hi may i know where can i get the “ID” from?
The value of the automation’s id
option can be whatever you want, as long as it’s different from any other automation.
Did you have found any solution? I am looking a solution to see on an separate sensor the next Prayer TIme.
i have now problem with fetching data and i think something breaks now with REST api. The sensors says unknown now. By me nothing was changed. What can be the problem?
@Himdola Still working fine for me.
@starnetworks FYI also interesting for you
See Diyanet Ezan in Home Assistant which I updated to reflect the latest changes.
For the next prayer sensor:
sensors:
next_prayer:
friendly_name: Next Prayer
value_template: >-
{% set state = states('sensor.time') %} {% if '00:00' <= state <
states('sensor.imsak') %} {{ states('sensor.imsak') }} {% elif
states('sensor.imsak') <= state < states('sensor.gunes') %} {{
states('sensor.gunes') }} {% elif states('sensor.gunes') <= state <
states('sensor.ogle') %} {{ states('sensor.ogle') }} {% elif
states('sensor.ogle') <= state < states('sensor.ikindi') %} {{
states('sensor.ikindi') }} {% elif states('sensor.ikindi') <= state <
states('sensor.aksam') %} {{ states('sensor.aksam') }} {% elif
states('sensor.aksam') <= state < states('sensor.yatsi') %} {{
states('sensor.yatsi') }} {% elif states('sensor.yatsi') <= state <
'23:59' %} {{ states('sensor.imsak') }} {% endif %}
Hi Salih, the code only generates eg. sensor.imsak but not sensor.imsak.vakti
Am I missing something?
@Salerg
rest:
method: GET
scan_interval: 172800
resource: "https://ezanvakti.herokuapp.com/vakitler/11421"
- name: Imsak
value_template: >-
{% for entry in value_json %} {% if entry.MiladiTarihKisa ==
now().strftime('%d.%m.%Y') %} {{ entry.Imsak }} {% endif %} {% endfor %}
- name: Ogle
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.Ogle }} {% endif %} {% endfor %}
- name: Ikindi
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.Ikindi }} {% endif %} {% endfor
- name: Aksam
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.Aksam }} {% endif %} {% endfor %}
- name: Yatsi
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.Yatsi }} {% endif %} {% endfor %}
- name: hicri
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.HicriTarihUzun }} {% endif %} {%
endfor %}
- name: Gunes
value_template: >-
now().strftime('%d.%m.%Y') %} {{ entry.Gunes }} {% endif %} {% endfor %}
I got this error on my logs and state is unknown with the DIyanet Prayer TIme api.
Logger: homeassistant.components.rest.sensor
Source: components/rest/sensor.py:170
Integration: RESTful (documentation, issues)
First occurred: April 18, 2023 at 10:59:11 PM (3 occurrences)
Last logged: 12:59:11 PM
Empty reply found when expecting JSON data
AND
Logger: homeassistant.components.rest.data
Source: components/rest/data.py:85
Error fetching data: http://localhost:1453/api/dailyPrayerTimes/12345 failed with All connection attempts failed
After one month of trying to figure out how to get the times correct, I finally figured it all out today
Just remove the current addon and anything else you have with it and add the following to configuration.yaml (dont forget to change the number to your city)
rest:
method: GET
- name: Imsak
device_class: timestamp
value_template: "{{ today_at(value_json|selectattr('MiladiTarihKisa','eq',now().strftime('%d.%m.%Y'))|map(attribute='Imsak')|first) }}"
- name: Ogle
value_template: "{{ today_at(value_json|selectattr('MiladiTarihKisa','eq',now().strftime('%d.%m.%Y'))|map(attribute='Ogle')|first) }}"
- name: Ikindi
value_template: "{{ today_at(value_json|selectattr('MiladiTarihKisa','eq',now().strftime('%d.%m.%Y'))|map(attribute='Ikindi')|first) }}"
- name: Aksam
value_template: "{{ today_at(value_json|selectattr('MiladiTarihKisa','eq',now().strftime('%d.%m.%Y'))|map(attribute='Aksam')|first) }}"
- name: Yatsi
value_template: "{{ today_at(value_json|selectattr('MiladiTarihKisa','eq',now().strftime('%d.%m.%Y'))|map(attribute='Yatsi')|first) }}"
template:
- binary_sensor:
- name: Imsak is now
state: "{{ as_datetime(states('sensor.imsak')).strftime('%H:%M') == states('sensor.time') }}"
- name: Ogle is now
state: "{{ as_datetime(states('sensor.ogle')).strftime('%H:%M') == states('sensor.time') }}"
- name: Ikindi is now
state: "{{ as_datetime(states('sensor.ikindi')).strftime('%H:%M') == states('sensor.time') }}"
- name: Aksam is now
state: "{{ as_datetime(states('sensor.aksam')).strftime('%H:%M') == states('sensor.time') }}"
- name: Yatsi is now
state: "{{ as_datetime(states('sensor.yatsi')).strftime('%H:%M') == states('sensor.time') }}"
The binary_sensor.imsak_is_now will show “On” when the time is correct and “Off” when it is not.
