ADAX NEO WIFI Modern Electric Wall Heater, Home Automation Heating
Hi All / @Danielhiversen
I fairly recently bought a pair of ADAX wifi/bluetooth heaters for my kids play room with the idea that I can control them from my HA system.
When I first installed them I was really pleased but pretty quickly I started to struggle with the HA integration taking sometimes 5 mins to respond to a command to either turn on or increase the heat. It has got so bad that my automation are hit and miss. Most of the time the heating events fire but the heaters don’t respond and you have to execute them a few times to eventually fire. HA often times out to any thermostat controls return to their original values…
So… To combat this I though perhaps it would be time to move to the local API instead of using the cloud API. It actually turned out to be a bit of work to move them to local API control, mainly because my HA servers BT would not reach the room they are in so I have to power everything off and move the server just so I can talk to the rads to configure them…
(In case you are unfamiliar, you have to add them to your home wifi network using BT to start with)…
After a few attempts I managed to get them both back in to HA and again… To start with them seem great and much more responsive (basically instant)…
Now comes a new problem…!
Just as I thought I was out of the woods I now am finding that after a period of time (don’t think there is an exact time) HA seems to lose connection to the rads… I am on a mesh network and there is a wifi node in that room and I don’t “think” it is the wifi but not really got a full way to test that. (no other device in that room loses connection)…
The only way I can solve this is to power them off… wait… power on and reinitialize the device in HA which seems to get them back for another few hours…
Right now I have2 options that are both pretty lame… The cloud API is slow (5 mins +) or simply just doesn’t respond… OR… THe local API which is fast but loses connection after X time…
Anyway got any ideas or had experience with ADAX that could help? Not even sure how to get any logging out to see what is going on…
@Danielhiversen
So sorry… I realised I didnt even say thank you for writting the integration… It really is great to be able to control these guys and I am very sure I either have a problem with my heaters or I am doing something wrong…
Just wanted to say thanks for taking the time to make these!
Hope there will come a oslution for getting the energy values out of the API…
Hello, I am also interested in the topic, but isn’t the problem really that ADAX doesn’t provide a good API. It seems that they provide an added power consumption on an hour basis.
What would be great to get is, each time the red LED indicates heating that this would be provided as an event in some form. Maybe difficult to provide as a cloud integration as it will cause quite a load.
Any further inisghts or status?
Frank
Has anyone been able to setup the local api with an Esp32 Bluetooth proxy? Saw something about it’s not supported, which I find strange why that should be any different to an adapter.
I am using the Orico BTA-402 USB dongle, and I am unable to set up the local ADAX Integration.
Getting no messages/log in the Bluethoot integration, but this in the system log:
Logger: root
Source: /usr/local/lib/python3.12/asyncio/events.py:88
First occurred: 12:23:08 (2 occurrences)
Last logged: 20:49:31
A message handler raised an exception:
  File "src/dbus_fast/message_bus.py", line 805, in dbus_fast.message_bus.BaseMessageBus._process_message
  File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/manager.py", line 1034, in _parse_msg
    watcher.on_characteristic_value_changed(
  File "/usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/client.py", line 182, in on_value_changed
    callback(bytearray(value))
  File "/usr/local/lib/python3.12/site-packages/adax_local/__init__.py", line 120, in notification_handler
    raise InvalidWifiCred
adax_local.InvalidWifiCred
Logger: py.warnings
Source: components/adax/config_flow.py:82
First occurred: 12:15:40 (3 occurrences)
Last logged: 20:46:45
/usr/local/lib/python3.12/site-packages/adax_local/__init__.py:194: FutureWarning: BLEDevice.metadata is deprecated and will be removed in a future version of Bleak, use AdvertisementData instead metadata = discovered_item.metadata
Previoysly the ADAX cloud intergartion worked. I have reset the ADAX heater. Deleted the integration. And trying to set it up from start. My SSID and psw are correct so dont unerstand why the log says “InvalidWifiCred”.
