Tento instalar os Add-on e ate ai tranquilo. Porem nenhum inicia.
Confiro a documentação e esta ok
vejo o log apostentar iniciar e esta ok o log e gerado e nao aparece erro. Porem o app nao inicia.
ja tentei varios e nada.
Caso eu desistale um Add-on nao consigo fazer ele iniciar de novo.
tenho terminal instalado e se atravez dele eu conseguir zerar o home assistent ou deixar de “fabrica- exemplo”
tenho instalado o home assistente num Haspberry pi 4 de 8 GB com Uma NVme 256 gb em uma case Argon
I try to install the Add-ons and so far it’s ok. But none starts.
I check the documentation and it’s ok
I see the log start and it’s ok the log is generated and no error appears. But the app does not start.
I’ve tried several and nothing.
If I uninstall an Add-on I can’t make it start again.
I have a terminal installed and if through it I can reset the home assistant or leave “factory-example”
I have installed the home assistant on a Haspberry pi 4 of 8 GB with a NVme 256 gb in an Argon case
