 0F 38 6C 3A 3E 54 10 00 60 B8 F3 78 8F E7 09 EF 3B 29 A8 38 34 02 A8 8F F3 A9 81 00 94 93 80 CF 48 09 80 BB F7 3D 90 8D CB
[13:22:48][D][actron485.climate:027]: M: Zone: 1, Set Point: 14.50, Temp: 4.00, SP Range: 1.50-28.50, Zone: On, Compr. Mode: Off, Damper Pos: 80%, ??Adjusting??
[13:22:48][D][actron485.climate:027]: 91 28 52 43 1D 39 FE F7 AA 4A 00 D9 D9 BF 82 5C 75 66 0C 0A 61 48 63 06 E1 92 DF 86 92 10 92 DB 38 1E 72 5C 8E 00 D3 6B C6 54 F4 00 96 96 00 0A 00 EB 5C 00 28 06 B4 02 00 C0 80 3F 61 40 84 B4
[13:22:48][D][actron485.climate:027]: C: Zone: 7, Set Point: 65.50, Temp: 8.00(Pre:8.30), Mode: Off
[13:22:48][D][actron485.climate:027]: C7 83 02 A7 45 B3 20 28 CA 07 EC 84 39 8D 54 DF D9 42 1D BC 45 2A 90 A6 43 40 24 1E 1A 84 93 BC 25 3B 82 54 1F 73 9D 84 AF 1B 29 9F 9A A9 CF F3 A1 08 B9 33 02 E7 D1 14
[13:22:49][D][actron485.climate:027]: Unknown Message received
[13:22:49][D][actron485.climate:027]: 0C ED 15 E3 22 40 07 63 28 C7 5E A9 CF 1A 42 20 E8 CA 23 54 64 AA 88 21 06 A7 B1 1F 40 45 98 E1 52 28 0A 2C 29 F7 38 20 85 01 A3 0E 20 6A B2 98 14 49 47 9F 97 E0 87 F4 2C C9 16 30 6A B7 40 4D
[13:22:49][D][actron485.climate:027]: 76 AB 84 23 A8 05 51 00 00 48 98 D4 00 84 4D 2C 8A 2A 82 0F 96 E2 FF BD 45 9C 23 84 8B 13 7D A3 30 84 7C 89 2C 9F 05 00 19 D9 52 00 6F 52 12 4A C0 DC 73 99 33 12 80 9F
[13:22:49][D][actron485.climate:027]: 2E 55 04 69 01 8C 28 67 81 4B 10 F1 DE 42 01 20 80 25 79 01 00 6C F1 07 81 15 42 95 48 11 18 5F DC 7D 63 81 44 6A 3C 05 00 30 EE 55 10 60 44 53 22 E1 07 27 1D F0 06 B0 34 12 05 14 4C 15 46 06
[13:22:49][D][actron485.climate:027]: C: Zone: 8, Init Zone-3.40
[13:22:49][D][actron485.climate:027]: C8 7B 16 C2 68 00 34 11 09 16 7E 41 A8 85 59 00 24 BF 7E B5 3B 24 54 00 9F 23 02 00 DA 2B 7F 57 A2 E2 3A 0E 89 A0 B9 36 C0 38 80 C5 5C 50 9B 73 A9 A8 E7 5B 02 84 50 9F
[13:22:49][D][actron485.climate:027]: C: Zone: 4, Temp Offset: -10.40
[13:22:49][D][actron485.climate:027]: D4 A9 B5 98 13 10 49 3D CD 85 81 50 95 D8 8D 64 97 E8 04 88 35 36 A0 4B A7 93 86 85 83 5C FC 5A 20 D1 83 86 C3 74 8E B1 14 CE 02 42 31 30 DB CC A0 C0 00 92 78 04 00 58 82 38 01 D8 9B 1B 00 00
[13:22:49][D][actron485.climate:027]: C: Zone: 4, Set Point: 112.50, Temp: -8.20(Pre:-7.00), Mode: Open
[13:22:49][D][actron485.climate:027]: D4 E1 C3 40 78 E0 E2 7F 01 C0 49 C9 15 02 49 69 A2 01 3C FD 9C AA 8F 52 12 A8 1F A7 09 CF E3 A9 68 71 E6 05 CF F3 08 00 9F 73 A9 CE 11 00 4A 44 AB 09 80 7C 5A 03 1E 7B
[13:22:50][D][actron485.climate:027]: Unknown Message received
[13:22:50][D][actron485.climate:027]: 56 54 54 8F 1A 42 00 8F 03 46 54 4F 05 85 07 7C AE 00 00 9E 51 B3 C6 10 41 8C 99 02 00 84 76 98 52 2A 0E D9 DB 44 84 58 34 22 05 00 84 00 10 14 00 60 F9 AB 8C 30 46 E1 FC 23 0A 1C B6 61 B0 80
[13:22:50][D][actron485.climate:027]: M: Zone: 6, Set Point: 28.00, Temp: 8.80, SP Range: 16.00-0.00, Zone: Off, Damper Pos: 0%
[13:22:50][D][actron485.climate:027]: 86 58 00 E0 B8 C0 07 00 00 46 4D 7F 00 81 D6 FD 0A 00 43 1C 99 84 28 64 58 48 4A 92 99 9F FD C0 50 C0 AA 72 50 35 16 FB A1 80 37 F7 01 00 EF 1A 02 A8 7F E7 09 D9 63 29
[13:22:50][D][actron485.climate:027]: 20 80 C2 93 20 24 8E 00 72 30 24 4C 80 F0 87 36 61 38 33 60 24 E0 84 B3 41 44 88 90 A5 70 2E 60 5A 04 62 25 E1 66 2B 98 1C E8 03 8A 24 A1 BF 89 12 47 21 5C FD 44 80 20 22 EB 28 13 50 B8 24 08
What model is your AC?
Looking at the messages in the log, itâs all gibberish, canât even see a pattern. Some messages should be repeating at least every second.
The code is interpreting some messages as something valid even though they arenât related (Looks like I need to put in some better guards for this in the code to reduce confusion).
I feel there is some sort of communications issue (e.g. the RS485 module should work on v3.3). But also might be a timing thing that Iâve made an assumption for based on my AC unit. In the logs, itâs running out of buffer for reading the data so Iâve increased that now. Try the updated code and post back the logs. Also be handy if you can record the actual state of the AC. E.g. Setpoint temperature, which zones are on/off, current temperature, operating mode. Then I can see if that data is scattered in those logs.
Hi @awulf ,
AC indoor unit is SRV171E-0100
AC outdoor unit is SRD173C-0300
The log is gibberish whenever the ESP and RS485 module is powered up with the config and connected to home assistant. This also includes when the A and B wires are disconnected from the AirCon indoor unit and when the A and B wires are connected and the power supply is isolated from the AirCon indoor and outdoor units. The gibberish doesnât change when the AirCon power is turned on.
I think Iâve got the updated code. I donât have a lot of expereince here but I uploaded a new config onto the ESP with this config in the .yaml. I assume this config automatically pulls the update you made a few days ago when I install the config from ESPHome?
I also get an error message from Home Assistant (randomly poping up on the screen) " Fan mode is not valid. Valid fan modes are: auto, low, medium, high.
I will post a series of logs separately below. I was limited to 3 consecutive posts for the forum (this post + 2 log posts).
Thanks in advance
LOGS 15-03-2024
AirCon power supply on but turned off 2024_03_15
INFO Starting log output from 192.168.1.26 using esphome API
INFO Successfully connected to actron-ac-esphome @ 192.168.1.26 in 0.046s
INFO Successful handshake with actron-ac-esphome @ 192.168.1.26 in 0.099s
[08:44:31][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 15 2024, 07:57:59
[08:44:31][C][wifi:577]: WiFi:
[08:44:31][C][wifi:409]: Local MAC: [redacted]
[08:44:31][C][wifi:414]: SSID: [redacted]
[08:44:31][C][wifi:415]: IP Address: [redacted]
[08:44:31][C][wifi:417]: BSSID: [redacted][redacted]
[08:44:31][C][wifi:418]: Hostname: 'actron-ac-esphome'
[08:44:31][C][wifi:420]: Signal strength: -59 dB ââââ
[08:44:31][C][wifi:424]: Channel: 11
[08:44:31][C][wifi:425]: Subnet: 255.255.255.0
[08:44:31][C][wifi:426]: Gateway: [redacted]
[08:44:31][C][wifi:427]: DNS1: [redacted]
[08:44:31][C][wifi:428]: DNS2: 0.0.0.0
[08:44:31][C][logger:447]: Logger:
[08:44:31][C][logger:448]: Level: DEBUG
[08:44:31][C][logger:449]: Log Baud Rate: 115200
[08:44:31][C][logger:451]: Hardware UART: UART0
[08:44:31][D][actron485.climate:027]: Unknown Message received
[08:44:31][D][actron485.climate:027]: 10 79 A7 89 F9 FC 16 BE 59 87 A0 3D C0 54 03 18 56 72 50 A8 FF 1A 90 20 09 A1 86 07 00 46 E3 5E B9 1C 92 01 20 82 3D 00 4A C3 1C 82 79 5F 03 20 C2 B8 9B 29 40 60 40 82 A0 30 FD E6 DC 00 6C 46
[08:44:31][D][actron485.climate:027]: 21 4C 00 D2 02 F7 C6 25 25 3F D4 00 0E 38 0A 26 3E 31 F3 D3 86 38 08 0A 35 56 02 92 04 59 72 31 1C 92 40 7F 40 29 30 7E 3B 06 84 20 97 32 64 82 09 96 0A A8 A1 91 44 6C
[08:44:31][C][uart.arduino_esp32:137]: UART Bus 1:
[08:44:31][C][uart.arduino_esp32:138]: TX Pin: GPIO26
[08:44:31][C][uart.arduino_esp32:139]: RX Pin: GPIO27
[08:44:31][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[08:44:31][C][uart.arduino_esp32:143]: Baud Rate: 4800 baud
[08:44:31][C][uart.arduino_esp32:144]: Data Bits: 8
[08:44:31][C][uart.arduino_esp32:145]: Parity: NONE
[08:44:31][C][uart.arduino_esp32:146]: Stop bits: 1
[08:44:31][C][actron485.climate:226]: Actron485 Status:
[08:44:31][C][actron485.climate:227]: Receiving Data: YES
[08:44:31][C][actron485.climate:571]: ClimateTraits:
[08:44:31][C][actron485.climate:572]: [x] Visual settings:
[08:44:31][C][actron485.climate:573]: - Min temperature: 16.0
[08:44:31][C][actron485.climate:574]: - Max temperature: 30.0
[08:44:31][C][actron485.climate:575]: - Temperature step:
[08:44:31][C][actron485.climate:576]: Target: 0.5
[08:44:31][C][actron485.climate:577]: Current: 0.1
[08:44:31][C][actron485.climate:578]: - Min humidity: 30
[08:44:31][C][actron485.climate:579]: - Max humidity: 99
[08:44:31][C][actron485.climate:581]: [x] Supports current temperature
[08:44:31][C][actron485.climate:593]: [x] Supports action
[08:44:31][C][actron485.climate:596]: [x] Supported modes:
[08:44:31][C][actron485.climate:598]: - OFF
[08:44:31][C][actron485.climate:598]: - COOL
[08:44:31][C][actron485.climate:598]: - HEAT
[08:44:31][C][actron485.climate:598]: - FAN_ONLY
[08:44:31][C][actron485.climate:598]: - AUTO
[08:44:31][C][actron485.climate:601]: [x] Supported fan modes:
[08:44:31][C][actron485.climate:603]: - AUTO
[08:44:31][C][actron485.climate:603]: - LOW
[08:44:31][C][actron485.climate:603]: - MEDIUM
[08:44:31][C][actron485.climate:603]: - HIGH
[08:44:31][C][actron485.climate:616]: [x] Supported custom presets:
[08:44:31][C][actron485.climate:618]: - Continuous Fan
[08:44:31][C][actron485.climate:618]: - Standard Fan
[08:44:31][D][actron485.climate:027]: 01 88 52 B8 24 41 00 9A 86 1E 03 6D 9B E5 8D 60 00 88 82 A6 50 40 1C 3A 30 04 10 B2 07 E5 60 64 F9 04 91 11 90 56 43 29 95 98 75 1F 30 18 31 4A 02 08 64 CA 38 93 A1 1D 01 40 49 04 1C E2 37 42
[08:44:31][C][captive_portal:088]: Captive Portal:
[08:44:32][D][actron485.climate:027]: M: Zone: 8, Set Point: 20.50, Temp: 18.20, SP Range: 5.00-16.50, Zone: On, Compr. Mode: On Heating, Compr. Active, Damper Pos: 60%
[08:44:32][D][actron485.climate:027]: 88 B6 EC CA 29 A1 2B 00 52 28 10 57 00 11 01 1C 65 10 0A 60 9A 48 24 29 01 9D 37 04 02 81 B0 E7 00 21 98 2D 25 93 6A 6E 87 34 54 A0 4B 2D 6C 29 E5 2A 5A 80 00 90 0C 36
[08:44:32][C][mdns:115]: mDNS:
[08:44:32][C][mdns:116]: Hostname: actron-ac-esphome
[08:44:32][C][ota:096]: Over-The-Air Updates:
[08:44:32][C][ota:097]: Address: actron-ac-esphome.local:3232
[08:44:32][C][ota:103]: OTA version: 2.
