I did, but not sure what I’m looking for?
It still lists the correct clothing combo, but no image.
Do you have this png in /www/josie folder?
Also, the created entity ends with “_2” - are you sure that you use same entity inside a Picture-entity card? And it is definitely not “sensor.josie_pjs”.
The images are here:
And I have the Unique ID as: unique_id: sensor.josie_pjs but for some reason that doesn’t show up?
The only sensor I can see that shows any info on the clothing is:
sensor.what_should_josie_wear_to_bed_2
That is the one that lists the clothing on my dashboard, I currently see:
This is the sensor information that is currently showing in the Developer Tools:
Now add this sensor to the picture-entity card. What you posted above is Entity card.
I get this:
As I said, cannot test myself.
Try adding this entity to Entities card - will you see an image then? (instead of icon)
Or just open more-info for this entity.
Also , just in case, remove everything from “picture: …” and set some image with a short name like “/local/josie/orange.jpg” (ofc this file should exist).
I altered the sensor back to this:
template:
- sensor:
- name: "What Should Josie Wear to Bed?"
icon: mdi:tshirt-crew
state: >-
{% set temp = states('sensor.bedroom_temperature_sensor_temperature') | float %}
{% if temp <= 16 %}
2 tog bag, Sleep suit, Long sleeve, Socks, Mittens, Hat
{% elif temp <= 17 %}
{% elif temp <= 19 %}
1 tog bag, Sleep suit, Long sleeve
{% elif temp <= 21 %}
1 tog bag, Sleep suit, Short sleeve
{% elif temp <= 23 %}
0.5 tog bag, Sleep suit
{% elif temp <= 25 %}
0.5 tog bag, Short sleeve
{% else %}
Short sleeve
{% endif %}
availability: "{{ 'sensor.bedroom_temperature_sensor_temperature' | has_value }}"
And then set the Picture Entitiy code to:
show_state: false
show_name: false
camera_view: auto
type: picture-entity
entity: sensor.what_should_josie_wear_to_bed
state_image:
2 tog bag, Sleep suit, Long sleeve, Socks, Mittens, Hat: /local/josie/2-tog-bag,-Sleep-suit,-Long-sleeve,-Socks,-Mittens,-Hat.png
2 tog bag, Sleep suit, Long sleeve, Socks: /local/josie/2-tog-bag,-Sleep-suit,-Long-sleeve,-Socks.png
1 tog bag, Sleep suit, Long sleeve: /local/josie/1-tog-bag,-Sleep-suit,-Long-sleeve.png
1 tog bag, Sleep suit, Short sleeve: /local/josie/1-tog-bag,-Sleep-suit,-Short-sleeve.png
0.5 tog bag, Sleep suit: /local/josie/0.5-tog-bag,-Sleep-suit.png
0.5 tog bag, Short sleeve: /local/josie/0.5-tog-bag,-Short-sleeve.png
Short sleeve: /local/josie/Short-sleeve1.png
And now finally, the pictures are displaying correctly:
Thanks for your help with this, we got there in the end!
Love this! Can you share the images please
I’ve attached them below. Sorry for the delayed response. Enjoy.
Brilliant! Thanks John
