i did it like you said - create new automation → switch to yaml and paste it there
Ok, it’s likely the hyphen before alias:
… that was from the original and is only required when pasting it to configuration.yaml
or automations.yaml
I’ve adjusted the automation configuration in my original post, so do a new copy/paste.
Ok did all what you said bite Alexa don’t answer the windows error in expiration
Stopped because an error was encountered at 29. Juni 2023 um 08:03:17 (runtime: 1.22 seconds)
Unable to find service notify.alexa_media_last_called
ok i set the delay little bit higher now the error dont occure.
but alexa answer nothing
i think your posted script above is not equal with this one:
tts_opened_windows:
alias: Notify - Alexa - List Open Windows
sequence:
- service: notify.alexa_media_last_called
type: tts
message: '{{active_windows}}'
variables:
active_windows: |-
{% set ow = expand('binary_sensor.all_window_sensors')
| selectattr('state','eq','on') |
map(attribute='entity_id') | map('area_name')
| unique | reject('eq',None) | sort | map('lower') | list %}
{% set qty = ow | count %}
{% if qty != 0 %}
There {{'is an' if qty==1 else 'are'}} open window{{' ' if qty==1
else 's '}}in the {{' and '.join((ow|join(', ')).rsplit(', ', 1)) }}.
{% else %}
All windows are closed.
{% endif %}
so i think alexa couldnt answer anything ? - my actual script is this:
alias: "Alexa Report"
- platform: state
entity_id: light.alexa_virtual
to: 'on'
condition:
- variables:
1: |-
{% set ow = expand('binary_sensor.all_window_sensors') | selectattr('state','eq','on') |
map(attribute='entity_id') | map('area_name') | unique | reject('eq',None) | sort | map('lower') | list %}
{% if qty != 0 %}
There {{'is an' if qty==1 else 'are'}} open window{{' ' if qty==1 else 's '}}in the {{' and '.join((ow|join(', ')).rsplit(', ', 1)) }}.
{% else %}
{% endif %}
- service: alexa_media.update_last_called
- delay: 1
type: tts
message: |-
{% set brightness = state_attr('light.alexa_virtual', 'brightness') %}
{% set id = (brightness | int(0) / 255 * 100 ) | round | string%}
{% if id in messages %}
{{ messages.get(id) }}
{% else %}
No value has been set for brightness level {{ brightness }}
{% endif %}
- delay: 1
- service: light.turn_off
data: {}
That error message indicates that HA can’t find the service. Check if the service call exists on your HA instance by using the Services tool in Developer Tools. If you paste notify.alexa_media_last_called
into the selection box you should be presented with:
If that does not show up, there is something wrong with your Alexa Media Player integration and you may need to delete the integration and reinstall it.
The script I posted has been tested and works…
I have changed now to that:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
alias: Alexa Report
- platform: state
to: 'on'
condition: null
data: {}
- delay:
hours: 0
minutes: 0
seconds: 3
milliseconds: 0
type: tts
messages: '{{1}}'
variables:
'1': |-
{% set ow = expand('binary_sensor.fenster') |
{% if qty != 0 %}
{% else %}
Nein alle Fenster sind zu
{% endif %}
- delay:
hours: 0
minutes: 0
seconds: 2
milliseconds: 0
data: {}
So i think its nearly working but i got following error at the end:
Stopped because an error was encountered at 29. Juni 2023 um 13:32:40 (runtime: 3.26 seconds)
extra keys not allowed @ data['type']
start over again… copied again your script now i have no error - but alexa says nothing in the logs after a start stand only output
message: No value has been set for brightness level 4
but i use “1”
shouldnt be stand here for example No Windows are open - which the alexa speaks ?
YES !!! I got it !! the problem is this
https://github.com/custom-components/alexa_media_player/issues/770
Weird… The automation I have (and tested yesterday) has round
and works without issue. I have updated the automation above and the A.M.P. wiki to use int
since that apparently works for everyone.
One last question! All of my Echos fire up the windows and answer only with one (and that’s the main echo) won’t work. In log the error appears:
Stopped because an error was encountered at 4. Juli 2023 um 07:57:51 (runtime: 2.18 seconds)
All other work