[08:44:32][D][actron485.climate:027]: 8A D2 8F 09 65 11 26 62 4D 8D 8A 3B 4C 94 26 10 00 6A 90 49 17 88 14 BE 3E 39 A9 2A BB 24 94 19 45 89 41 C9 A2 29 0C 20 40 89 DE A3 1B 18 42 1D 0C 0B 08 9E 66 48 BB BA A0 4E 9E 34 00 C3 68 28
[08:44:32][C][api:139]: API Server:
[08:44:32][C][api:140]: Address: actron-ac-esphome.local:6053
[08:44:32][C][api:142]: Using noise encryption: YES
[08:44:32][D][actron485.climate:027]: M: Zone: 8, Set Point: 9.50, Temp: 6.90, SP Range: 7.50-15.00, Zone: On, Compr. Mode: Off, Fan Mode, Damper Pos: 100%, ??Adjusting??
[08:44:32][D][actron485.climate:027]: 88 45 76 0F 93 1E 48 62 E1 4A 13 75 15 4F 45 15 84 D7 99 6C 64 24 A5 4B 63 03 1B EE 91 25 0C 1A 68 68 DB A1 73 29 86 21 24 C4 B5 42 24 82 5E 04 C1 10 36 4B 42 2B A2 B0
[08:44:32][D][actron485.climate:027]: Unknown Message received
[08:44:32][D][actron485.climate:027]: 2D 31 85 88 A3 91 98 A8 88 60 1F C1 00 CA 54 37 0D 59 40 5C 91 08 89 13 46 AD 01 00 03 83 A0 AA 23 21 46 42 48 32 57 B0 AA E1 94 EE 10 50 91 A2 1D 02 84 50 0A 8E 95 15 A3 B7 C8 94 21 51 20 C1
[08:44:32][D][actron485.climate:027]: 20 15 45 04 24 80 54 67 CC A1 A5 69 73 45 21 A1 20 7C 92 F1 04 24 C0 CB 80 0F 60 D1 51 A8 16 27 48 A9 55 55 8A 1E 50 54 E0 29 3A C2 41 42 A4 3F A4 DF 55 88 55 C8 47 CB
[08:44:32][D][actron485.climate:027]: 89 1F 89 0E 80 87 12 1D 72 89 48 18 B2 08 4A 02 13 1C 15 02 18 80 8E 0C 08 91 08 A2 E0 1F E0 20 54 40 2D AD 30 00 82 05 62 83 04 48 45 31 83 85 A8 95 84 EB 94 15 28 10 0C 08 29 E5 81 83 0C 20
[08:44:32][D][actron485.climate:027]: M: Zone: 1, Set Point: 16.00, Temp: 24.00, SP Range: 28.50-13.00, Zone: On, Compr. Mode: On Cooling, Compr. Active, Damper Pos: 140%, ??Adjusting??
[08:44:32][D][actron485.climate:027]: B1 F0 FE 79 20 DA A6 C1 60 24 C1 13 C8 01 DD 82 F5 58 92 0F 5D 30 C5 C0 48 05 42 55 05 A8 43 65 A1 90 C0 F1 83 02 55 09 0D 3F 7F 60 40 81 C0 20 22 05 08 0D 44 92 05 A8
[08:44:32][D][actron485.climate:027]: 49 88 BE C0 B3 F3 56 48 04 05 05 02 0C 13 04 1B 8D 14 66 19 52 F0 4A 0C 50 3A C2 4F 09 42 05 40 74 A6 4B B1 9A C1 06 00 18 AC 30 34 20 49 72 E2 94 22 C8 D8 1B 0A 55 48 A5 D6 4A 70 22 D3 09 31
[08:44:33][D][actron485.climate:027]: M: Zone: 1, Set Point: 10.50, Temp: 14.80, SP Range: 6.50-8.50, Zone: On, Compr. Mode: Off, Compr. Active, Damper Pos: 20%, ??Adjusting??
[08:44:33][D][actron485.climate:027]: A1 94 66 0D 15 91 66 60 04 49 19 9E DE 00 E0 81 24 0F 84 05 98 6C 40 AB 07 A8 88 0D 48 02 88 C4 62 4C A8 62 70 F9 25 28 86 A7 BB 46 1F 00 05 18 F6 A0 29 03 48 40 05 48
[08:44:33][D][actron485.climate:027]: Unknown Message received
[08:44:33][D][actron485.climate:027]: 25 87 C1 7E 00 35 0E 48 01 22 24 12 01 81 FB E3 A1 21 72 A1 18 12 4D 80 D1 2E C4 92 18 38 C3 83 15 76 43 09 55 50 7C CC 61 1C 95 8C 40 95 21 18 89 09 24 92 48 C5 0B 40 40 B4 A5 0D 23 C1 A6 03
[08:44:33][D][actron485.climate:027]: 80 00 11 DF 1B 22 A9 2A 6D A5 B1 4A D6 15 25 A7 11 05 85 12 F3 17 25 07 58 32 45 07 58 FB A8 E3 08 AB 63 13 52 0A 4A 22 D6 D1 31 C0 F0 95 37 77 20 88 05 38 12 29 0D 60
[08:44:33][D][actron485.climate:027]: 90 05 4C 30 4F E6 2F C1 04 A0 C9 08 8D 13 44 E0 4F 5A 2A 13 01 D1 1C 11 46 83 0B 3A 04 12 20 91 35 90 34 83 E0 47 2A 10 94 AA 91 48 55 44 80 55 55 20 70 88 4A 89 82 47 54 20 88 8D FB 21 8B 01
[08:44:33][D][actron485.climate:027]: D0 83 60 01 DB 1E 4E 89 03 A8 4F 0D 4F 78 4C 03 DC 94 F9 58 A2 05 98 A3 40 82 05 B8 92 50 05 10 92 A4 28 54 B0 20 40 49 52 0B 0A 33 3E F1 16 C4 05 B8 92 3F 3D CA 03 18
[08:44:33][D][actron485.climate:027]: 10 24 C6 BC 46 DF C7 53 94 01 20 4A E0 D6 11 8E 40 AB 05 82 20 02 80 E0 01 48 82 77 91 88 09 84 93 82 69 81 C0 50 F5 A5 15 0D AA 86 50 00 06 84 01 02 42 58 21 A0 65 60 20 65 42 31 02 32 00 00
[08:44:33][D][actron485.climate:027]: 49 CC EE E9 F9 41 0C 1C B2 A8 48 02 21 06 2A FF 08 07 A8 22 E2 38 82 B2 28 48 E3 98 92 C9 05 00 0D 5F 31 59 85 1C C4 44 37 7C 86 01 28 06 0C 10 07 2E 83 50 05 60 C2 44
[08:44:34][D][actron485.climate:027]: 3A 19 18 0D 96 0C 3F 63 94 03 38 19 30 B0 06 80 01 0D C2 02 42 81 3C 55 41 10 28 91 0F 7C 87 6A C9 85 48 80 11 25 A1 C6 01 52 40 72 C9 03 15 47 17 28 15 A0 40 25 C6 08 15 44 05 15 94 01 A8 C9
[08:44:34][D][actron485.climate:027]: Unknown Message received
[08:44:34][D][actron485.climate:027]: 10 18 40 AA 06 00 30 0F CE 10 64 81 E8 47 01 FE CA C5 82 0A 48 08 43 18 32 0D 5A F3 04 03 4E 90 99 FF 9B 92 84 4D 92 32 05 E2 56 1C 61 8F 9C 80 70 00 61 15 60 99 5A 12
[08:44:34][D][actron485.climate:027]: 62 15 3B 60 00 98 F9 07 15 B3 B9 48 40 30 BD E7 3E C1 72 EF A8 44 4A B8 74 5B 16 00 41 81 20 53 A4 15 E0 92 45 48 80 F2 02 A5 C4 96 4D 2A A5 21 A8 4D 54 54 65 C2 93 00 05 88 1F B1 59 00 22 01
[08:44:34][D][actron485.climate:027]: 27 50 2A CF 48 10 C8 B6 1E 83 12 22 51 55 FB 63 38 AF 35 60 12 E1 5A 5B 80 29 C5 28 08 6D E0 48 4D 8F 20 0D 83 98 B9 50 D9 22 62 44 03 0C 00 C0 E3 2A FB 00 29 85 80 88
[08:44:34][D][actron485.climate:027]: CC 07 5A 25 0D 1E 80 85 2A 1D 1A 01 01 65 24 30 35 02 A4 C0 83 42 00 74 C4 41 20 84 2D C2 83 23 86 C3 32 AA 55 EC 8D CB 6A A5 3C 01 33 32 ED 69 08 82 A8 A2 A5 17 29 0D 0E 47 55 44 95 30 09 A0
[08:44:34][D][actron485.climate:027]: State 2: Operating Mode: - Idle, Fan Mode: Off Continuous - Active, Setpoint: 18.00, Temperature: 3444.70, Zones: 1:Off 2:Off 3:Off 4:On 5:Off 6:Off 7:On 8:Off
[08:44:34][D][actron485.climate:027]: 02 14 80 05 24 86 48 27 72 86 8F B5 46 92 55 94 41 07 AC 0D 40 28 FF 2E 24 03 BA 24 01 58 7D 0B 95 8C 8E 51 08 10 51 3B 95 05 55 BB 51 62 05 A6 FE 78 0A 1C 80 28 20 E1
[08:44:35][D][actron485.climate:027]: 3D 48 85 4A 60 FF 7B 92 C9 4C 0B 19 20 3C 88 3C 08 2A E2 FA 69 34 08 05 CF D1 51 15 15 1C 6C 78 31 88 16 EB 83 41 51 F4 34 2A B9 60 30 47 00 98 8B 49 66 92 B8 00 07 51 05 05 44 66 24 05 09 CC
[08:44:35][D][actron485.climate:027]: 9F 90 81 35 F0 09 81 08 05 7D 21 50 6F 5B 49 28 25 8E 1E C8 05 A6 99 FF 48 07 54 05 92 82 04 00 01 C2 52 43 F2 45 10 A2 F3 21 28 C8 58 3C 82 05 24 11 0D 00 05 44 07 2A
[08:44:35][D][actron485.climate:027]: Unknown Message received
[08:44:35][D][actron485.climate:027]: 11 05 4E 8D 02 4A FF C1 57 A8 EF 40 12 22 75 4C 91 40 4C 92 1D 8C 02 A2 1C D0 51 88 84 2F 35 50 C0 43 0F CE 8A 09 82 8C 1A 28 A1 95 DA 30 A0 29 75 05 E8 50 B0 10 1C 08 41 41 00 E4 96 04 49 44
[08:44:35][D][actron485.climate:027]: FC 3A D3 08 0A 49 04 E4 CB FC 62 E0 00 28 05 CF 3C 28 01 16 60 05 38 85 26 12 05 48 32 5A 59 7F 82 45 AC 24 46 D9 88 1C 25 C6 EA 81 30 F0 39 03 09 05 38 32 03 01 12 1F
[08:44:35][D][actron485.climate:027]: M: Zone: 7, Set Point: 9.00, Temp: 0.30, SP Range: 31.50-17.50, Zone: On, Compr. Mode: Off, Compr. Active, Damper Pos: 0%
[08:44:35][D][actron485.climate:027]: A7 03 40 FF 12 E3 57 75 AC D1 02 72 A7 76 25 40 01 C1 91 09 C8 45 84 17 02 0A 49 00 8B 50 25 48 AC 74 8C 84 3E A2 11 42 29 45 CE C5 A1 55 18 29 1B AA 05 51 74 7D 05 15 41 0F 13 54 44 23 6B 04
[08:44:35][D][actron485.climate:027]: 3A A5 4E 81 2B F4 20 70 90 19 51 CC 68 7C 24 71 50 57 FF FF 97 E3 4C 13 B9 C0 48 C3 18 07 58 12 00 B3 28 05 18 92 42 13 D4 00 80 E7 38 40 A1 81 A7 FF 00 05 4C 32 E3 8F
[08:44:36][D][actron485.climate:027]: 44 15 20 82 4A 94 FE 1C 00 41 32 F0 00 12 54 61 51 02 32 8A 62 62 10 2E 57 2E 88 10 6D 60 91 49 05 25 05 09 67 52 7C 75 50 64 00 56 E5 0C 2A 01 8A 8A 84 05 72 D1 21 50 55 20 00 4E 04 05 00 8A
