Is this what you mean by that? the import is done successfully in an Custom Component sensor:
import homeassistant.helpers.config_validation as cv
from homeassistant.helpers.entity import Entity
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import (CONF_NAME)
from homeassistant.util import Throttle
from urllib.request import urlopen
from datetime import timedelta
import json
import argparse
import datetime
import logging
import voluptuous as vol
Yes, I have no clue how you are running your other file. Something is running it as an exec() string. What you have listed above is normal. When running through the exec() function, you need to pass the __import__ __builtin__ because it doesnāt perform imports. That cannot be done by you in the script, it has to be done by whatever is calling the exec().
well that sounds ominous⦠the only thing I can tell you the summary.py is in my /config/python_scripts, as defined in the configuration.yaml through:
python_script:
might not be related but still, in the same folder another python script is being used to extract the last_command and show that in the frontend. This script uses:
state = hass.states.get(entity_id)
dt = datetime.datetime.now() #state.attributes.get('last_triggered') #
time = "%02d:%02d" % (dt.hour, dt.minute)
and doesnāt need the +1 for the timezone correction.
Is that something i could use in cooperation with the last_triggered or last_changed, so i wont need to add +1?
The first shot is a custom string formatted for the user, the second two images are showing you exactly what they are as objects.
I think you just need to add a feature request and call it a day. I think you are beating a dead horse at this point. In a custom_script, you cannot get your current time zone time. You either need to move to a component, or appdaemon so you can properly get all the calls you need.
The reason they use UTC under the hood is because they have users all over the world. They will never change this. In yaml, they convert it to your time zone. In the custom_script they donāt because you are accessing their object.
Why am i telling you this? Because when you make a feature request, you need to ask for a custom_script enhancement that allows you to convert to your timezone, because they will never change their object because it would break for other users.
for entity_id in hass.states.get(lights_group).attributes['entity_id']:
# dt = hass.states.get('automation.sense_lights_change').attributes.get('last_triggered')
# dt = dt + datetime.timedelta(hours=+1)
# time = '%02d:%02d' % (dt.hour, dt.minute)
if hass.states.get(entity_id).state is 'on': #and entity_id not in excluded
lights_on.append(hass.states.get(entity_id).attributes["friendly_name"])
dt = state.last_changed
thus reading the last changed of the individual entities, rather than the triggered status of the automation. Error is goneā¦
only thing is, it doesnāt read the state for no lights on.
Trying this algorithm in an else : statement below this section doesnāt work. Would you be willing to help me one final timeā¦
how to make the script take the time when the state.lights_group.state goes from on to off (any light on to no lights on) and read that last_changed and set it to the timeā¦
my effort:
else:
state = hass.states.get(lights_group)
still, havent seen the errors since.
Only thing bugging now is the fact some of the entities arenāt populated at startup, leading to several Nonetypeās.
And the still existing issue of the daytime and daylight savings (have hours=2) at the momentā¦
Hello since the hassio 0.95 update one of my python script (from maattdiy(https://github.com/maattdiy) is not working with this error in the log:
Error executing script: %d format: a number is required, not NoneType
File "/usr/src/homeassistant/homeassistant/components/python_script/__init__.py", line 159, in execute
exec(compiled.code, restricted_globals, local)
File "summary.py", line 174, in <module>
TypeError: %d format: a number is required, not NoneType
