Adding MQTT Devices without discovery
I am using Zigbee2MQTT and although it does an amazing job with discovery true, I have my all setup on yaml (so fare at least) and automated, I am trying to configure a MQTT sensor with the device information on it.
Even if I use the configuration as documented the device doesn’t appear in the device list and configuration doesnt show any warning or error.
Any clue what am I doign wrong?
- platform: "mqtt"
  unique_id: "0x00158d000232a9ad_linkquality_zigbee2mqtt"
  state_topic: "zigbee2mqtt/0x00158d000232a9ad"
  availability_topic: "zigbee2mqtt/bridge/state"
  json_attributes_topic: "zigbee2mqtt/0x00158d000232a9ad"
  unit_of_measurement: "lqi"
  value_template: "{{ value_json.linkquality }}"
  device_class: signal_strength
  device:
    identifiers: ["zigbee2mqtt_0x00158d000232a9ad"]
    manufacturer: "Xiaomi"
    model: "Aqara door & window contact sensor (MCCGQ11LM)"
    sw_version: "Zigbee2mqtt 1.12.2"
Mqtt devices show only in de device list when discovered. You should see it in the entities list.
yes, I see I misread the documentation, it will only work through discovery. :frowning:
Given that zigbee2mqtt supports Home Assistant’s MQTT Discovery, it’s advantageous to use it.
There is another option. You can continue to define the entity manually and use MQTT Discovery. Create a script that publishes the sensor’s configuration to the appropriate discovery topic.
For example, here’s a simple script that creates two binary_sensors via MQTT Discovery:
#script:
  create_entities:
    alias: Create entities via MQTT Discovery
      - service: mqtt.publish
          topic: homeassistant/binary_sensor/bathroom_door/config
          payload: '{"name": "Bathroom Door", "state_topic": "home/sensor1", "device_class": "door", "unique_id": "abc123xyz"}'
          retain: true
          topic: homeassistant/binary_sensor/hallway_motion/config
          payload: '{"name": "Hallway Motion", "state_topic": "home/sensor2", "device_class": "motion", "off_delay": 5, "unique_id": "jkl789mno"}'
          retain: true
In your case, payload’s value will need to be more complex. Here’s a partial example (you’ll need to complete it) of the payload:
'{"name": "frontdoor_contact_linkquality", "device_class": "signal_strength", "state_topic": "zigbee2mqtt/0x00158d000232a9ad", "unique_id": "0x00158d000232a9ad_linkquality_zigbee2mqtt", "device": {"identifiers": ["zigbee2mqtt_0x00158d000232a9ad"],"name": "0x00158d000232a9ad", "model": "Aqara door & window contact sensor (MCCGQ11LM)", "manufacturer": "Xiaomi", "sw_version": "Zigbee2mqtt 1.12.2"}}'
The topic will be:
homeassistant/sensor/frontdoor_contact_linkquality/config
Resulting (partial) example is this:
          topic: homeassistant/sensor/frontdoor_contact_linkquality/config
          payload: >
              "device": {