[08:44:36][D][actron485.climate:027]: Unknown Message received
[08:44:36][D][actron485.climate:027]: 1F 54 55 C0 AE 3B 91 12 C3 4A 02 04 1B B5 38 64 29 E8 26 07 08 51 FB BF 12 78 8C 01 B8 92 F3 20 20 03 98 12 F9 18 00 A6 A0 0D 44 A8 1B 0B 11 10 10 78 99 01 78 46 03 B8
[08:44:36][D][actron485.climate:027]: 24 88 6D 8F DC DB 45 A8 28 14 85 4A 28 42 5C 01 78 0E AE 6E 18 28 01 A8 69 1E 08 12 28 08 4A 02 90 C5 94 40 13 10 37 F4 80 80 1C 13 A4 05 05 5D AC 95 29 55 58 10 01 42 88 8A 85 A8 A4 8A 10 01
[08:44:36][D][actron485.climate:027]: State 2: Operating Mode: Off-Off - Idle, Fan Mode: Low - Active, Setpoint: 121.50, Temperature: 1746.80, Zones: 1:Off 2:Off 3:On 4:Off 5:Off 6:Off 7:Off 8:On
[08:44:36][D][actron485.climate:027]: 02 28 01 00 F3 20 84 4F DD 44 3C E8 53 27 22 38 CA 60 30 90 E3 A8 01 5E 20 07 A8 3B 9E 48 03 18 45 0D 4E 07 0E E3 48 82 40 18 6A 84 D2 86 2A 9F 30 E0 F0 6D 91 B1 A0 07
[08:44:36][D][actron485.climate:027]: 2C 24 04 6B FC 97 F1 0F 6B 60 DD 58 08 22 1E 01 25 00 18 14 20 72 D0 05 E1 E4 B3 2A 15 F8 D6 54 04 F9 03 71 02 97 92 70 02 40 03 C7 54 15 90 08 60 08 82 A9 03 19 1F 65 0A 46 98 33 8A 64 FB 23
[08:44:36][D][actron485.climate:027]: 24 43 93 88 A6 19 33 A0 C6 1D 8F 61 4A 8F 23 54 49 C5 0A 42 49 55 1A A5 06 00 A2 E0 31 13 A4 48 09 94 0A 09 15 0D 19 06 42 8A A1 25 10 49 19 08 00 92 22 CC B9 56 BD 74
[08:44:36][D][actron485.climate:027]: State 2: Operating Mode: - Unknown, Fan Mode: Low Continuous - Active, Setpoint: 74.50, Temperature: 1246.50, Zones: 1:Off 2:Off 3:On 4:Off 5:Off 6:Off 7:Off 8:Off
[08:44:36][D][actron485.climate:027]: 02 D5 BC 70 95 C6 04 05 6B 30 B1 60 94 44 80 C4 8D 04 2A 20 9A 64 45 F0 4A 03 D9 92 49 89 6A 83 CF 80 82 8C 27 5A 18 24 49 1C 87 11 09 41 AA 24 85 14 93 9D 61 20 10 1A 6A 65 14 55 20 56 1A 81
[08:44:36][D][actron485.climate:027]: 30 02 39 00 42 02 E2 D3 41 54 14 4F E1 44 4A A2 C7 12 85 68 4A 6D C0 48 0F FA 00 38 22 D7 39 C5 8E 51 07 20 42 4A 02 CA 4E 05 2C 2A FF B0 8D E8 4C 75 C0 08 A0 40 1D 40
[08:44:37][D][actron485.climate:027]: Unknown Message received
[08:44:37][D][actron485.climate:027]: 40 8A 6D 7E 26 D2 B2 BB 1C 30 54 19 02 A2 85 2C 10 55 80 00 12 F8 B0 98 20 00 24 C2 40 40 7C F6 94 19 02 61 F8 20 CC 30 C3 A4 45 54 20 84 12 92 C6 08 60 0D 8C 23 04 51 13 20 18 44 F8 0D 94 01
[08:44:37][D][actron485.climate:027]: M: Zone: 5, Set Point: 2.50, Temp: 19.50, SP Range: 8.00-0.00, Zone: On, Compr. Mode: On Cooling, Damper Pos: 0%, ??Adjusting??
[08:44:37][D][actron485.climate:027]: B5 C3 C2 10 45 40 14 B2 05 40 42 0D 00 30 29 16 8F FB 99 31 0E C4 07 80 07 24 05 50 05 88 13 DC 40 48 E4 CE 45 10 89 DA 6D C0 08 B0 02 0C 05 5D C9 8D 80 82 81 80 82 07
[08:44:37][D][actron485.climate:027]: AC 09 1F 25 27 63 56 45 FE FA 46 20 29 00 2C 68 35 AC 32 72 E4 48 64 4D 34 53 55 9C 56 53 28 AA 17 96 29 41 A2 40 E5 35 08 00 9A CC 42 52 49 86 4D 51 A1 C9 D6 E5 42 95 28 F8 00 A8 20 E2 2C 79
[08:44:37][D][actron485.climate:027]: M: Zone: 8, Set Point: 3.50, Temp: 26.40, SP Range: 25.50-25.00, Zone: Off, Damper Pos: 20%
[08:44:37][D][actron485.climate:027]: 88 08 25 B3 47 B2 A8 AC 97 45 88 00 4F 11 55 85 92 AD 79 48 05 0C 22 DA F0 40 92 05 48 07 A8 7B 2C 20 91 28 69 84 97 41 49 29 15 D5 0C 5E DE 01 AE 5A 05 90 60 30 32 03
[08:44:37][D][actron485.climate:027]: AC 26 B1 B2 4E 66 A7 1E 74 A0 31 82 00 F3 21 12 A6 A4 02 F9 7D 13 44 92 D4 36 94 94 B3 50 81 40 15 61 4B F4 8C 02 54 4B 85 49 05 EC 65 A8 15 94 A8 4D 08 F9 02 15 5B A2 55 C4 75 41 9A 1A A6 E2
[08:44:37][D][actron485.climate:027]: F0 21 A6 C8 56 4D 00 40 C0 E1 93 92 E2 48 A3 49 FF A0 03 58 ED 80 A4 83 58 20 FF 18 12 7F 52 12 0B C8 8F 51 88 45 37 A7 05 A5 6C E3 4B B9 A4 22 05 00 A0 59 8B 20 90 05
[08:44:38][D][actron485.climate:027]: Unknown Message received
[08:44:38][D][actron485.climate:027]: 18 40 7B 70 41 6F E3 03 92 E3 20 92 08 A1 54 03 80 98 61 41 3A 52 08 A8 6D 2B 02 42 08 AB 18 13 84 03 C0 18 29 24 54 41 09 85 86 91 A5 A1 15 FB 94 81 A8 60 80 ED 98 A9 08 6C 66 84 60 5D FC 23
[08:44:38][D][actron485.climate:027]: C: Zone: 3, Set Point: 73.00, Temp: 88.10(Pre:71.10), Mode: Off
[08:44:38][D][actron485.climate:027]: D3 92 44 33 46 54 24 46 C7 99 84 58 E1 48 92 2B 38 92 E3 B8 05 B8 92 62 70 20 03 98 12 23 B0 12 45 6E 09 88 1F 98 CD 94 42 69 96 C0 0C 2C 3B 48 03 1C 12 63 70 20 22 03
[08:44:38][D][actron485.climate:027]: 07 12 E2 44 E3 A7 78 0F D0 14 90 99 12 01 01 5D 0F 00 44 62 83 14 09 C1 09 E8 A0 19 24 58 AC 04 09 06 08 92 CC 10 C0 6A 68 55 00 A5 A8 A0 00 70 12 58 31 32 C6 AA D5 4E 28 A5 0F 41 14 41 28 00
[08:44:38][D][actron485.climate:027]: 9D 55 93 09 76 E1 91 46 A8 CC 82 4A 02 B4 A6 22 63 06 50 70 E8 07 80 29 1C 22 03 22 82 07 58 C4 0E 48 18 20 82 03 98 92 E5 2C 99 71 56 AC 14 90 15 C7 02 E0 80 F1 08 D8
[08:44:38][D][actron485.climate:027]: State: Operating Mode: - Heating, Fan Mode: ESP - Active, Setpoint: 7.50, Temperature: 4114.60, Zones: 1:On 2:On 3:Off 4:Off 5:Off 6:On 7:On 8:Off
[08:44:38][D][actron485.climate:027]: A0 29 05 1B C5 93 E0 C9 0C 08 48 63 70 28 0F 34 A0 BA 01 42 92 25 6D 27 14 09 94 11 15 21 15 58 40 01 2C A0 50 24 26 05 0C 01 00 51 C8 46 D2 14 40 52 82 05 54 A0 CA 00 44 49 22 A0 54 46 02 F0
[08:44:38][D][actron485.climate:027]: 75 1E 83 00 B6 67 21 9C 00 11 85 89 61 A3 1F 25 28 4A 18 C9 12 07 18 03 41 82 03 08 55 3F 10 7F 50 12 03 3C 83 80 48 33 96 94 47 84 07 72 95 21 95 44 5A F1 0D D4 07 48
[08:44:38][D][actron485.climate:027]: 05 D1 FE 54 12 C1 F1 55 B1 08 20 0D B0 7F 24 20 C6 07 A4 22 0A BC 0B 02 D0 53 05 02 0A 45 58 36 4F C2 50 58 C0 50 95 80 DE 53 24 11 C4 60 10 C5 A2 15 A6 00 A4 15 35 5C 1C 52 15 09 B5 1E 64 20
[08:44:39][D][actron485.climate:027]: 65 16 63 8B 09 8C CB EB 24 93 63 68 04 55 B3 59 95 D5 8C A6 33 13 07 21 32 1D 28 92 6D FF B0 FB 10 92 07 5A 0D 7E 08 05 5A 00 08 C4 64 81 A8 62 44 C0 81 44 84 C0 44 13
[08:44:39][D][actron485.climate:027]: C: Zone: 2, Temp Offset: -12.80
[08:44:39][D][actron485.climate:027]: C2 D5 E6 80 87 0A 88 80 E3 0D A9 67 EF 84 88 84 8E 2A AD 35 51 21 89 D4 51 89 A8 02 D4 80 91 02 09 55 45 48 22 06 5A 62 00 D1 2C 07 6D 00 DA 50 8C 24 A3 15 AB 1D AA 05 4D 44 11 A1 25 93 FE 04
[08:44:39][D][actron485.climate:027]: Unknown Message received
[08:44:39][D][actron485.climate:027]: 24 42 09 E1 A4 50 62 65 27 A9 A5 30 C0 29 6B 68 21 81 51 56 C9 48 F0 B5 82 FF 65 F8 AF 00 00 28 03 B8 49 E5 48 48 15 7D 85 85 68 82 91 F9 80 08 25 04 A5 50 3E 40 20 02
[08:44:39][D][actron485.climate:153]: Has Changed, Publishing State
[08:44:39][D][climate:396]: 'Actron Climate Controller' - Sending state:
[08:44:39][D][climate:399]: Mode: OFF
[08:44:39][D][climate:401]: Action: OFF
[08:44:39][D][climate:404]: Fan Mode: AUTO
[08:44:39][D][climate:413]: Custom Preset: Continuous Fan
[08:44:39][D][climate:419]: Current Temperature: 4114.60°C
[08:44:39][D][climate:425]: Target Temperature: 7.50°C
[08:44:39][D][actron485.climate:023]: Zone Fan Changed, Publishing State
[08:44:39][D][fan:120]: 'Living' - Sending state:
[08:44:39][D][fan:121]: State: ON
[08:44:39][D][fan:120]: 'Theatre' - Sending state:
[08:44:39][D][fan:120]: 'Master Bedroom' - Sending state:
[08:44:39][D][fan:121]: State: OFF
[08:44:39][D][fan:120]: 'Bedroomss' - Sending state:
[08:44:39][W][component:214]: Component actron485.climate took a long time for an operation (0.11 s).
