@gieljnssns
@doune
i modified the custom netatmo platform so it works with 0.29.2
@gieljnssns and @jabesq
Thank you soooo much!!
I’m new and I want to start testing this module on my deployment. How is possible to install this module ? Can someone point me to some documentation on ho to deploy the dev env?
Thanks you so much
At the bottom are the instructions to update to dev version.
Thanks a lot for that.
Matteo
I have 4 Netatmo thermostat, and in HA it gest only 1 data.
Let me explain, in the HA homepage it shows all 4 thermostat correctly, but the reading is only of 1 thermostat copied also to the other 3 (which is a wrong data), and also changing the temperature in all 4 switch it changes only in 1.
Is it a bug? Can be fixed?
Do you also have 4 relays?
I will try to figure this out. But i have only 1 relay and 1 thermostat.
Yes 4 relays and 4 thermostats. I tried all combinations (insert RELAY and/or insert THERMOSTAT) but I end up having all 4 relay/thermostat but one reading only repeated on all 4 items (one is correct, the other 3 are of course wrong, ).
I hope I made myself clear. Ask me if you want to make me some tests
p.s. all 4 thermostat have different values in reality, but this is what I get in HA:
maybe using the right coordination of REALY and THERMOSTAT in climate: section?
If you direct me I will provide you test/logs, and so on.
Thanks!
I think i have to make changes in the lnetatmo file and the netatmo.py file in climate. When i have time i Will try to fix this. But i’m working night shifts wright now.
When i have somthing, i will post it so you can test.
thank you!!
Ho all,
how to set this thermostat to away mode?
This not work:
- alias: Thermostat to Away mode
platform: state
entity_id: groups.rodina
to: ‘not_home’
service: climate.set_away_mode
entity_id: ‘climate.thermostat’
value: ‘true’
Thanks!
J.
try like this:
automation:
platform: time
after: "07:15:00"
- service: climate.set_away_mode
entity_id: climate.kitchen
away_mode: true
@anon35356645
Can you test this? https://github.com/gieljnssns/My_Home-Assistant/tree/master/homeassistant
You have to replace the Thermostat.py file in deps/smart_home.
And paste the netatmo.py in custom_components/climate/
will do now. Newb here, I might ask you very silly questions …
- I have a directory deps/smart_home, so I replaced the Thermostat.py
- I don’t have the custom_componet directory, where shall I create it?
create it like this .homeassistant/custom_components/climate/netatmo.py
Done.
In deps directory there is a file
lnetatmo.py
shall I leave it there?
yes, it is needed
