[add-on] HassOS I2C Configurator
Now I did a complete reinstallation of HassOS I2C Configurator with disabled protected mode and rebooted the device via power cord pull twice. I still get this protocol message from HassOS I2C Configurator:
brw-rw----    1 root     disk      254,   1 Jun  2  2022 zram1
brw-rw----    1 root     disk      254,   2 Jun  2  2022 zram2
ls: /dev/i2c-1: No such file or directory
I don't see I2C.
dtparam=i2c_vc=on
i2c already configured on sda1. Reboot required.
dtparam=i2c_arm=on
dtparam=i2c_arm=on
i2c already configured on sda1. This addon was already run during this boot and no reboot occurred.
mount: mounting /dev/sdb1 on /tmp/sdb1 failed: No such file or directory
no sdb1 config found
no mmcblk0p1 available
This Configurator did it's job. Perform a hard-power-off reboot now.
You will need to reboot twice total, once to place the files, and again to activate the I2C.
Any further idea?
Lets see the log directly after a pull-the-plug reboot.
Directly after a pull-the-plug reboot the HassOS I2C Configurator did not start automatically, although the start switch is on; I had to start it by hand. Then the protocol looks like this:
crw-------    1 root     root      247,   0 Jun  2  2022 watchdog0
crw-rw-rw-    1 root     root        1,   5 Jun  2  2022 zero
brw-rw----    1 root     disk      254,   0 Jun  2  2022 zram0
I don't see I2C.
dtparam=i2c_vc=on
dtparam=i2c_arm=on
dtparam=i2c_arm=on
Iā€™m not sure whatā€™s going on here, but its saying this is the second time the addon was run during this boot. Itā€™s detected this by looking for a file it places that is automatically removed by Home Assistant during HAOS boot up. For some reason your machine is not booting from the SDA or itā€™s not using this file, or it isnt able to write or delete that file.
Oh, my system boots from SSD. Maybe that causes the problem?
Is the SSD the sda drive?
Yes, it is.
That wouldnā€™t be the problem then. If its booting from sda, not microsd, and those files on are on sda1, they should be acted upon and removed by the OS at startup.
In /config.txt of my /dev/sda1 I find:
dtparam=i2c1=on
dtparam=i2c_arm=on
dtparam=i2c_vc=on
dtparam=i2s=on
and lsmod | grep i2c shows:
i2c_mux_pinctrl        16384  0
i2c_mux                16384  1 i2c_mux_pinctrl
i2c_bcm2835            16384  0
but there is still no i2c device:
# ls /dev/i2*
ls: /dev/i2*: No such file or directory
Maybe a hardware issue?
I added file named ā€˜rpi-i2c.confā€™ to the directory /etc/modules-load.d/ with following lines in it:
i2c-dev
i2c-bcm2835
Now I see i2c devices:
# ls -l /dev/i2*
crw-------    1 root     root       89,   0 Jun  2  2022 /dev/i2c-0
crw-------    1 root     root       89,   1 Jun  2  2022 /dev/i2c-1
crw-------    1 root     root       89,  10 Jun  2  2022 /dev/i2c-10
crw-------    1 root     root       89,  22 Jun  2  2022 /dev/i2c-22
And everything works fine :slight_smile:
Thanks a lot for your support, Adam!
Did you try something else prior to this? It seems it was 1/2 installed before you ran the app.
Yes, I tried to activate i2c by hand and uncommented the i2c related entries in my /config.txt before I found your tool. But I didnā€™n succeed . . .
This tool uses the commented entries to determine the need to apply the other files. If you had run it with the entries commented it would have worked fine.
Ok, I see. Next time I use your tool I leave the i2c entries commented. It would have been helpful if I had this information beforeā€¦ Thank you for your advice, Adam!
Updated faq. This is a new one.
Perfect, thanks!
Hello
My system appears only this log and does not change. Iā€™ve restarted twice and I donā€™t know whatā€™s wrong. My Argoone has a 256GB SSD
log:
I donā€™t see I2C.
mount: permission denied (are you root?)
Detected Protection Mode is enabled. Disable Protection Mode in Info Screen.
in sda1 config found
no sdb1 available
This Configurator did itā€™s job. Perform a hard-power-off reboot now.
Check the FAQ in the first post.
Sorry Iā€™m new to home assistant and I started a week ago. Iā€™m still getting familiar with everything. I informed you above that I use an SSD, but I was wrong. I use an M.2 as HD in Argoone.
I read all the posts and it didnā€™t help me.