[08:44:39][W][component:215]: Components should block for at most 20-30ms.
[08:44:39][D][actron485.climate:027]: 64 CC 65 E0 03 96 00 92 32 44 9D B5 22 C1 E8 53 83 8E 38 85 BC 16 80 01 99 0A A1 29 85 9B 46 42 44 84 C1 22 24 0A 84 8A 48 38 D0 39 0E 25 80 D2 75 F2 85 01 95 80 40 12 55 88 94 1B 05 55 61 15
[08:44:39][D][actron485.climate:027]: A9 99 E2 30 82 14 01 39 E4 06 00 24 60 ED 3F E1 BE 49 1C 80 48 08 48 18 98 0A 08 8A FE 28 15 85 D2 39 41 05 0C 89 1D 80 20 65 B6 85 03 90 92 15 97 31 10 A5 5D 08 56 44
[08:44:39][D][actron485.climate:027]: 00 B1 CC 69 49 DC 80 E4 2D C0 83 D7 66 78 00 C3 02 8F 30 80 01 5A C3 00 BB 28 E8 3F 0A 10 01 03 47 81 48 00 31 13 46 44 EB 79 19 34 C1 24 EC 82 04 23 22 94 18 11 00 B8 18 31 1C A0 D0 93 10 02
[08:44:39][D][actron485.climate:027]: 05 F5 46 82 29 85 4C 04 58 C2 C1 B6 13 44 25 65 62 52 88 07 E0 77 0A A9 81 C9 14 08 05 80 E1 11 85 C0 9D C1 26 40 51 86 90 19 13 E6 B2 00 84 15 D3 94 04 A5 8D 1A C0 40
[08:44:40][D][actron485.climate:027]: Unknown Message received
[08:44:40][D][actron485.climate:027]: 62 68 14 F5 A0 20 20 3E D4 40 02 E4 ED 3E 21 07 13 50 04 05 10 0A 30 1F C2 44 B1 C5 46 5B 71 0A 39 18 28 19 A6 D0 93 57 20 82 80 D3 52 03 30 09 08 15 20 7D 50 55 02 5A 55 45 36 BB 55 88 88 88
[08:44:40][D][actron485.climate:027]: 20 84 88 02 08 E9 4C 55 3D F2 58 F9 21 24 01 04 C0 E4 5B A1 91 00 10 48 47 A8 55 2D 41 0D FF 62 88 80 51 00 10 05 98 12 BE 1C 4A C1 00 95 A0 0C 00 28 6F 9E C2 7F 19 4E
[08:44:40][D][actron485.climate:027]: 8C 7D 05 49 90 01 B5 09 70 33 81 F8 0C 10 5D C4 05 04 A0 92 E8 88 02 44 2A 49 3B 4D 28 19 AA C0 24 1A 27 42 28 CC 5C 85 08 34 30 F0 8E A4 05 31 F4 11 95 54 22 10 55 05 00 B7 00 55 08 C4 34 82
[08:44:40][D][actron485.climate:027]: AA 48 A8 8F 90 96 36 9F 80 55 AA BD 65 0C 81 30 B8 38 57 07 2C 19 86 69 0A C8 54 B3 07 29 0A 66 AE 33 12 00 10 AF 0C C2 17 08 99 0D 00 41 07 50 85 90 92 65 00 2B 68 50
[08:44:40][D][actron485.climate:153]: Has Changed, Publishing State
[08:44:40][D][climate:396]: 'Actron Climate Controller' - Sending state:
[08:44:40][D][climate:399]: Mode: OFF
[08:44:40][D][climate:401]: Action: OFF
[08:44:40][D][climate:404]: Fan Mode: AUTO
[08:44:40][D][climate:413]: Custom Preset: Standard Fan
[08:44:40][D][climate:419]: Current Temperature: 4114.60°C
[08:44:40][D][climate:425]: Target Temperature: 7.50°C
[08:44:40][D][actron485.climate:027]: 46 21 3A 0C FC 3F 48 92 69 4F C2 00 A0 71 38 B0 E5 85 00 A3 AD E0 11 12 52 B4 49 F2 92 82 10 F1 83 0A 0A F8 A3 11 32 12 CC 31 85 A9 14 A8 0D 43 82 12 A5 28 12 09 0C 8A 14 02 40 EA 9C 48 3A E0
[08:44:40][D][actron485.climate:027]: M: Zone: 2, Set Point: 20.50, Temp: 12.50, SP Range: 18.00-26.00, Zone: Off, Damper Pos: 100%
[08:44:40][D][actron485.climate:027]: 82 7D 94 24 A9 34 03 42 12 EC 48 C2 10 61 01 58 4A 41 10 83 71 64 48 E3 64 CF 80 80 21 D6 F1 60 C9 66 2C A5 29 A4 0C A8 95 09 C5 C0 14 25 55 C0 80 CA 80 11 42 29 31 14
[08:44:40][D][actron485.climate:027]: 26 30 0D EC 82 20 35 86 41 57 C7 C9 C9 D0 71 03 93 60 81 9A 15 40 B9 B8 41 80 E0 08 B4 89 2A 11 F2 D5 04 42 21 16 F0 08 01 28 01 A2 84 3B 01 84 24 0C 22 42 98 08 18 55 15 35 94 50 05 D2 01 09
[08:44:40][D][actron485.climate:027]: M: Zone: 5, Set Point: 6.00, Temp: 8.50, SP Range: 6.50-17.00, Zone: On, Compr. Mode: On Cooling, Compr. Active, Damper Pos: 0%
[08:44:40][D][actron485.climate:027]: A5 55 E0 0D 0C A2 05 E0 C3 FB 50 72 18 10 8A 15 65 E0 8D 50 48 C8 FC 08 20 45 24 89 1D 00 21 72 95 FB 2A 8A 60 40 48 04 20 51 6F 31 0A 01 02 BD 52 55 20 0D D5 22 05 0B
LOGS 15-03-2024
AirCon running - cooling, setpoint 20, living room on, fan speed low 2024_03_15
INFO Successfully connected to actron-ac-esphome @ 192.168.1.26 in 0.050s
INFO Successful handshake with actron-ac-esphome @ 192.168.1.26 in 0.159s
[08:48:02][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 15 2024, 07:57:59
[08:48:02][C][wifi:577]: WiFi:
[08:48:02][C][wifi:409]: Local MAC: [redacted]
[08:48:02][C][wifi:414]: SSID: '[redacted]'[redacted]
[08:48:02][C][wifi:415]: IP Address: [redacted]
[08:48:02][C][wifi:417]: BSSID: [redacted][redacted]
[08:48:02][C][wifi:418]: Hostname: 'actron-ac-esphome'
[08:48:02][C][wifi:420]: Signal strength: -57 dB ââââ
[08:48:02][C][wifi:424]: Channel: 11
[08:48:02][C][wifi:425]: Subnet: 255.255.255.0
[08:48:02][C][wifi:426]: Gateway: [redacted]
[08:48:02][C][wifi:427]: DNS1: [redacted]
[08:48:02][C][wifi:428]: DNS2: 0.0.0.0
[08:48:02][C][logger:447]: Logger:
[08:48:02][C][logger:448]: Level: DEBUG
[08:48:02][C][logger:449]: Log Baud Rate: 115200
[08:48:02][C][logger:451]: Hardware UART: UART0
[08:48:02][D][actron485.climate:027]: Unknown Message received
[08:48:02][D][actron485.climate:027]: 04 61 E3 02 1D 24 81 2E 01 00 A6 A4 41 01 D6 90 4A 42 23 80 0D 6A 32 00 82 26 0D C0 08 59 9E C0 06 80 66 92 4B 52 AA 06 1C 81 A9 C5 E0 00 1D 43 C5 03 40 05 28 88 3D C9 66 25 55 AB 54 80 CA B0
[08:48:02][D][actron485.climate:027]: 21 14 4A 12 89 9E 99 42 06 25 CB 4B 2A 09 F8 8B 21 A9 31 11 2C A4 52 E2 E5 15 24 05 BC 12 20 8A 8E FF 0A 87 4C 88 02 00 22 A0 AB 71 02 E0 31 02 83 00 20 2C A3 46 44 08
[08:48:02][C][uart.arduino_esp32:137]: UART Bus 1:
[08:48:02][C][uart.arduino_esp32:138]: TX Pin: GPIO26
[08:48:02][C][uart.arduino_esp32:139]: RX Pin: GPIO27
[08:48:02][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[08:48:02][C][uart.arduino_esp32:143]: Baud Rate: 4800 baud
[08:48:02][C][uart.arduino_esp32:144]: Data Bits: 8
[08:48:02][C][uart.arduino_esp32:145]: Parity: NONE
[08:48:02][C][uart.arduino_esp32:146]: Stop bits: 1
[08:48:02][C][actron485.climate:226]: Actron485 Status:
[08:48:02][C][actron485.climate:227]: Receiving Data: YES
[08:48:02][C][actron485.climate:571]: ClimateTraits:
[08:48:02][C][actron485.climate:572]: [x] Visual settings:
[08:48:02][C][actron485.climate:573]: - Min temperature: 16.0
[08:48:02][C][actron485.climate:574]: - Max temperature: 30.0
[08:48:02][C][actron485.climate:575]: - Temperature step:
[08:48:02][C][actron485.climate:576]: Target: 0.5
[08:48:02][C][actron485.climate:577]: Current: 0.1
[08:48:02][C][actron485.climate:578]: - Min humidity: 30
[08:48:02][C][actron485.climate:579]: - Max humidity: 99
[08:48:02][C][actron485.climate:581]: [x] Supports current temperature
[08:48:02][C][actron485.climate:593]: [x] Supports action
[08:48:02][C][actron485.climate:596]: [x] Supported modes:
[08:48:02][C][actron485.climate:598]: - OFF
[08:48:02][C][actron485.climate:598]: - COOL
[08:48:02][C][actron485.climate:598]: - HEAT
[08:48:02][C][actron485.climate:598]: - FAN_ONLY
[08:48:02][C][actron485.climate:598]: - AUTO
[08:48:02][C][actron485.climate:601]: [x] Supported fan modes:
[08:48:02][C][actron485.climate:603]: - AUTO
[08:48:02][C][actron485.climate:603]: - LOW
[08:48:02][C][actron485.climate:603]: - MEDIUM
[08:48:02][C][actron485.climate:603]: - HIGH
[08:48:02][C][actron485.climate:616]: [x] Supported custom presets:
[08:48:02][C][actron485.climate:618]: - Continuous Fan
[08:48:02][C][actron485.climate:618]: - Standard Fan
[08:48:02][D][actron485.climate:027]: M: Zone: 4, Set Point: 5.00, Temp: 28.60, SP Range: 12.50-10.50, Zone: On, Compr. Mode: Off, Compr. Active, Damper Pos: 80%
[08:48:02][D][actron485.climate:027]: 84 1E 71 D9 0A D5 65 23 5A 12 12 20 23 45 81 97 4A 57 20 C6 D5 22 00 54 A8 D6 80 93 25 D3 FA 13 04 80 7D 44 64 02 17 20 1B 8A 1A C8 82 42 A9 25 81 FC A8 E3 02 D0 43 49 31 12 9E 04 C2 06 94 97
[08:48:02][C][captive_portal:088]: Captive Portal:
[08:48:02][D][actron485.climate:027]: 61 30 00 51 20 91 08 00 21 1E B1 82 41 BD EA 71 8C 90 33 AC 41 99 49 94 85 38 09 1E E1 07 20 08 42 D9 86 40 89 82 C5 18 2C 90 E1 1A 11 2A 18 00 87 4E 81 21 A6 61 11 CD
[08:48:02][C][mdns:115]: mDNS:
[08:48:02][C][mdns:116]: Hostname: actron-ac-esphome
[08:48:02][C][ota:096]: Over-The-Air Updates:
[08:48:02][C][ota:097]: Address: actron-ac-esphome.local:3232
[08:48:02][C][ota:103]: OTA version: 2.