But what I have done is created 5 different automations using each ezan entity to play a different ezan.
alias: Ezan - Sabah
description: ""
- platform: time
at: sensor.imsak
condition: []
- service: media_player.volume_set
volume_level: 0.6
entity_id: media_player.living_room
- service: media_player.play_media
media_content_id: >-
media-source://media_source/local/Sabah Ezanı (Saba Makamı) - Nurettin
Okumuş.mp3
media_content_type: audio/mpeg
metadata:
title: Sabah Ezanı (Saba Makamı) - Nurettin Okumuş.mp3
thumbnail: null
media_class: music
children_media_class: null
navigateIds:
- media_content_type: app
media_content_id: media-source://media_source
mode: single
@Zotech I have answered you already. But anyways, including you here
@Himdola As Zotech mentioned.
I have updated the website to be complete now. Additionally I share my complete automation with comments in the code. See the website: https://ergezen.nl/Diyanet-Ezan-in-Home-Assistant-7186fe119843435d802ca3c0b71f1c5f
Specifically sharing the link, as it is rather long. No problem to share code snippets here and or further discuss.
Also shared the UI element I created to display nicely the relevant prayer times.
That is one intense automation code, well done!
Does your source web site has all the times for USA, state and cities?
I see ABD (USA) is included. These are diyanet times only. So most likely only relevant if you are Turkish…
Thank you. I am not Turkish but I was interested in Imsak notification and would love to implement it in my setup from the Islamic prayer times integration.
I have been trying to scrape my local website for timings for the past few weeks and just cant get my head around how to get it to work. I have managed to scrape the time which shows as 4:57 am but can not get it to format as a timestamp. This is my code:
scrape:
- resource: https://www.noorulislam.org.uk
- name: "Fajr_Prayer_Time"
select: "tr"
index: 2
value_template: '{{ value.split("am")[0] }}'
The value template for this is:
value_template: >
{{ strptime(states('sensor.fajr_prayer_time'), '%I:%M %p').strftime('%H:%M') }}
This turned out to be a bit messy, as the HTML in that table is a long way from standards-compliant. The data is in the third <tr>
element, but the mess of <td>
and <th>
tags make it impossible to scrape any further.
Scraping that <tr>
element gives this (for today):
Begins4:07 am5:42 am1:04 pm5:58 pm8:16 pm9:29 pm
So we’ll configure our sensors to pull out those times, with the second time being sunrise. The regex pattern is looking for an optional 1 (in e.g. 10:15 am) followed by digit:digit digit then am or pm. It should find all six as a list, so we just need to tell each sensor which one it’s using.
scrape:
- name: "Fajr Prayer Time"
select: "tr"
index: 2
value_template: '{{ today_at(strptime((value|regex_findall("(1?\d:\d\d\ [ap]m)"))[0], "%I:%M %p").strftime("%H:%M")) }}'
- name: "Zuhr Prayer Time"
select: "tr"
index: 2
value_template: '{{ today_at(strptime((value|regex_findall("(1?\d:\d\d\ [ap]m)"))[2], "%I:%M %p").strftime("%H:%M")) }}'
- name: "Asr Prayer Time"
select: "tr"
index: 2
value_template: '{{ today_at(strptime((value|regex_findall("(1?\d:\d\d\ [ap]m)"))[3], "%I:%M %p").strftime("%H:%M")) }}'
- name: "Maghrib Prayer Time"
select: "tr"
index: 2
value_template: '{{ today_at(strptime((value|regex_findall("(1?\d:\d\d\ [ap]m)"))[4], "%I:%M %p").strftime("%H:%M")) }}'
- name: "Isha Prayer Time"
select: "tr"
index: 2
value_template: '{{ today_at(strptime((value|regex_findall("(1?\d:\d\d\ [ap]m)"))[5], "%I:%M %p").strftime("%H:%M")) }}'
This assumes sunrise is always in between Fajr and Zuhr. If that’s not the case, it gets a bit more difficult but not impossible.
Also, you can create these sensors via the UI:
Settings / Devices & Services / Integrations (at the top) / Add integration / Scrape
Brother you dont understand how much i appreciate your post. I’ve been trying to figure this out for weeks losing my sleep. Thank you so much!
I managed to get the timings separated by using this code which looked for the td tables, however the code you provided worked instantly and can not thank you enough.
scrape:
select: "td"
index: 1
value_template: "{{ strptime(states('sensor.fajr_prayer_time'), '%H:%M %p').strftime('%H:%M %p') }}"
Nice!
Where do you get the icons from?
