Adding Creality K1 Max to HA using Nodered (No root required)
Thank you for your reply.
I also thought about that and did not like the idea :confused:
However, I just enabled heartbeat at WS settings and now connection reestablishes by itself.
Hey @Spellbinder_4
Happy new year !
I’ve updated github with latest Nodered Workflow. I put the print job time and time left values as you asked
Take care
You’re a wizard!
Thank you :slight_smile:
Wondering if you could elaborate just a little more on what heartbeat is. I am running into the same issue but don’t want to restart the addon everytime.
Hey @TheOsirian ,
Open Nodered’s workflow and edit the K1 Server Listner then click on the pen to edit the settings
In the settings, tick the heartbeat and set a value as you like
I have mine setup for 10s and it works like a charm
Chris
hey can u share ur dashboard code pls
It’s a great script. Got it translated to Dutch, but this is based on the dashboard Chris showed in post 1. Installed the integration MJPEG IP Camera - Home Assistant he mentioned in post 2. Also put a Zigbee power plug to monitor the power for the printer called: sensor.smart_plug_3d_energy
Good luck with it
title: 3D printer
layout: {}
subview: false
visible:
cards: []
type: sections
badges:
  - type: entity
    show_name: false
    show_state: true
    show_icon: true
    entity: sensor.smart_plug_3d_energy
    color: ""
  - type: entity
    show_name: false
    show_state: true
    show_icon: true
    entity: sensor.smart_plug_3d_power
    color: ""
  - type: entity
    show_name: false
    show_state: true
    show_icon: true
    entity: sensor.k1_working_layer
    color: ""
  - type: entity
    show_name: false
    show_state: true
    show_icon: true
    entity: sensor.k1_total_layer_count
    color: ""
  - type: entity
    show_name: false
    show_state: true
    show_icon: true
    entity: sensor.print_progress
    color: green
sections:
  - type: grid
    cards:
      - type: heading
        heading: K1C
        heading_style: title
      - show_state: true
        show_name: true
        camera_view: live
        type: picture-entity
        entity: switch.k1_printer_light
        camera_image: camera.creality_3d_k1c
        grid_options:
          columns: full
        tap_action:
          action: perform-action
          perform_action: light.toggle
            device_id: 4fc80b153e547f52329d7f23ddc533f8
        visibility:
          - condition: state
            entity: switch.smart_plug_3d
            state: "on"
    column_span: 2
  - type: grid
    cards:
      - type: heading
        heading: Ventilator
      - type: tile
        entity: switch.side_fan
      - type: tile
        entity: switch.case_fan
      - type: tile
        entity: switch.model_fan
      - type: heading
        icon: mdi:thermometer
        heading: Temperatuur
      - type: tile
        entity: sensor.k1_nozzle_temp
        name: Nozzle temperatuur
      - type: tile
        entity: sensor.bed_temperature
      - type: tile
        entity: sensor.box_temperature
      - type: heading
        icon: ""
        heading: Verlichting
      - type: tile
        name: K1C printer licht
      - type: tile
        tap_action:
          action: toggle
max_columns: 3
Thing I like to add is a AI detection sensor. If my print fails I can send a notification to my phone
Thanks for all the info. I managed to get everything but my K2 Plus camera working properly with your setup. If anyone has any suggestions about the camera, please let me know.
Hello everyone,
Sorry for not getting back to you all, I as dealing with some health issues just back online today.
Thanks @Keizer23 for sharing.
@genomez, can you tell me what you tried for the camera and what is not working ?
As far as I am concerned, I added the camera using this integration, using these settings:
Full details can be found here
Cheers
Thanks for the response! I tried that integration as well as the generic camera integration. Apparently, the K2 must be a little different than the K1. The url to access just the camera is http://printer_ip:8000. None of the “?action=stream” part. Although I did try it that way and various other ports too.
I was able to get the various sensors and switched you had in your workflow, just not the camera.
Edited to add that the still image url did work for the K2 using the MJPEG IP Camera integration, just not the streaming. I still have more to do to the dashboard obviously lol.
Is the dashboard code for this available ??
Hey @genomez
You might be able to extract that using the developer view.
  • Open Chrome or Firefox and browse the IP of your printer
  • Open the developer tools and refresh the page
In my case, I have something like this. CameraView poped to mind straight away:
If you click on that line and go to the Payload tab, you might find the request URL
Hello @gaz99 ,
Here is mine, not edited since a couple of months, pretty sure not everything is working.