[08:48:02][C][api:139]: API Server:
[08:48:02][C][api:140]: Address: actron-ac-esphome.local:6053
[08:48:02][C][api:142]: Using noise encryption: YES
[08:48:02][D][actron485.climate:027]: E0 6F 79 44 22 A2 44 25 0A 01 39 7D 18 1A 8C 11 70 BC 11 93 A1 8A 1B 64 80 84 8C 41 9C 39 90 40 FF 42 12 00 4A 10 0D 13 C3 17 23 80 08 8C 3A 2F 28 54 95 0D 72 38 06 84 09 0A 16 E0 4D 24 54 99
[08:48:02][D][actron485.climate:027]: FC 26 53 51 DA C6 49 9B A1 9C 21 23 0F 0A 4C 3B 50 29 09 E9 A5 64 04 B5 1B 24 C9 80 99 10 9E 49 F3 68 54 84 4A 10 B5 4E 14 06 08 4F 01 F3 0A DD 91 F5 53 49 7C 15 40 A0
[08:48:02][D][actron485.climate:027]: E0 56 11 18 00 50 88 01 40 4A 92 C2 6D 41 08 20 AF 80 25 42 6A B3 31 12 16 25 91 21 41 88 80 08 8C 21 02 90 63 20 39 16 BE 54 09 B0 00 D4 99 49 15 C3 28 54 41 68 60 00 60 52 18 14 48 40 25 C0
[08:48:02][D][actron485.climate:027]: C: Zone: 8, Temp Offset: -8.80
[08:48:02][D][actron485.climate:027]: C8 64 B0 A8 B8 57 30 54 55 6F 1A 63 40 08 1C CA 41 E1 7C 31 B8 41 21 D2 19 49 DF 00 0A D9 30 20 49 07 01 59 00 A0 4A 2C C8 A9 B5 22 8D 30 28 01 EC 85 00 20 3C 7E 0A 04
[08:48:03][D][actron485.climate:027]: Unknown Message received
[08:48:03][D][actron485.climate:027]: 12 1D 21 25 80 43 59 3F 60 01 9C 42 85 EC 09 20 8A AF 2B 0A 24 40 DC 46 42 2A 09 B0 06 B8 88 0F B2 94 48 D3 38 05 00 88 30 DC 22 F2 A1 42 80 CB 80 29 45 47 65 14 85 88 A9 C9 20 80 02 57 AC 20
[08:48:03][D][actron485.climate:027]: 15 40 D0 5D B0 0A C3 51 01 11 0A 40 25 2E 4A 24 00 2D 2C 2A 4A 02 55 40 15 22 23 5A D4 0A 0D F0 93 AD 32 32 46 47 D4 22 3F FF 75 FF FF A7 E3 48 12 54 F7 1C 94 6D 20 0D
[08:48:03][D][actron485.climate:027]: FA 01 32 46 29 05 08 92 B4 23 A4 01 21 41 38 52 9C 22 FA 16 60 E2 94 30 45 6D 50 31 88 23 4A E8 A9 63 FE 45 24 2C C5 B7 20 90 8A E1 09 18 48 5C C5 A8 10 62 70 A8 2C 48 E2 65 4C 50 52 C4 03 6E
[08:48:03][D][actron485.climate:027]: 28 04 85 14 40 0E 4A 19 B1 18 24 01 26 61 12 E3 60 8A 1C F0 55 E4 C6 21 F4 ED D0 95 94 3F 88 4A 0D A0 0D F4 15 A8 91 C0 30 D5 25 1C 70 74 01 80 05 88 F3 81 48 0C 43 45
[08:48:03][D][actron485.climate:027]: 49 2B 8E 1A 4A 63 65 7F 28 11 01 1C 21 82 ED 75 80 04 0A 68 10 8F 61 40 D8 66 90 60 00 34 17 76 AA A5 48 06 12 4E 40 46 41 00 A1 B3 10 40 A2 0A BC 0D 81 EA A6 24 9E 28 4A 06 22 98 0E 10 48 09
[08:48:03][D][actron485.climate:027]: State 2: Operating Mode: Off-Off - Unknown, Fan Mode: High - Active, Setpoint: 3.00, Temperature: 478.40, Zones: 1:Off 2:Off 3:Off 4:On 5:On 6:Off 7:On 8:Off
[08:48:03][D][actron485.climate:027]: 02 6B 99 60 06 1A 58 41 14 12 B0 7B 9E 42 92 04 4D A8 75 74 55 D5 FD AC 4A FC 8E 01 89 FC 00 84 E4 47 A9 14 70 50 90 F8 1E 95 40 85 0E 4B E3 22 46 3B FF 12 92 8C 79 86
[08:48:04][D][actron485.climate:027]: Unknown Message received
[08:48:04][D][actron485.climate:027]: 13 1D 00 5D 30 05 AC 46 F5 40 00 3B 3A 16 24 00 52 02 1E 04 80 00 9B 11 C6 98 22 C0 0C AA 00 E1 02 88 D0 33 28 C8 92 11 02 26 B2 40 48 81 A9 A4 48 A8 D6 24 27 15 28 B0 B1 44 09 8A FD 9C 41 45
[08:48:04][D][actron485.climate:027]: 20 54 AC 54 52 A2 7B 07 04 02 C8 B0 0D 43 07 B0 95 04 49 0C CC F7 24 38 20 06 E3 E0 40 05 16 B1 74 82 F9 0E 55 32 F8 70 20 41 0F 01 F9 80 20 92 00 FD 55 9D EC 20 1E 54
[08:48:04][D][actron485.climate:027]: 30 8A 94 3E 78 60 FB 98 92 D6 28 78 EC A4 D0 F0 E1 3B 16 91 4C 5C F9 21 49 54 43 E8 64 49 45 26 02 8D 93 C5 0A 93 0A 84 1B 23 2C 94 83 03 3E 02 42 5C 40 87 55 21 AC 28 80 00 A5 00 DD 54 95 22
[08:48:04][D][actron485.climate:027]: D0 A9 84 60 09 56 9D 49 84 79 1D FF C4 18 80 FD 6C 48 01 34 95 92 E4 C0 04 D2 64 43 10 C1 8C E3 92 32 C4 55 58 D1 E1 10 02 22 84 89 9E 7C A9 02 30 04 92 F0 90 28 83 CF
[08:48:04][D][actron485.climate:027]: M: Zone: 4, Set Point: 26.00, Temp: 0.00, SP Range: 20.00-1.00, Zone: Off, Damper Pos: 40%
[08:48:04][D][actron485.climate:027]: 94 00 A8 28 B4 02 DF 4C 32 89 50 76 84 1C 69 A0 08 2A 10 C0 40 C4 80 21 25 4B 31 15 AC C6 18 11 C9 11 D0 46 A4 22 C1 B4 ED 48 02 66 A8 CC 05 05 38 0D 40 A2 52 1E 3E 50 01 00 3A AA 44 A0 08 98
[08:48:04][D][actron485.climate:027]: M: Zone: 8, Set Point: 1.00, Temp: 3.20, SP Range: 2.00-1.50, Zone: Off, Damper Pos: 20%
[08:48:04][D][actron485.climate:027]: 88 20 04 04 C2 43 7C 0A 63 55 C3 22 2A 42 65 48 03 80 20 83 7C 01 FF 90 20 03 90 08 0B 5C 00 90 0F CC 98 0F 60 88 BE 58 05 05 F0 39 01 20 28 91 FE 1E 41 12 ED 00 01 A4
[08:48:04][D][actron485.climate:027]: M: Zone: 2, Set Point: 29.50, Temp: 2.00, SP Range: 10.00-24.50, Zone: On, Compr. Mode: On Heating, Fan Mode, Damper Pos: 80%
[08:48:04][D][actron485.climate:027]: 92 14 F0 94 FB 31 06 78 90 92 93 4C 91 52 61 32 70 88 08 83 CC 35 02 07 64 3F 40 BC 50 45 A4 48 90 29 B8 89 11 76 19 D8 63 55 05 00 5B 9D 31 22 0C 17 41 3C 40 A9 42 19 93 25 70 50 09 55 10 02
[08:48:04][D][actron485.climate:027]: 49 CD 36 08 90 35 55 A2 08 22 F9 F0 10 52 F8 07 20 29 34 54 B1 09 55 D2 FD 55 05 40 4A 50 3F 88 28 15 F0 42 9D FC 55 C0 03 36 21 AA 95 00 10 73 AA C1 0C 92 22 87 F3 03
[08:48:05][D][actron485.climate:027]: C9 40 F8 00 20 51 90 47 92 F9 58 12 28 F9 0C 52 08 73 5E 0A 09 04 D0 9F 10 0D 44 49 29 49 43 23 51 E3 0A 28 B2 06 00 28 FA 70 00 06 51 18 C0 22 C2 10 81 C1 EB 28 2D 42 02 14 0D 82 08 72 00 E5
[08:48:05][D][actron485.climate:027]: Unknown Message received
[08:48:05][D][actron485.climate:027]: 28 40 38 62 F2 0A C8 62 05 4A 24 00 FC AB 09 29 0E 61 60 1A 10 DD 38 83 8A 18 18 0A 84 86 07 10 92 59 0D 41 59 80 20 92 1C FE 45 7B 12 25 1D F6 A9 12 F6 D8 52 31 28 A1
[08:48:05][D][actron485.climate:027]: 10 E1 40 0C 8A 00 00 1A 11 C3 03 58 04 48 33 9D 80 28 40 13 36 90 5A B2 A3 D6 10 01 01 D9 08 04 44 71 81 CC A9 00 0F 6A 44 21 00 BF B4 94 C2 A6 24 0F 21 22 52 9C 31 04 2A 04 50 64 2A 41 99 48
[08:48:05][D][actron485.climate:027]: M: Zone: 2, Set Point: 25.50, Temp: 9.00, SP Range: 25.50-1.00, Zone: On, Compr. Mode: Off, Fan Mode, Damper Pos: 0%
[08:48:05][D][actron485.climate:027]: A2 5A 40 73 F3 C2 FC 4C 66 A5 05 90 92 D0 F7 0C 94 0D E0 09 1D 4E 00 80 03 52 01 09 94 98 9D 21 55 05 86 5D 71 7F 98 48 0D 60 15 D0 CF 2C 84 1C 30 45 D3 40 4A 0C 4F 01
[08:48:05][D][actron485.climate:027]: C9 EC 40 41 54 41 11 08 E7 04 6D 78 25 83 05 AE 3B 02 26 28 A1 A1 6E 1D 77 64 AA 24 48 2D D0 84 40 E0 8C 55 94 F9 0C 60 52 B1 08 92 FE 35 1A C0 6C 9A 66 67 48 1B FA E1 89 34 75 17 20 11 88 D5
[08:48:05][D][actron485.climate:027]: 15 28 12 6A 84 25 14 08 3C 08 2A 15 E8 9C 22 50 00 08 1C 86 55 94 C2 B6 87 84 C4 B3 F9 00 00 FA 01 48 73 44 2A 13 52 31 8E 14 11 B1 0A 24 92 62 77 FE 82 1D 00 90 08 F8
[08:48:06][D][actron485.climate:027]: Unknown Message received
[08:48:06][D][actron485.climate:027]: 2C 84 02 D0 C0 C2 01 0F 1D 9A 95 00 3F F0 54 0E E9 04 00 3A 60 02 98 22 7C B0 8C 21 80 5C C9 12 49 A8 1F 6A 72 04 3E B0 69 1E 12 40 CC FF 54 51 95 D4 21 75 42 88 0B 34 01 95 20 58 88 40 48 04
[08:48:06][D][actron485.climate:027]: 01 02 81 5A 4D A8 24 14 B2 8D 55 E0 00 4C 62 86 FE 9F F8 30 08 79 30 45 79 80 28 9A FA 55 87 20 90 00 F5 95 F9 06 94 76 42 BD 86 38 3D 35 4A 0C 30 F5 0A 1F 3F CA 7C 82
[08:48:06][D][actron485.climate:027]: 11 DC AF 07 40 14 1B 61 C8 91 0A F2 06 10 32 9D 68 14 18 F2 AF 4F 49 A1 25 9C 38 D0 1D 0C 96 92 20 06 26 54 40 25 B0 89 87 D1 2B 01 5C 35 14 81 24 40 60 54 A8 A6 54 DD 81 2A 4C 34 02 52 42 75
[08:48:06][D][actron485.climate:027]: 53 7F 84 24 73 0A 21 92 C6 0F FE 4A 22 01 68 E6 66 A8 86 31 21 50 45 68 A7 4E 03 40 28 A4 F8 1E 41 83 00 42 03 00 21 E6 0E A9 03 40 C8 BD 90 28 06 00 53 DE 68 C8 DA C1
