Add support for Tesla Powerwall
Sorry, I meant to do this sooner, didnt want to keep posting without testing it a bit more. This updated version has been working for a couple of days without any issues. Calling it frequently seems to work and so does calling it twice a day.
The local api is now working in the ‘Tesla Powerwall’ component from the public release of HA (https://www.home-assistant.io/integrations/powerwall/)
The owners API from the Tesla component is also working: https://www.home-assistant.io/integrations/tesla/
And here is the updated version of the Tesla gateway to modify the operation:
Monitors and controls the Tesla gateway.
import logging
import aiohttp
import asyncio
import async_timeout
import base64
import hashlib
import json
import os
import re
import time
from urllib.parse import parse_qs
import voluptuous as vol
from homeassistant.const import (
    CONF_USERNAME,
    CONF_PASSWORD,
    CONF_ACCESS_TOKEN
from homeassistant.helpers.aiohttp_client import async_get_clientsession
import homeassistant.helpers.config_validation as cv
DOMAIN = 'tesla_gateway'
CONF_REFRESH_TOKEN = "refresh_token"
_LOGGER = logging.getLogger(__name__)
DEFAULT_TIMEOUT = 100
CONFIG_SCHEMA = vol.Schema({
    DOMAIN: vol.Schema({
        vol.Required(CONF_USERNAME): cv.string,
        vol.Required(CONF_PASSWORD): cv.string,
        vol.Optional(CONF_ACCESS_TOKEN, default=''): cv.string,
        vol.Optional(CONF_REFRESH_TOKEN, default=''): cv.string,
}, extra=vol.ALLOW_EXTRA)
tesla_base_url = 'https://owner-api.teslamotors.com'
tesla_auth_url = 'https://auth.tesla.com'
step_max_attempts = 7
step_attempt_sleep = 3
TESLA_CLIENT_ID = '81527cff06843c8634fdc09e8ac0abefb46ac849f38fe1e431c2ef2106796384'
@asyncio.coroutine
def async_setup(hass, config):
    # Tesla gateway is SSL but has no valid certificates
    websession = async_get_clientsession(hass, verify_ssl=False)
    domain_config = config[DOMAIN]
    conf_user = domain_config[CONF_USERNAME]
    conf_password = domain_config[CONF_PASSWORD]
    @asyncio.coroutine
    def SSO_login():
        # Code extracted from https://github.com/enode-engineering/tesla-oauth2/blob/e6922c6e7805d9f65c109d90c5eaf806c5b71938/tesla.py
        # Login process explained at https://tesla-api.timdorr.com/api-basics/authentication
        authorize_url = tesla_auth_url + '/oauth2/v3/authorize'
        callback_url = tesla_auth_url + '/void/callback'
        headers = {
            "User-Agent": "curl",
            "x-tesla-user-agent": "TeslaApp/3.10.9-433/adff2e065/android/10",
            "X-Requested-With": "com.teslamotors.tesla",
        verifier_bytes = os.urandom(86)
        code_verifier = base64.urlsafe_b64encode(verifier_bytes).rstrip(b"=")
        code_challenge = base64.urlsafe_b64encode(hashlib.sha256(code_verifier).digest()).rstrip(b"=").decode("utf-8")
        state = base64.urlsafe_b64encode(os.urandom(16)).rstrip(b"=").decode("utf-8")
        params = (
            ("client_id", "ownerapi"),
            ("code_challenge", code_challenge),
            ("code_challenge_method", "S256"),
            ("redirect_uri", callback_url),
            ("response_type", "code"),
            ("scope", "openid email offline_access"),
            ("state", state),
        try:
            # Step 1: Obtain the login page
            _LOGGER.debug('Step 1: GET %s\nparams %s', authorize_url, params)
            for attempt in range(step_max_attempts):
                with async_timeout.timeout(DEFAULT_TIMEOUT, loop=hass.loop):
                    response = yield from websession.get(authorize_url,
                        headers=headers,
                        params=params,
                        raise_for_status=False)
                returned_text = yield from response.text()
                if response.status == 200 and "<title>" in returned_text:
                    crsf_regex_result = re.search(r'name="_csrf".+value="([^"]+)"', returned_text)
                    if crsf_regex_result:
                        _LOGGER.debug('Step 1: Success on attempt %d', attempt)
                        break
                _LOGGER.warning('Step 1: Error %d on attempt %d, call %s:\n%s', response.status, attempt, response.url, returned_text)
                time.sleep(step_attempt_sleep)
            else:
                raise ValueError('Step 1: failed after %d attempts, last response %s:\n%s', step_max_attempts, response.status, returned_text)
            # Step 2: Obtain an authorization code
            csrf = crsf_regex_result.group(1)
            transaction_id = re.search(r'name="transaction_id".+value="([^"]+)"', returned_text).group(1)
            body = {
                "_csrf": csrf,
                "_phase": "authenticate",
                "_process": "1",
                "transaction_id": transaction_id,
                "cancel": "",
                "identity": conf_user,
                "credential": conf_password,
            _LOGGER.debug('Step 2: POST %s\nparams: %s\nbody: %s', authorize_url, params, body)
                    response = yield from websession.post(authorize_url,
                        headers=headers,
                        params=params,
                        data=body,
                        raise_for_status=False,
                        allow_redirects=False)
                if "We could not sign you in" in returned_text and response.status == 401:
                    raise ValueError('Step 2: Invalid credentials. Error %d on call %s:\n%s', response.status, response.url, returned_text)
                if response.status == 302 or "<title>" in returned_text:
