Adguard integration - multiple instances on HA Core?
Hi
Is there no way to add two Adguard home instances to HA core? It is not possible via the GUI integration method and I cannot see anything about manual configuration in the documentation.
I ran two Piholes for many years but decided to try out Adguard after seeing it was HA’s new choice of adblocker addon.
I really like it, but only being able to view/control one instance is a bit of a backwards step. It also means if I need to fully disable ad-filtering, I have to disable the primary instance via the Adguard filter switch and stop the secondary adguard container via HA as a workaround.
  • one for this
    Just moved from having two PiHole to two AdGuard Home installations. One being the add-on and the other running on docker on another RPI.
    Only one integration to control AdGuard Home from Home Assistant is allowed which is annoying.
The api is public. You could call command line switches with curl commands to enable/disable The filtering. You must need to know how to encode the authorization header. I’m on mobile but when I get to a computer I’ll see what I can link to you.
I just completed this and works like a charm.
I realize I’m a bit late to this party…
Here is how i implement multiple instance switches of aguard. the integration is flaky for me so i just hard coded some rest switches to turn on/off the protection, and then combine them into a template switch.
link to adguard api: https://github.com/AdguardTeam/AdGuardHome/blob/1e2e965ea78317ac28b3d8c51b7990c1714f76e2/openapi/openapi.yaml
switch:
  - platform: command_line
    switches:
      adguard_gonzo:
        command_on: >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'  -d '{"protection_enabled": true}' http://ipaddressofgonzo:8280/control/dns_config
        command_off: >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'  -d '{"protection_enabled": false}' http://ipaddressofgonzo:8280/control/dns_config
        friendly_name: "Adguard Gonzo"
        command_state:  >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'   http://ipaddressofgonzo:8280/control/dns_info
        value_template: "{{ value_json is defined and value_json.protection_enabled }}"
      adguard_pi:
        command_on: >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'  -d '{"protection_enabled": true}' http://ipaddressofpi:3000/control/dns_config
        command_off: >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'  -d '{"protection_enabled": false}' http://ipaddressofpi:3000/control/dns_config
        friendly_name: "Adguard Pi"
        command_state:  >-
          curl -H 'Authorization: Basic <<redacted authorization token>>'   http://10.9.209.182:3000/control/dns_info
    switches:
      adguard:
        friendly_name: "adguard"
        value_template: "{{ is_state('switch.adguard_pi', 'on') or is_state('switch.adguard_gonzo', 'on')}}"
        turn_on:
          service: switch.turn_on
            entity_id: switch.adguard_pi, switch.adguard_gonzo
        turn_off:
          service: switch.turn_off
Hi, any hints/links on how to get this?
https://github.com/AdguardTeam/AdGuardHome/tree/master/openapi
The authorization token is the base64data of the username password combo. I put them in an online encoder and used whatever spit out as the header token.
The link above point to another? zwift?
I have problems…
I have 2 adguards,
01 on 192.168.1.90
02 on 192.168.1.91
What is the correct API port? is this open by default?
I get errors in the log. Can I check the API in any way?
Using:
switch:
    switches:
      adguard_01:
        command_on: >-
          curl -H 'Authorization: Basic <<base64datahash>>'  -d '{"protection_enabled": true}' http://192.168.1.90:8280/control/dns_config
        command_off: >-
          curl -H 'Authorization: Basic <<base64datahash>>'  -d '{"protection_enabled": false}' http://192.168.1.90:8280/control/dns_config
        friendly_name: "Adguard 01"
        command_state:  >-
          curl -H 'Authorization: Basic <<base64datahash>>'   http://192.168.1.90:8280/control/dns_info
      adguard_02:
        command_on: >-
          curl -H 'Authorization: Basic <<base64datahash>>'  -d '{"protection_enabled": true}' http://192.168.1.91:3000/control/dns_config
        command_off: >-
          curl -H 'Authorization: Basic <<base64datahash>>'  -d '{"protection_enabled": false}' http://192.168.1.91:3000/control/dns_config
        friendly_name: "Adguard 02"
        command_state:  >-
          curl -H 'Authorization: Basic <<base64datahash>>'   http://192.168.1.91:3000/control/dns_info
    switches:
      adguard:
        value_template: "{{ is_state('switch.adguard_01', 'on') or is_state('switch.adguard_02', 'on')}}"
        turn_on:
            entity_id: switch.adguard_pi, switch.adguard_01
        turn_off:
Hi, is there any chance or any source where I could get some help with this? Thank you!
Can we just get the option to add two instances please?
any update?
There seems to be some movement on the multiple instances:
Just ran into this issue today switching from pi-hole… Any updates by any chance?