[08:48:06][D][actron485.climate:027]: 54 92 99 82 00 4C 02 D8 E3 57 4B 00 96 80 45 49 56 93 88 90 01 85 BD 54 28 A2 15 F5 21 A1 19 21 60 08 C3 86 14 34 12 40 59 90 98 64 22 5E 1B A0 2A 08 97 04 2A 0A 9A 26 EB 50 55 C2 94 C0 28 13
[08:48:06][D][actron485.climate:027]: 06 55 D5 1C 02 C8 C3 7C 48 D3 65 29 45 E0 C5 47 CB 00 08 6B 05 0D 42 00 39 73 04 91 22 6E 00 07 3F CE F4 28 83 3F 28 DD FC 15 B4 F9 D4 84 FF 80 4A D7 A0 42 3F 0D 41 69
[08:48:06][D][actron485.climate:027]: C0 18 A2 94 90 72 26 1E F1 60 99 2C 79 50 C0 7C 1C 0E A9 24 01 D1 20 80 05 22 A0 99 83 94 62 10 76 0A 28 0F 01 00 CA 49 53 80 25 7C B4 A0 49 48 0E 04 60 A8 81 9A 01 05 B4 64 82 22 98 EC 54 11
[08:48:06][D][actron485.climate:027]: State: Operating Mode: - Heating, Fan Mode: Off Continuous - Active, Setpoint: 9.00, Temperature: 4403.50, Zones: 1:On 2:Off 3:Off 4:Off 5:Off 6:Off 7:Off 8:On
[08:48:06][D][actron485.climate:027]: A0 80 F8 08 07 52 64 82 AC 97 10 81 7B A7 12 C0 AC 03 2E BD F8 15 01 6C 05 AC E7 98 42 40 A4 19 88 1C 5E 20 0C 18 3D 55 01 00 DE 73 2C 92 05 CC 41 FD 32 29 05 BC 01 44
[08:48:07][D][actron485.climate:027]: Unknown Message received
[08:48:07][D][actron485.climate:027]: 7E 70 42 7F 40 12 28 95 FE 56 A9 01 00 18 EE 81 28 61 40 64 39 99 01 8C 71 3B 04 55 6A 28 2F A4 2A 09 94 7C 88 01 98 09 65 D2 29 25 15 81 A1 01 2C 98 0C 8C A3 78 44 55 88 8D FB 1A 21 95 08 1C
[08:48:07][D][actron485.climate:027]: 76 CA C4 60 2E D4 14 28 08 EE 9D 81 22 40 11 05 D4 54 51 94 25 A9 25 A8 13 41 ED 90 D1 FF 2C A0 B5 00 01 1D BC 45 34 A6 5B 25 6A 40 A4 87 B1 91 A8 25 B6 17 FF 94 4A 0D
[08:48:07][D][actron485.climate:027]: EC A0 42 18 3F 4A 05 A4 F4 EE 48 08 03 81 54 D2 01 60 47 A6 42 A8 45 68 D2 83 13 31 1D 03 90 A1 E0 3F 81 80 11 32 71 8A 25 A1 C4 C1 41 91 02 AE 2A 40 22 5A 37 C6 10 48 52 40 E9 08 21 88 46 C4
[08:48:07][D][actron485.climate:027]: 8E 6F 5C D5 74 49 88 DB 01 14 0A 11 55 31 0D 02 0C 74 CA 55 49 A2 39 2B CD 0F 55 F9 56 55 90 F8 04 A0 F8 DC 28 72 00 73 A0 06 0E 52 ED D0 18 01 00 C6 0C 20 94 60 A5 47
[08:48:07][D][actron485.climate:027]: 15 15 09 5B B0 DE 7E C0 1D C0 48 A8 03 7E 95 71 E0 0B 01 00 0E 85 22 02 66 3E A6 54 15 10 73 69 4A D2 FB AD 55 00 29 C8 41 00 83 D9 69 AB 01 15 4A 8D 21 C4 32 69 68 12 55 55 01 27 49 28 A0 4A
[08:48:07][D][actron485.climate:027]: 49 2E 52 04 38 34 3F 94 09 D8 4E 0A FE A6 07 A4 A5 9B B5 43 10 3B 22 89 04 0D 00 00 D8 E9 20 01 90 A0 92 F8 90 28 01 04 55 C9 A0 82 28 82 20 4A F8 90 20 24 41 1C 11 40
[08:48:07][D][actron485.climate:153]: Has Changed, Publishing State
[08:48:07][D][climate:396]: 'Actron Climate Controller' - Sending state:
[08:48:07][D][climate:399]: Mode: OFF
[08:48:07][D][climate:401]: Action: OFF
[08:48:07][D][climate:404]: Fan Mode: HIGH
[08:48:07][D][climate:413]: Custom Preset: Continuous Fan
[08:48:07][D][climate:419]: Current Temperature: 4403.50°C
[08:48:07][D][climate:425]: Target Temperature: 9.00°C
[08:48:07][D][actron485.climate:023]: Zone Fan Changed, Publishing State
[08:48:07][D][fan:120]: 'Master Bedroom' - Sending state:
[08:48:07][D][fan:121]: State: OFF
[08:48:07][W][component:214]: Component actron485.climate took a long time for an operation (0.06 s).
[08:48:07][W][component:215]: Components should block for at most 20-30ms.
[08:48:08][D][actron485.climate:027]: C: Zone: 4, Temp Offset: 10.00
[08:48:08][D][actron485.climate:027]: C4 C3 71 64 80 CC 07 6A 92 84 20 24 E0 0C 32 96 30 12 C8 13 FD 01 38 93 CC 40 47 25 55 00 81 62 64 00 5D 5B 09 81 A4 1F 18 ED AA 55 E2 48 09 10 06 1F C5 02 08 8A 40 4E 00 82 F0 15 AF 54 48 1F
[08:48:08][D][actron485.climate:027]: Unknown Message received
[08:48:08][D][actron485.climate:027]: 2D C0 02 02 4F F8 93 A1 D1 12 43 81 62 F6 00 2B 03 40 28 48 03 90 48 03 84 A0 30 30 13 22 00 9E B8 83 08 40 48 74 B1 EB 64 80 45 57 5A 91 84 05 66 A1 83 0E 28 29 84 0B
[08:48:08][D][actron485.climate:027]: D0 02 94 02 53 F4 03 36 20 81 84 5A 50 42 38 60 D4 C8 18 06 E7 39 C6 0C FE 8C 38 21 15 8A 4D 22 F2 48 03 B3 48 40 D5 43 4E 09 AE 13 C9 02 A1 6D 90 57 80 95 89 31 89 88 98 0C 0A 4E 08 0A 25 72
[08:48:08][D][actron485.climate:027]: 3B 19 19 06 03 86 02 41 83 97 C2 10 E4 14 78 05 91 A5 79 5C 95 AD 15 58 34 54 52 08 14 EC 14 55 10 F8 D7 A4 80 D0 18 61 34 42 01 9C 8F 84 C8 7F C3 E1 0E 28 DC A1 50 64
[08:48:08][D][actron485.climate:027]: 9C 11 44 0E A8 16 54 00 82 95 2B F8 4F 28 78 F2 00 70 30 30 9C 40 00 89 C0 2C 6C 50 42 B0 02 10 00 EC 55 00 80 80 18 99 EF 50 10 18 90 84 94 24 50 3A A0 55 6A 90 09 24 80 C8 6D 4C 41 25 52 D2
[08:48:08][D][actron485.climate:027]: 03 00 F8 40 4D 01 04 55 40 DA 00 30 12 0C 1B FB 40 48 0A F8 30 A0 06 D5 50 4C 60 20 C9 21 1C C0 CE 0A 08 B0 B8 58 94 F9 34 14 82 06 21 F9 34 15 C9 F8 30 A0 79 6C 4A F9
[08:48:08][D][actron485.climate:027]: 73 84 F6 B9 F5 52 85 15 2A F8 8E C6 80 70 E0 68 1C 16 0B 48 8C A1 43 08 DE F5 09 28 F1 30 C9 09 C0 08 92 62 96 04 86 00 25 CA 49 24 0C C6 44 A5 15 88 83 14 49 3E 81 26 21 25 3A A7 F3 85 4A 80
[08:48:08][D][actron485.climate:027]: EF 12 2A 2E A4 55 87 28 08 33 BF 60 70 05 B0 82 C5 20 28 49 1C F2 54 0B A0 28 E3 60 A8 88 23 C9 27 9B 94 A2 CF 58 05 28 DA 6C 64 2A F8 A9 06 BE E3 60 4A 10 7C 04 1D 4E
[08:48:08][D][actron485.climate:153]: Has Changed, Publishing State
[08:48:08][D][climate:396]: 'Actron Climate Controller' - Sending state:
[08:48:08][D][climate:399]: Mode: OFF
[08:48:08][D][climate:401]: Action: OFF
[08:48:08][D][climate:404]: Fan Mode: OFF
[08:48:08][D][climate:413]: Custom Preset: Continuous Fan
[08:48:08][D][climate:419]: Current Temperature: 4403.50°C
[08:48:08][D][climate:425]: Target Temperature: 9.00°C
[08:48:09][D][actron485.climate:027]: Unknown Message received
[08:48:09][D][actron485.climate:027]: 05 62 69 0C 80 48 CD 10 B0 C7 E6 DC AE 0C 89 52 A0 14 51 00 ED B0 95 41 41 B2 F2 44 24 98 20 12 2A 09 84 EC 44 10 16 50 BD 51 A1 08 19 24 01 01 48 01 4E 21 05 0A 2C 34 50 55 85 CA 19 06 16 02
[08:48:09][D][actron485.climate:027]: M: Zone: 5, Set Point: 17.50, Temp: 29.10, SP Range: 4.00-10.00, Zone: Off, Damper Pos: 20%
[08:48:09][D][actron485.climate:027]: 85 23 25 48 A3 D4 C2 04 12 38 EF 81 0C 09 D1 5E AA 62 08 D2 21 18 0C 93 13 CA 11 88 0A 40 45 81 22 10 D8 9B A8 F8 C5 00 34 84 04 08 5C 1B 28 29 69 7A 62 32 54 BF E9 00
[08:48:09][D][actron485.climate:027]: 51 76 E1 78 32 B3 30 10 FD 6C 83 29 55 34 8E A0 CE 6A 62 A1 48 95 09 29 9B 44 55 20 A5 E9 52 4A 82 75 42 D0 02 20 E8 40 C0 24 55 3E 92 05 5A 20 89 02 81 AF AE 94 01 14 8A 00 20 A0 C8 9F 19 80
[08:48:09][D][actron485.climate:027]: 24 42 70 24 80 F8 71 34 5D C6 45 CF A1 60 44 28 54 78 32 A3 F7 92 44 8C 00 56 49 48 F9 74 88 06 00 25 3C 47 01 DC 00 95 08 00 75 55 F8 08 45 01 4E 95 B5 1F 24 27 98 42
[08:48:09][D][actron485.climate:027]: M: Zone: 1, Set Point: 6.00, Temp: 19.00, SP Range: 16.00-0.00, Zone: Off, Damper Pos: 60%
[08:48:09][D][actron485.climate:027]: 91 BE 8C 20 0C 40 89 4E 00 61 B5 8F 25 7C 99 23 28 C3 01 0D 0A 24 50 3D 0F 85 B0 70 B0 07 15 A2 F8 62 2A A5 01 35 41 78 24 C1 A9 D5 23 4A 06 16 1F 84 64 22 4B 00 12 81 0A 90 97 24 48 2A B4 4D
[08:48:09][D][actron485.climate:027]: 22 08 0C 56 66 F8 C8 1A 50 82 09 0F B5 13 4A 25 44 2F 95 9D 80 28 88 02 80 64 A0 80 B4 82 04 54 A3 16 86 09 55 1F 99 79 90 48 F8 90 28 2A 64 1E 2A F8 90 08 98 CF 8F 95
