Thanks - no joy, but here is the result of the log file. Assume it should have been âPowerViewShadeTiltAnywhereâ rather than âPowerViewShadeâ.
2022-05-20 16:22:44 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hunterdouglas_powerview_custom which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-05-20 16:23:02 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind C - Detected as [<class 'custom_components.hunterdouglas_powerview_custom.cover.PowerViewShade'>]
2022-05-20 16:23:03 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind L - Detected as [<class 'custom_components.hunterdouglas_powerview_custom.cover.PowerViewShade'>]
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind R - Detected as [<class 'custom_components.hunterdouglas_powerview_custom.cover.PowerViewShade'>]
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Raw data update: {'id': 53960, 'type': 51, 'capabilities': 2, 'batteryKind': 1, 'smartPowerSupply': {'status': 0, 'id': 0, 'port': 0}, 'batteryStatus': 4, 'batteryStrength': 180, 'roomId': 7666, 'firmware': {'revision': 2, 'subRevision': 5, 'build': 287, 'index': 280}, 'name': 'QmxpbmQgQw==', 'positions': {'posKind1': 1, 'position1': 65535, 'posKind2': 3, 'position2': 65535}, 'signalStrength': 4, 'groupId': 9209, 'name_unicode': 'Blind C'}
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind C - Update Position: {'posKind1': 1, 'position1': 65535, 'posKind2': 3, 'position2': 65535}
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Raw data update: {'id': 25921, 'type': 51, 'capabilities': 2, 'batteryKind': 1, 'smartPowerSupply': {'status': 0, 'id': 0, 'port': 0}, 'batteryStatus': 4, 'batteryStrength': 180, 'roomId': 7666, 'firmware': {'revision': 2, 'subRevision': 5, 'build': 287, 'index': 280}, 'name': 'QmxpbmQgTA==', 'groupId': 9209, 'positions': {'posKind1': 1, 'position1': 0, 'posKind2': 3, 'position2': 0}, 'name_unicode': 'Blind L'}
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind L - Update Position: {'posKind1': 1, 'position1': 0, 'posKind2': 3, 'position2': 0}
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Raw data update: {'id': 59321, 'type': 51, 'capabilities': 2, 'batteryKind': 1, 'smartPowerSupply': {'status': 0, 'id': 0, 'port': 0}, 'batteryStatus': 4, 'batteryStrength': 180, 'roomId': 7666, 'firmware': {'revision': 2, 'subRevision': 5, 'build': 287, 'index': 280}, 'name': 'QmxpbmQgUg==', 'signalStrength': 4, 'positions': {'posKind1': 1, 'position1': 0, 'posKind2': 3, 'position2': 0}, 'groupId': 9209, 'name_unicode': 'Blind R'}
2022-05-20 16:23:04 DEBUG (MainThread) [custom_components.hunterdouglas_powerview_custom.cover] Blind R - Update Position: {'posKind1': 1, 'position1': 0, 'posKind2': 3, 'position2': 0}