I’ve not had time to look at it lately
 - path: printer
    title: Printer
    icon: mdi:printer-3d
    sections:
      - type: grid
        cards:
          - type: heading
            heading: K1 Max
            badges: []
          - camera_view: auto
            type: picture-glance
            title: K1 Max
            entities:
              - entity: switch.k1_printer_light
            camera_image: camera.k1_max
            grid_options:
              columns: full
            aspect_ratio: '4:3'
        column_span: 1
        visibility:
          - condition: state
            entity: switch.3d_printer_switch_0
            state: 'on'
      - type: grid
        cards:
          - type: heading
            heading: Fan
            badges: []
            layout_options:
              grid_columns: 8
              grid_rows: 1
          - type: tile
            entity: switch.k1_printer_side_fan
          - type: tile
            entity: switch.k1_printer_case_fan
          - type: tile
            entity: switch.k1_printer_model_fan
          - type: tile
            entity: sensor.k1_used_material_length
          - type: heading
            heading: Temps
            badges: []
            layout_options:
              grid_columns: 8
              grid_rows: 1
          - graph: line
            type: sensor
            detail: 1
            hours_to_show: 12
          - graph: line
            type: sensor
            entity: sensor.k1_printer_bed_temperature
            detail: 1
            hours_to_show: 12
          - graph: line
            type: sensor
            entity: sensor.k1_printer_box_temperature
            detail: 1
            hours_to_show: 12
        column_span: 1
        visibility:
          - condition: state
            state: 'on'
    cards: []
    type: sections
    max_columns: 2
    badges:
      - type: custom:mushroom-template-badge
        content: |-
          {% if is_state('switch.3d_printer_switch_0', 'on') %}
          Ready to rumble
          {% else %}
          Having a nap
          {% endif %}
        icon: mdi:power-plug
        color: |-
          blue
          {% else %}
          red
          {% endif %}
        tap_action:
          action: more-info
        hold_action:
          action: toggle
        label: Socket
        picture: ''
      - type: entity
        show_name: false
        show_state: true
        show_icon: true
        entity: sensor.3d_printer_switch_0_energy
        color: ''
      - type: entity
        show_name: false
        show_state: true
        show_icon: true
        entity: sensor.3d_printer_switch_0_power
        color: ''
        visibility:
          - condition: state
            state: 'on'
        content: >-
          {% if is_state('sensor.k1_total_layer_count', '0') %}
          Not printing
          {% else %}
          {{states('sensor.k1_working_layer')}} /
          {{states('sensor.k1_total_layer_count')}}
          {% endif %}
        icon: mdi:layers
        color: |-
          red
          {% else %}
          green
          {% endif %}
        tap_action:
          action: more-info
        hold_action:
          action: toggle
        label: Layers
        picture: ''
        visibility:
          - condition: state
            state: 'on'
        content: |-
          {% if is_state('sensor.k1_printer_print_progress', '0') %}
          Paused
          {% else %}
          {{states('sensor.k1_printer_print_progress')}}%
          {% endif %}
        color: |-
          red
          {% else %}
          green
          {% endif %}
        tap_action:
          action: more-info
        hold_action:
          action: none
        label: Progress
        picture: ''
        entity: sensor.k1_printer_print_progress
        double_tap_action:
          action: none
        visibility:
          - condition: state
            state: 'on'
      - type: entity
        show_name: false
        show_state: true
        show_icon: true
        entity: sensor.k1_time_left
        color: ''
        visibility:
          - condition: state
            state: 'on'
I’ll check it later today and post what I find in case another K2 user finds this. Thank you!
Sorry, I meant to post this sooner in case someone else with a K2 stumbles in here. The only way I have found so far to get the video stream to show up on my dashboard is by adding a Webpage Card. Then you can enter http://Printer-IP:8000 into the URL field and see the stream if you are local.
HA did complain when I was logged into it via https (vs http) so I ended up adding a reverse proxy to handle the https so I can view it local or remote. Thanks again for all the pointers!
Thanks for this, I’ve got it working with my K1C however the filament used appears to be wrong, I am currently printing a simple coaster, orca slicer says the total print uses 11.18m of filament, the print is about 15% in and ‘K1 Used Material Length’ is showing i’ve used 43.7m of filament already. Is there something I need to change somewhere? does this figure show a used since the printer was turned on or used in current print?
Good morning @iamgrog68,
I’ll check that as soon as possible and let you know !
Hello @iamgrog68 !
Sorry for the delay getting back to you. I just got to test this out and as far as I can see, the K1 Max is sending this data on the websocket in mm. I therefore setup the same for the entity in NodeRed
I tried slicing a quick keyring to test things out and got these results :
  • Slicer advised 0.11m in Material lenght
  • Websocket is showing 127 Material Used
  • HA is showing 12.7 cm
So all in all, I think the setup is fine at least for the K1 Max, I would expect the K1C to be exactly the same but I can’t check that as I don’t have one
For me it resets each new print, hence the answer to your question, “current print”
thanks Chris, I will take another look next time I am printing.
If I can help in any way let me know