[08:48:09][D][actron485.climate:027]: 49 7D 80 08 07 1E 03 65 A3 44 60 58 04 80 02 C8 AE 58 22 85 0E 54 11 A4 07 1A 5F 93 25 0E 4C 38 43 01 98 11 58 6D 02 4F 94 18 92 40 B6 26 22 15 A8 35 21 80 AA 24 1D 02 00 20 EB 23 04 55 C0 F1
[08:48:09][D][actron485.climate:027]: 25 0A 85 14 15 23 60 93 83 47 11 03 A0 47 A6 F8 40 4A 4A D0 90 03 90 22 BF 90 20 4F B2 44 83 B5 02 8A 48 64 8C 80 20 08 92 58 73 29 03 60 4A DB 68 70 92 03 40 20 F7 40
[08:48:10][D][actron485.climate:027]: Unknown Message received
[08:48:10][D][actron485.climate:027]: 28 85 88 03 B8 42 6A 91 50 13 80 86 4A 64 E1 C7 FC 9D 26 3A 30 C6 A0 06 64 15 82 46 2C 6F 61 31 B1 02 41 50 20 23 20 41 40 4C 01 66 40 8E 09 15 80 C8 81 A4 94 11 12 F3 31 54 29 C0 68 06 61 18
[08:48:10][D][actron485.climate:027]: 29 8C 1B 00 01 22 4F 63 23 03 C0 7B 18 FF 9A 08 86 1E 55 71 07 01 90 1D 20 A0 F9 7E 84 3B 20 4A 51 07 88 0C 42 A8 3D 24 91 06 C8 04 60 38 40 06 C0 4A F9 34 14 21 D9 62
[08:48:10][D][actron485.climate:027]: 54 FF 3A C2 F3 07 29 04 16 45 EC 6A 52 35 23 29 59 00 18 90 12 4A 49 02 05 ED F4 63 09 AA 51 6B 93 04 28 00 45 51 50 C4 56 0D 0A A9 52 8C 69 00 14 95 30 54 09 00 D0 94 1B 28 55 D0 A9 CF 48 4C
[08:48:10][D][actron485.climate:027]: C: Zone: 2, Set Point: 9.50, Temp: 51.60(Pre:47.40), Mode: Off
[08:48:10][D][actron485.climate:027]: E2 13 05 20 A3 06 05 34 A2 00 56 54 C0 84 09 3F 26 1C 80 A9 A0 95 07 5C 7F 40 48 E2 E8 14 0D CC 14 ED 20 85 E3 43 12 2A 22 12 02 44 3A FA 53 22 22 22 6E 85 7F 05 18 92
[08:48:10][D][actron485.climate:027]: 89 36 FD 16 AD FF 48 12 6B D2 28 F0 0A 4A B9 3F 59 0D C0 63 CB 60 08 A4 0B 50 40 01 D6 98 21 00 40 89 F5 94 80 D2 14 F2 10 21 88 EA 03 12 91 E6 51 85 B9 28 8E 35 40 AA B2 5B 69 84 48 32 C4 CC
[08:48:10][D][actron485.climate:027]: AA 28 C0 09 82 83 52 0A C7 0A 09 A7 24 CB 22 F1 2E 8A 00 A0 E6 93 81 66 05 56 C5 30 41 7F C0 20 04 87 80 4A 3C 40 29 14 70 95 52 47 21 C3 24 2C 01 66 84 10 80 30 06 0E
[08:48:11][D][actron485.climate:027]: AA 55 85 4E 49 D2 20 38 26 05 80 20 92 6A 7F 18 20 34 1B 71 04 26 A7 B2 92 20 46 E2 1C A4 01 F8 C7 AB 84 95 01 62 B5 3E 06 C0 0F 57 18 A4 E0 78 0C 34 11 C8 46 21 40 DA 02 5E 14 A4 2A 25 8D 6B
[08:48:11][D][actron485.climate:027]: Unknown Message received
[08:48:11][D][actron485.climate:027]: 55 14 28 2C 93 01 00 80 0A 1F 29 4F 3D 05 95 92 D3 F1 22 6D C3 08 85 68 84 AA 32 0C FB 80 70 00 00 4C F9 76 95 08 F8 70 20 F9 46 01 9C 00 95 09 82 40 28 19 FE 50 81 86
[08:48:11][D][actron485.climate:027]: M: Zone: 5, Set Point: 7.50, Temp: 19.50, SP Range: 19.00-2.00, Zone: Off, Damper Pos: 60%, ??Adjusting??
[08:48:11][D][actron485.climate:027]: 95 C3 0E 26 4F C4 00 3E 2B 63 A1 48 02 07 20 30 35 18 88 05 14 17 12 00 2B 14 54 88 41 96 63 92 91 22 40 0D 02 0B C0 87 04 92 08 5E 45 4C AA 15 00 83 24 52 40 92 92 48 61 08 A4 83 A8 93 54 C8
[08:48:11][D][actron485.climate:027]: 39 42 E0 D7 CD 21 24 89 6C 34 30 F0 20 15 40 48 00 5D 44 79 10 28 98 0F 55 F8 08 D9 89 A0 F5 56 1D 8A 00 60 6A 66 07 00 00 03 5E B5 0F 24 32 03 90 90 F8 90 08 CF 8F 55
[08:48:11][D][actron485.climate:027]: 09 A0 5E 28 85 AC D7 3C 92 C8 D4 90 50 0E 7C 20 15 2C 00 EE 6B 01 F1 99 1B 40 51 00 E0 1D 99 90 28 05 E2 44 A5 9A 41 F0 88 14 95 5E 28 08 80 33 2C 09 90 30 A8 4E 4B 54 15 35 A0 10 92 11 3C 93
[08:48:11][D][actron485.climate:027]: M: Zone: 6, Set Point: 10.50, Temp: 3.60, SP Range: 1.00-2.50, Zone: Off, Damper Pos: 40%, ??Adjusting??
[08:48:11][D][actron485.climate:027]: 86 24 0A C2 D5 C5 94 50 03 31 08 00 C8 F6 26 33 11 83 50 60 FF 89 0D 10 D5 A8 20 E3 36 28 8A A0 20 4A 03 C0 1C 09 C0 27 CA 6A 10 AE E7 54 55 85 3E D8 48 34 D2 05 90 42
[08:48:11][D][actron485.climate:027]: 31 3F C0 25 82 78 3C 05 12 02 00 80 01 04 4C CA 61 27 83 8B 80 7A 85 0D A8 C2 34 EA 81 21 7E EC 41 50 6A 20 60 06 82 96 B0 E9 23 09 12 A0 64 53 25 01 AC 3F 54 55 55 9A 54 92 09 A8 51 84 85 D2
[08:48:11][D][actron485.climate:027]: M: Zone: 8, Set Point: 25.00, Temp: 26.00, SP Range: 9.00-4.00, Zone: Off, Damper Pos: 60%
[08:48:11][D][actron485.climate:027]: B8 04 2D 92 32 C8 2A 90 98 48 9C 04 00 40 EA 52 26 10 B3 07 43 22 0C 30 C3 0A EB 40 28 A9 40 50 DB 40 28 0D FC A0 49 45 D3 04 92 01 40 4A 20 7C C0 50 03 02 29 32 94 FC
[08:48:12][D][actron485.climate:027]:
[08:48:12][D][actron485.climate:027]: Unknown Message received
[08:48:12][D][actron485.climate:027]: 38 01 47 12 84 AA 12 50 E3 B8 92 85 3E 9F 24 44 40 89 50 44 21 40 AE 1B 91 08 66 6C 84 52 E3 43 94 01 81 8A 2F BC 82 38 E9 DC D5 20 80 1A 74 08 84 10 00 E2 D6 C6 A9 71 B2 51 00 0A 00 05 84 9E
[08:48:12][D][actron485.climate:027]: M: Zone: 8, Set Point: 5.00, Temp: 36.00, SP Range: 8.00-25.00, Zone: Off, Damper Pos: 80%
[08:48:12][D][actron485.climate:027]: 88 68 31 10 0A F2 12 4A 42 22 74 CA 12 53 2A 63 1A 7E C0 52 2F 12 92 52 15 08 A1 46 38 25 11 80 35 A2 53 90 BF 05 46 86 44 71 C8 E3 04 A8 42 BB 14 A0 8A 6A 81 21 4A 48
[08:48:12][D][actron485.climate:027]: C: Zone: 7, Temp Offset: 3.20
[08:48:12][D][actron485.climate:027]: D7 31 A2 20 1A 5E 22 21 FC 00 11 51 31 24 08 2F 80 22 54 62 05 24 D2 92 02 63 43 1D 2E 18 A0 21 1A 29 05 85 D3 24 A9 2A 42 C0 6D 1A 04 64 6B 93 01 1D 5C 7E 84 C0 A9 B6 09 C5 12 D7 2E 24 92 29
[08:48:12][D][actron485.climate:027]: A9 20 44 00 01 E8 04 15 54 0E D1 28 00 20 0C 2B B2 49 24 3D A6 C7 C4 60 0B 7F 10 62 11 02 9A 80 18 B3 45 D1 61 32 FC 2C 81 4A A1 E8 31 09 2A 25 52 8E 18 08 3A 83 12 38
[08:48:12][D][actron485.climate:027]: 48 92 17 8E 2A C7 B8 C1 24 CA 59 42 0E 24 8E 18 32 61 11 72 02 08 16 51 90 A8 54 79 34 54 00 40 FA 91 82 05 EB DC 51 7E 3C 9A 08 0E 44 20 1E 0C 10 02 28 56 41 A8 0A 42 AE A8 0A 68 6F A0 28 A4
[08:48:12][D][actron485.climate:027]: 8A A0 53 AA 92 96 C0 DC 10 A1 00 37 3D 11 03 60 E0 00 00 8C 99 14 40 88 3C A0 30 8C F9 00 00 78 01 00 4A 0D FC 01 28 1C 60 14 E4 0A A9 0D B0 95 30 E0 3E 4A 85 40 2D DD
[08:48:13][D][actron485.climate:027]: Unknown Message received
[08:48:13][D][actron485.climate:027]: 69 99 41 F1 A1 1C 12 C0 7F 1C 9D 42 32 14 E3 3A 98 5E 78 BC B4 CA 40 15 F5 32 89 88 02 7F 03 00 40 A2 8E 11 A1 28 22 A2 00 10 12 47 25 92 33 54 10 13 90 02 25 08 50 48 89 95 89 15 F1 5E 7D 01
[08:48:13][D][actron485.climate:027]: 55 22 B0 25 41 42 50 E9 17 88 04 32 25 F8 00 C6 CE 84 1D 60 15 14 1E 01 FC CE 55 C3 AA 7F 6C 08 F0 4A 78 0C 55 55 05 55 1F 3C 30 42 14 41 55 28 01 FE 55 14 08 01 DC 9C
[08:48:13][D][actron485.climate:027]: 01 B0 18 5A 81 80 20 9A 7B 71 C0 01 04 49 11 2A 20 43 21 B0 2A 08 05 4E 24 A9 28 33 1A 10 C0 48 8E 0D 09 01 50 13 49 81 03 C1 14 C9 52 88 9D DD 01 41 88 93 2B 84 08 92 D4 65 01 06 9C 67 1E A4
[08:48:13][D][actron485.climate:027]: C0 EF 5C 0B A1 9C B7 12 20 04 90 E0 39 28 F9 76 47 6D 70 20 3A 0E 01 18 80 80 C9 00 80 A0 EC 12 05 00 99 BB F4 00 09 AD F6 90 81 29 4E 88 55 15 01 84 9A 8E 45 ED 90 28
[08:48:13][D][actron485.climate:027]: 51 E3 00 A4 0D 40 08 25 C3 20 45 F8 62 86 4C 17 E8 DA 37 26 00 42 80 82 D6 54 0A 73 D5 90 20 07 92 34 49 15 11 50 54 05 02 8F 35 84 11 00 1C 32 2A 00 29 82 40 05 81 C0 51 06 92 02 81 2A 21 50
[08:48:13][D][actron485.climate:027]: M: Zone: 3, Set Point: 4.00, Temp: 15.40, SP Range: 0.00-17.50, Zone: Off, Damper Pos: 0%
[08:48:13][D][actron485.climate:027]: A3 9A 20 00 08 23 C8 34 00 0E C6 6C 20 CC 3E 66 58 4A 02 8E 55 F9 10 28 29 02 44 4A F8 90 90 02 12 84 34 8D 84 5E 03 31 12 25 BC 94 0C 40 FB F1 60 C0 9C 03 A6 85 00 20
I think this is a bit of a red flag. There should be nothing coming through at all if not connected to the AC. Try another ESP32 and RS485 module if you have one.
