Adding zigbee router causes issues with automation
Zigbee does not allow that, the network routing is done automatically. Just add more/better Zigbee Router devices and do everything you can to avoid interference, especially for the Zigbee Coordinator
Begin by following this to rule out both interference and lack of routers (you will probably have to buy and add more Zigbee Router devices regardless of your setup) → Zigbee networks: how to guide for avoiding interference and optimize for getting better range + coverage (weird symptoms are usually due to EMF interference from something so before doing anything else start by connecting the Zigbee Coordinator via a very long USB extension cable to get it far way from other devices, and be sure to only connect to to a USB 2.0 port, so connect it via a powered USB 2.0 hub if your computer only have USB 3.x ports. Know that USB 3.x ports and USB 3.x devices will cause serious EMF interference for Zigbee).
If that does not work then also consider upgrading the Zigbee Coordinator firmware to a later version.