                    _LOGGER.debug('Step 2: Success on attempt %d', attempt)
                    break
                _LOGGER.warning('Step 2: Error %d on call %s:\n%s', response.status, response.url, returned_text)
            else:
                raise ValueError('Step 2: failed after %d attempts, last response %s:\n%s', step_max_attempts, response.status, returned_text)
            is_mfa = True if response.status == 200 and "/mfa/verify" in returned_text else False
            if is_mfa:
                raise ValueError('Multi-factor authentication enabled for the account and not supported')
            # Step 3: Exchange authorization code for bearer token
            code = parse_qs(response.headers["location"])[callback_url + '?code']
            token_url = tesla_auth_url + '/oauth2/v3/token'
            body = {
                "grant_type": "authorization_code",
                "client_id": "ownerapi",
                "code_verifier": code_verifier.decode("utf-8"),
                "code": code,
                "redirect_uri": callback_url
            _LOGGER.debug('Step 3: POST %s', token_url)
                response = yield from websession.post(token_url,
                    headers=headers,
                    data=body,
            returned_json = yield from response.json()
            access_token = returned_json['access_token']
            domain_config[CONF_ACCESS_TOKEN] = access_token
            domain_config[CONF_REFRESH_TOKEN] = returned_json['refresh_token']
            return access_token
        except asyncio.TimeoutError:
            _LOGGER.warning('Timeout call %s.', response.url)
        except aiohttp.ClientError:
            _LOGGER.error('Client error %s.', response.url)
        return None
    @asyncio.coroutine
    def SSO_refresh_token():
        token_oauth2_url = tesla_auth_url + '/oauth2/v3/token'
        headers = {
        body = {
            "grant_type": "refresh_token",
            "refresh_token": domain_config[CONF_REFRESH_TOKEN],
            "scope": "openid email offline_access",
            response = yield from websession.post(token_oauth2_url,
                headers=headers,
                data=body,
        return access_token
    @asyncio.coroutine
    def OWNER_get_token(access_token):
        try:
            token_oauth_url = tesla_base_url + '/oauth/token'
            headers = {
                "authorization": "bearer " + access_token,
            body = {
                "grant_type": "urn:ietf:params:oauth:grant-type:jwt-bearer",
                "client_id": TESLA_CLIENT_ID,
                response = yield from websession.post(token_oauth_url,
                    headers=headers,
                    data=body,
            owner_access_token = returned_json["access_token"]
            return owner_access_token
        return None
    @asyncio.coroutine
    def OWNER_revoke(owner_token):
        revoke_url = tesla_base_url + '/oauth/revoke'
        headers = {'Content-type': 'application/json'}
        body = {
            'token': owner_token
        try:
                response = yield from websession.post(revoke_url,
                    headers=headers,
                    json=body,
            if response.status != 200:
                _LOGGER.warning('Error %d on call %s:\n%s', response.status, response.url, returned_text)
            else:
                _LOGGER.debug('revoke completed')
                return True
        return False
    @asyncio.coroutine
    def get_energy_site_id(owner_token):
        list_url = tesla_base_url + '/api/1/products'
        headers = {
            'Authorization': 'Bearer ' + owner_token
        body = {}
        try:
                response = yield from websession.get(list_url,
                    headers=headers,
                    json=body,
            else:
                for r in returned_json['response']:
                    if 'energy_site_id' in r:
                        return r['energy_site_id']
                return None
        return None
    @asyncio.coroutine
    def set_operation(owner_token,energy_site_id,service_data):
        operation_url = tesla_base_url + '/api/1/energy_sites/{}/operation'.format(energy_site_id)
        headers = {
            'Content-type': 'application/json',
        body = {
            'default_real_mode': service_data['real_mode'],
            'backup_reserve_percent':int(service_data['backup_reserve_percent'])
        try:
                response = yield from websession.post(operation_url,
                    json=body,
                    headers=headers,
            else:
                _LOGGER.debug('set operation successful, response: %s', returned_json)
    @asyncio.coroutine
    def get_owner_api_token():
        access_token = domain_config[CONF_ACCESS_TOKEN]
        if not access_token:
            access_token = yield from SSO_login()
        else:
            access_token = yield from SSO_refresh_token()
            return None
        owner_token = yield from OWNER_get_token(access_token)
        return owner_token
    @asyncio.coroutine
    def async_set_operation(service):
        owner_token = yield from get_owner_api_token()
        if owner_token:
            energy_site_id = yield from get_energy_site_id(owner_token)
            if energy_site_id:
                yield from set_operation(owner_token, energy_site_id, service.data)
            yield from OWNER_revoke(owner_token)
    hass.services.async_register(DOMAIN, 'set_operation', async_set_operation)
    return True