The AC boards are always on unless switched off at outdoor unit or circuit breaker. When there is power to the indoor board, it will constantly send data. Unless you mean completely off from the master switch, then that would further indicate an issue with the ESP32 or RS485 module.
Should be compatible in theory. Looking online on the indoor board photo. You connected it to the A
B
on the GAB
(J4) header and not the ABCDE
(J3) header?
I donât think the code updated, as the messages are just as long as before, but I think itâs all coming through anyway on the next round of reading.
Thanks @awulf
A couple of things to work through here;
- Futher testing and power supply change
- Am I using the GitHub project correctly?
I donât have other ESP32 or RS485 modules to try however I will order another RS485 module online and await delivery.
While waiting for this I tried a few things. Up until now I had the ESP32 powered from a 3.3V power supply and the RS485 module powered from a 5V supply. Today I powered the ESP32 from the micro USB and powered the RS485 module from the ESP32s 3V output pins. Powering the ESP32 and RS485 like this stopped the gibberish in the logs and the logs were now âcleanâ.
Before connecting the A and B wires to the AirCon I used home assistant to toggle controls from the dashboard. Pressing buttons on the dashboard I can see the controls in the logs see below.
INFO ESPHome 2024.2.2
INFO Reading configuration /config/esphome/esphome-web-66825c.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing actron-ac-esphome (board: esp32dev; framework: arduino; platform: platformio/[email protected])
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Dependency Graph
|-- AsyncTCP-esphome @ 2.0.1
|-- Actron485 @ 0.6.0
|-- WiFi @ 2.0.0
|-- FS @ 2.0.0
|-- Update @ 2.0.0
|-- ESPAsyncWebServer-esphome @ 3.1.0
|-- DNSServer @ 2.0.0
|-- ESPmDNS @ 2.0.0
|-- noise-c @ 0.1.4
RAM: [= ] 13.0% (used 42732 bytes from 327680 bytes)
Flash: [===== ] 51.5% (used 945485 bytes from 1835008 bytes)
========================= [SUCCESS] Took 4.53 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.1.20
INFO Uploading /data/build/actron-ac-esphome/.pioenvs/actron-ac-esphome/firmware.bin (951264 bytes)
Uploading: [============================================================] 100% Done...
INFO Upload took 6.98 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.20 using esphome API
WARNING Can't connect to ESPHome API for actron-ac-esphome @ 192.168.1.20: Error connecting to [AddrInfo(family=<AddressFamily.AF_INET: 2>, type=<SocketKind.SOCK_STREAM: 1>, proto=6, sockaddr=IPv4Sockaddr(address='192.168.1.20', port=6053))]: [Errno 111] Connect call failed ('192.168.1.20', 6053) (SocketAPIError)
INFO Trying to connect to actron-ac-esphome @ 192.168.1.20 in the background
INFO Successfully connected to actron-ac-esphome @ 192.168.1.20 in 0.008s
INFO Successful handshake with actron-ac-esphome @ 192.168.1.20 in 0.176s
[20:49:43][I][app:102]: ESPHome version 2024.2.2 compiled on Mar 15 2024, 07:57:59
[20:49:43][C][wifi:577]: WiFi:
[20:49:43][C][wifi:409]: Local MAC: [redacted]
[20:49:43][C][wifi:414]: SSID: '[redacted]'[redacted]
[20:49:43][C][wifi:415]: IP Address: [redacted]
[20:49:43][C][wifi:417]: BSSID: [redacted][redacted]
[20:49:43][C][wifi:418]: Hostname: 'actron-ac-esphome'
[20:49:43][C][wifi:420]: Signal strength: -35 dB ââââ
[20:49:43][C][wifi:424]: Channel: 11
[20:49:43][C][wifi:425]: Subnet: [redacted]
[20:49:43][C][wifi:426]: Gateway: [redacted]
[20:49:43][C][wifi:427]: DNS1: [redacted]
[20:49:43][C][wifi:428]: DNS2: 0.0.0.0
[20:49:43][C][logger:447]: Logger:
[20:49:43][C][logger:448]: Level: DEBUG
[20:49:43][C][logger:449]: Log Baud Rate: 115200
[20:49:43][C][logger:451]: Hardware UART: UART0
[20:49:43][C][uart.arduino_esp32:137]: UART Bus 1:
[20:49:43][C][uart.arduino_esp32:138]: TX Pin: GPIO26
[20:49:43][C][uart.arduino_esp32:139]: RX Pin: GPIO27
[20:49:43][C][uart.arduino_esp32:141]: RX Buffer Size: 256
[20:49:43][C][uart.arduino_esp32:143]: Baud Rate: 4800 baud
[20:49:43][C][uart.arduino_esp32:144]: Data Bits: 8
[20:49:43][C][uart.arduino_esp32:145]: Parity: NONE
[20:49:43][C][uart.arduino_esp32:146]: Stop bits: 1
[20:49:43][C][actron485.climate:226]: Actron485 Status:
[20:49:43][C][actron485.climate:227]: Receiving Data: NO
[20:49:43][C][actron485.climate:571]: ClimateTraits:
[20:49:43][C][actron485.climate:572]: [x] Visual settings:
[20:49:43][C][actron485.climate:573]: - Min temperature: 16.0
[20:49:43][C][actron485.climate:574]: - Max temperature: 30.0
[20:49:43][C][actron485.climate:575]: - Temperature step:
[20:49:43][C][actron485.climate:576]: Target: 0.5
[20:49:43][C][actron485.climate:577]: Current: 0.1
[20:49:43][C][actron485.climate:578]: - Min humidity: 30
[20:49:43][C][actron485.climate:579]: - Max humidity: 99
[20:49:43][C][actron485.climate:581]: [x] Supports current temperature
[20:49:43][C][actron485.climate:593]: [x] Supports action
[20:49:43][C][actron485.climate:596]: [x] Supported modes:
[20:49:43][C][actron485.climate:598]: - OFF
[20:49:43][C][actron485.climate:598]: - COOL
[20:49:43][C][actron485.climate:598]: - HEAT
[20:49:43][C][actron485.climate:598]: - FAN_ONLY
[20:49:43][C][actron485.climate:598]: - AUTO
[20:49:43][C][actron485.climate:601]: [x] Supported fan modes:
[20:49:43][C][actron485.climate:603]: - AUTO
[20:49:43][C][actron485.climate:603]: - LOW
[20:49:43][C][actron485.climate:603]: - MEDIUM
[20:49:43][C][actron485.climate:603]: - HIGH
[20:49:43][C][actron485.climate:616]: [x] Supported custom presets:
[20:49:43][C][actron485.climate:618]: - Continuous Fan
[20:49:43][C][actron485.climate:618]: - Standard Fan
[20:49:43][C][captive_portal:088]: Captive Portal:
[20:49:43][C][mdns:115]: mDNS:
[20:49:43][C][mdns:116]: Hostname: actron-ac-esphome
[20:49:43][C][ota:096]: Over-The-Air Updates:
[20:49:43][C][ota:097]: Address: actron-ac-esphome.local:3232
[20:49:43][C][ota:103]: OTA version: 2.
[20:49:43][C][api:139]: API Server:
[20:49:43][C][api:140]: Address: actron-ac-esphome.local:6053
[20:49:43][C][api:142]: Using noise encryption: YES
[20:50:16][D][climate:011]: 'Actron Climate Controller' - Setting
[20:50:16][D][climate:015]: Mode: COOL
[20:50:16][D][climate:396]: 'Actron Climate Controller' - Sending state:
[20:50:16][D][climate:399]: Mode: COOL
[20:50:16][D][climate:401]: Action: OFF
[20:50:16][D][climate:419]: Current Temperature: nan°C
[20:50:16][D][climate:425]: Target Temperature: nan°C
[20:50:25][D][climate:011]: 'Actron Climate Controller' - Setting
[20:50:25][D][climate:015]: Mode: HEAT
[20:50:25][D][climate:396]: 'Actron Climate Controller' - Sending state:
[20:50:25][D][climate:399]: Mode: HEAT
[20:50:25][D][climate:401]: Action: OFF
[20:50:25][D][climate:419]: Current Temperature: nan°C
[20:50:25][D][climate:425]: Target Temperature: nan°C
[20:50:37][D][climate:011]: 'Actron Climate Controller' - Setting
[20:50:37][D][climate:024]: Fan: LOW
[20:50:37][D][climate:396]: 'Actron Climate Controller' - Sending state:
[20:50:37][D][climate:399]: Mode: HEAT
[20:50:37][D][climate:401]: Action: OFF
[20:50:37][D][climate:404]: Fan Mode: LOW
[20:50:37][D][climate:419]: Current Temperature: nan°C
[20:50:37][D][climate:425]: Target Temperature: nan°C
[20:50:39][D][climate:011]: 'Actron Climate Controller' - Setting
[20:50:39][D][climate:024]: Fan: MEDIUM
[20:50:39][D][climate:396]: 'Actron Climate Controller' - Sending state:
[20:50:39][D][climate:399]: Mode: HEAT
[20:50:39][D][climate:401]: Action: OFF
[20:50:39][D][climate:404]: Fan Mode: MEDIUM
[20:50:39][D][climate:419]: Current Temperature: nan°C
[20:50:39][D][climate:425]: Target Temperature: nan°C
[20:50:40][D][climate:011]: 'Actron Climate Controller' - Setting
[20:50:40][D][climate:015]: Mode: OFF
[20:50:40][D][climate:396]: 'Actron Climate Controller' - Sending state:
[20:50:40][D][climate:399]: Mode: OFF
[20:50:40][D][climate:401]: Action: OFF
[20:50:40][D][climate:404]: Fan Mode: MEDIUM
[20:50:40][D][climate:419]: Current Temperature: nan°C
[20:50:40][D][climate:425]: Target Temperature: nan°C
When connecting the A and B wires to the AirCon (J4) header on my indoor unit, I canât send or receive any data. I canât control or read any states from the AirCon and the logs look the same as posted above. Current and Target temperate remain as nan and issuing a control from the home assistant dashboard doesnât do anything, nor does pressing buttons on AirCon wall panel (heat/cool, toggle fan speed etc).
Maybe its the RS485 module like you said, maybe is the Actron Indoor unit board?
Iâm a first time user when it comes to GitHub projects and I want to make sure Iâm using it corectly after you mentioned the code hadnât updated in my previous post.
When using your .yaml file I get an error when I install the config from ESPHome using this config for external_components
external_components:
- source:
type: local
path: /config/actron485/components
From the GitHub Actron485 project I have copied all the files from components/actron485 to my home assistant server at /config/actron485/components
I get the error when I install the config from Home Assistant ESPHome
The error log is
ERROR Unable to load component climate:
File "/esphome/esphome/loader.py", line 169, in _lookup_module
module = importlib.import_module(f"esphome.components.{domain}")
File "/usr/lib/python3.11/importlib/__init__.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1206, in _gcd_import
File "<frozen importlib._bootstrap>", line 1178, in _find_and_load
File "<frozen importlib._bootstrap>", line 1149, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 690, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 940, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/config/actron485/components/climate.py", line 47, in <module>
Actron485Climate = actron485_ns.class_("Actron485Climate", climate.Climate, cg.Component)
AttributeError: partially initialized module 'esphome.components.climate' has no attribute 'Climate' (most likely due to a circular import)
Failed config
climate: [source /config/esphome/esphome-web-66825c.yaml:57]
Component not found: climate.
- platform: actron485
name: Actron Climate Controller
write_enable_pin: GPIO25
esp_fan_available: True
ultima:
available: False
adjust_master_target: False
logging_mode: ALL
zones:
- number: 1
- number: 2
- number: 3
- number: 4
I get around this error by replacing
- source:
type: local
with
- source: github://awulf/Actron485
Iâm not sure if this is sufficient and if all the config files are installing correctly and it appears to missed the change you made last week to the buffer size.
What files do I need to copy to /config/actron485/components?