“Fun fact”, - HA recognizes my Oral B toothbrush, so the USB dongle works, but not for the Adax heater…
My HA Blue is connected to my router with cable (not Wi-Fi). Can this be a problem?
@ Daniel Høyer Any insight will be appreciated.
Any ideas?
Hello @Danielhiversen . Is there a way to manually inject the heater IP and Token into the integration?
I manually ran your library GitHub - Danielhiversen/pyAdax: Python library for Adax heater on my laptop, and it connected to wifi successfully.
import adax_local
import asyncio
import logging
logging.basicConfig()
adax_local._LOGGER.setLevel(logging.DEBUG)
device = adax_local.AdaxConfig('wifissidxxx', 'passwordxxx')
asyncio.run(device.configure_device())
I just can’t get past the wifi dialog in the integration setup as it cannot discover my device.
Ill probably have to end up patching the onboarding function…
I patched /usr/src/homeassistant/homeassistant/components/adax/config_flow.py to contain the following in async_step_local:
    async def async_step_local(
        self, user_input: dict[str, Any] | None = None
    ) -> ConfigFlowResult:
        ACCESS_TOKEN = "access_token"
        DEVICE_IP="device_ip"
        MAC_ID="mac_id"
        data_schema = vol.Schema(
            {vol.Required(ACCESS_TOKEN): str, vol.Required(DEVICE_IP): str, vol.Required(MAC_ID): str}
        if user_input is None:
            return self.async_show_form(
                step_id="local",
                data_schema=data_schema,
        access_token = user_input[ACCESS_TOKEN].replace(" ", "")
        device_ip = user_input[DEVICE_IP].replace(" ", "")
        mac_id = user_input[MAC_ID].replace(" ", "")
        unique_id = str(mac_id)
        await self.async_set_unique_id(unique_id)
        self._abort_if_unique_id_configured()
        return self.async_create_entry(
            title=unique_id,
            data={
                CONF_IP_ADDRESS: device_ip,
                CONF_TOKEN: access_token,
                CONF_UNIQUE_ID: unique_id,
                CONNECTION_TYPE: LOCAL,
This was just a hack to get it to work. I can create a PR later that is better integrated into the flow. With this I am able to enter my creds.
I am however getting an error that the device is not available on port 443? Curling the device ip at 443 gives a connection refused. Are there firmware changes? I bought this device today.
EDIT: looks like this is a firmware issue! ADAX - cannot set up heater via local connection · Issue #127076 · home-assistant/core · GitHub
That would be awesome!
@Danielhiversen Looks like Energy Endpoint available for the ADAX integration. Maybe add this to the integration (also the local)?
Hi, I just integrated my adax heaters to home assistant but my temperature readings shows in fahrenheit instead of celsius. In adax app I have them in celsius. Any ideas how to change from fahrenheit to celsius? Just started using HA so not very familiar with it yet.
Try changing unit system in settings - system - general …
Any idea why Homey has power consumtion in their intergration and not in the HA intergration?
Is anybody elses Adax heater temp reading way off? Like my 2 other zigbee temps say 15 degree and Adax is keeping at 8. I wonder where the actual sensor is, sense this is now in fairly cold summer cabin in the winter, so maybe to floors/walls are much colder…
On my Adax Neo, the thermo sensor is below the heater, so almost at floor level on the wall where the heater is mounted. This is possibly the coldest place in the room. The sensor is a little finger that sticks down from the bottom of the heater.
Nice work!
Have you had the chance of working this into a PR?
Or perhaps I could help?
I was wondering this as well and seems there is a fork with some additions related to energy monitoring: GitHub - parholmdahl/home_assistant_adax: Integration for Adax heaters
Has anyone tried this version?
I looked around in the above repo and found a comment that
This repo is no longer used.
Looks like the HACS component has moved into HA Core code!
In late 2024 this stopped working. I deleted and reloaded the ADAX Integration. Used the form to load my credentials but Home Assistant no longer picks up any entities. Also tried with new credentials but without success. (HA Core 2025.2.3 HA OS 14.2)
ADAX app on Android still works.
