It was good working for but the camera fall of 10cm and it not boot correctly, so very cheap device,…
Yes, try the tricks in the readme of the repository i linked above
okay with onvif integration in same time it’s make the camera crash, it’s good after delete onvif.
Have you something to have move detection ?
No, but I plan to add motion alarms to the integration
Preset positioning are awesome
Servie are fully GUI usable
My button to active position and save position with long long time push :
show_name: true
show_icon: true
type: button
tap_action:
action: call-service
service: icsee_ptz.move
target: {}
cmd: GotoPreset
preset: 1
camera: cam_ptz
entity: device_tracker.camera
icon_height: 20px
icon: mdi:camcorder
name: Position maison vide
hold_action:
target: {}
cmd: SetPreset
camera: cam_ptz
preset: 1
I didn’t know there was a hold action, perfect use case for store and recall
Is there a kind of API to control Icsee cam ?
Hi Mateine
Little question about dbuezas/icsee-ptz:
I have 4 camera working with ICSee se. The ICSee software has a function called “follow human” that means that as soon as a human get into the camera beam, the camera start moving follow the human.
With your nice integration, Is It possibile tò enable or disable this feature?
If not, do you know how can be done??
Costa
It’s not possible at the moment, I could look into it.
Maybe i should make entities for each camera
This PR be of interest to you, if the repo owner takes it, it will enable what you did directly inside the webrtc card
Ty but i prefer to don’t have action hover the video. Buttons are too small on mobil and they mask video
I see.
Can you share a screenshot of your setup?
The PR was merged!
Make sure to update both WebRTC and GitHub - dbuezas/icsee-ptz to get the new features.
You’ll also have to make a slight update to your yaml files (see readme of icsee-ptz)
Thank you
The dvrip stream (via go2rtc) works for me.
Is There a solution to disconnect totaly the camera to icsee online services/server ?
Hello everyone.
I have two ICSEE cameras connected to a different network and I want to be able to view them from my home assistant network. I am currently using the “VMS” app on Windows to view the cameras, but the issue is that when I access the settings, it shows the local IP of the camera on the other network, which is not accessible from my own network. How can I access the camera streams on my home assistant setup? Thank you very much for your help.
Did you found solution for this?
I guess this will only work if you have some kind of vpn tunnel to the other network so you can reach the ip from within the network home assistant is in.
for icsee camera, by the seller info (EU dealer for many icsee cameras robicam.bg) → after you set camera via APP (icsee) then pressing 3 times reset button should put it in offline mode. i tried on mine, for now, still no success. but i plan to go in store for demonstration. As they promised it can work offline.
So 3 times pressing reset button.
