So I admit I haven’t read through ALL of the comments, but it seems this is still an active discussion even over a year later. But I’m a little confused, because it seems this is already supported in Home Assistant. Unfortunatley, you can’t seem to specify the friendly_name directly on the template sensor, but it is possible to set the friendly name.
With this configuration, the entity contact_4_adj_temp will have Contact 4 - Temp (Adjusted) for it’s display name in the UI.
I tried using various combinations of unique_id: and name: and attributes: ⏎ friendly_name:. But the above is the only one that works reliably for me.
Using unique_id: + attributes: ⏎ friendly_name: works…but then it prepends the actual resulting entity_id with template_. You can then edit the entity to fix the name…however, I don’t know if it is persistent across reboots/reloads.
Using name: + attributes: ⏎ friendly_name: does not work, it just uses a snake-case version of name: for the friendly_name attribute.
Using unique_id: + name: kinda sorta works…but you have to use justunique_id first, save, reload template sensors…then add name.
I would like to have the actual power consumption reading as part of the name for lights showed in the lovelace interface.
I’ve used the template editor under developer tools to check the code and there it works flawless. But I’m not able to make it work to adjust the name of mqtt light entities. I’ve used the following 2 template coding: Option 1
this topic is about sensors by the template: integration. All of the options support templates.
However, you’re asking about an mqtt: sensor. Which does not support templates on the name:. So, its simply returning what you enter there.
You cant just invent functionality
also, your templates are a bit odd with the |string filter (all templates are strings, so what are you trying to do with that? ) and all. also, you need to add defaults to the |int, see Updating Templates with the new default values in 2021.10.x
It sound like the problem here is not a lack of friendly name, but an issue with the way “identities” are derived from each other.
It is possible to assign a completely dynamic name (name, previously friendly_name) to template sensors. The issue causing confusion is that by default the entity_id is derived from the name, instead of the specified unique_id.
This perception is supported by:
Descriptions/workaround using the UI to configure the entity_id after assigning a unique_id.
Lifetime stability: unique_id > entity_id > name (friendly name)
If the following process (psuedo-code) was used, I think all this confusion would go away:
unique_id := specified.unique_id if specified.unique_id is defined
else guid()
entity_id := specified.entity_id if specified.entity_id is defined
else "domain."+specified.unique_id if specified.unique_id is defined
else specified.name
name := templated(specified.name) if specified.name is defined
else entity_id
It already does this…. The only part of your sudo code that isn’t applied is a auto generated guid if no unique id is provided. And that’s not possible because the guid would be different every startup.
that is not the unique_id, but the entity_id.
If that is what you want to change, just click the cogwheel and change it
since you configured a name in the yaml, it has taken that to use for the entity_id.
(what I always do is startup with a yaml configured name, so the entity_id is what I want it to be, and then comment the name in the yaml, since you can alter the name in the UI afterwards)
either set a name: and have the new entity get the slugified name as object_id
or dont set a name: and have the new entity get the unique_id as object_id, prefixed by template_
after that, click anything in the UI to change to your liking (and, let me repeat, comment the name in yaml, so there is no double ledger on that if you would change the name in the UI)
Feels like its been a backwards step from what existed previously… Everything needs more clicking now…
So where is the cog? I check the sensor.entity_id after removing the unique_id but it says there’s no unique_id associated with the entity so I can’t modify anything…
that’s odd, since you clearly have set a unique_id
unless, you are clicking on the original entity, and not the newly made one. did you check dev tools states and look for lana_home? there might just be 2 of them now?
o wait, I see you removed it? never do that, its your way into the UI…
If you actually set it to a UUID it becomes more obvious what’s going on here. It’s an internal reference and not something seen or used by the end user. Marius’ explanation is accurate. Here’s more info: This entity does not have a unique ID? - Home Assistant.
Yes, but removing the name in yaml will give a sensor named sensor.template_xxx
Don’t like that haha
With Name and ID it will label the sensor as a template integration only
Is there any other reason to not (besides the name) use unique_id to make it editable in UI?
(i have read something about not editable in the YAML anymore, but can’t find it)
This has been around WAY too long and should be completed with a solution. The friendly name never went away, it just changed. Unique_id is not meant for the user to use at all, it is a backend thing used by the UI. So that has to be unique and it is not referred to by humans anywhere.
You add an attributes key then a friendly_name key.
If you think about it, it makes a lot of sense because that is an attribute and belongs there with any other attributes you would like to add.
This was available when the format changed, but was not explained very well.
- name: sun_state
unique_id: f2ef3978-8f60-4f49-9ce5-1198306412fd
state: >
{% if is_state('sun.sun', 'above_horizon') %}
up
{% else %}
down
{% endif %}
availability: >-
{% from 'availability_template.jinja' import avail %}
{{- avail(['sun.sun']) | bool -}}
attributes:
friendly_name: "My Sun State"
