Adhan Automation (الأذان التلقائي للصلاة) using google speaker
Dear Sahar. @msahar Alhamdulihah
Thank you for the time you have put in and for the quick responses.
I like this automation the best. (
…value_template: >
{%- set a = states(“sensor.islamic_prayer_time_fajr”).split(“T”)[1].split(":")[0] -%}…)
got it set up perfectly.
Can you please assist with following:
  1. as how to do time offset in this version
  2. I am sure i can figure our Fajr as a separate action, so will do that
  3. How to implement Hanafi chool calculation (if that’s not possible, I’ll use the offset to estimate)
    Thank you
    Khaleel
@Sodz wa alikum salam,
You can modify this line for Fajr in your automation.yaml file
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S")) }}'
To
value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_fajr"), "%Y-%m-%dT%H:%M:%S"))+3600 }}'
Note there is 3600 in above line, this means a delay of 3600 seconds. You can adjust it accordingly.
I am not sure about this, however you can play around this line in your configuration.yaml file. Change mwl or any other thing to karachi, like below.
calculation_method: karachi
Thank you! will look into it.
I want to schedule morning and evening adhkar eg. morning adhkar at sunrise and evening adhkar 20 minutes before sunet.
what script can i use to automate this?
Got it right. used hybrid of the 2 - original code and the one where the times appear on the overview card.
For now Hanafi asr has no option so added time offest
Below is an example of Morning Azkar 10 seconds after sunrise.
################### Morning Azkar ###################
- action:
  - data:
      entity_id: media_player.sahar_google_mini   # replace with your Google Home's id
      media_content_id: https://myhomepi.tk:8123/local/azkaar.mp3   # replace with your choice of Adhan
      media_content_type: audio/mp3
    service: media_extractor.play_media
  - data:
      volume_level: '0.2'
    service: media_player.volume_set
  alias: Evening Azkaar
    - platform: sun
      event: sunrise
      offset: "00:00:10"
Can you please post here what you did to make that right so that other people may get benefit from it? JazakAllah.
for the configuration.yaml, I used your supplementary code which included sensors showing the actual time on a card on overview:
herewith:
 # Sensors
  - platform: time_date
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'time_date'
  - platform: islamic_prayer_times
    sensors:
      - fajr
      - dhuhr
      - asr
      - maghrib
      - isha
    sensors:
      salah_fajr:
        friendly_name: "Salah Fajr"
        value_template: >
           {%- set a = states("sensor.islamic_prayer_time_fajr").split("T")[1].split(":")[0] -%}
           {%- set b = states("sensor.islamic_prayer_time_fajr").split("T")[1].split(":")[1] -%}
           {{ a + ":" + b }}
      salah_dhuhr:
        friendly_name: "Salah Dhuhr"
        value_template: >
           {%- set a = states("sensor.islamic_prayer_time_dhuhr").split("T")[1].split(":")[0] -%}
           {%- set b = states("sensor.islamic_prayer_time_dhuhr").split("T")[1].split(":")[1] -%}
           {{ a + ":" + b }}
      salah_asr:
        friendly_name: "Salah Asr"
        value_template: >
           {%- set a = states("sensor.islamic_prayer_time_asr").split("T")[1].split(":")[0] -%}
           {%- set b = states("sensor.islamic_prayer_time_asr").split("T")[1].split(":")[1] -%}
           {{ a + ":" + b }}
      salah_maghrib:
        friendly_name: "Salah Maghrib"
        value_template: >
           {%- set a = states("sensor.islamic_prayer_time_maghrib").split("T")[1].split(":")[0] -%}
           {%- set b = states("sensor.islamic_prayer_time_maghrib").split("T")[1].split(":")[1] -%}
           {{ a + ":" + b }}
      salah_isha:
        friendly_name: "Salah isha"
        value_template: >
           {%- set a = states("sensor.islamic_prayer_time_isha").split("T")[1].split(":")[0] -%}
           {%- set b = states("sensor.islamic_prayer_time_isha").split("T")[1].split(":")[1] -%}
           {{ a + ":" + b }}
For the automations.yaml,
I saw that you still had the original sensors in the configuration, so I reverted to you original code:
Herewith the code for the 4 triggers except Fajr:
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_dhuhr"), "%Y-%m-%dT%H:%M:%S")) }}'
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S"))+3000 }}'
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S"))+180 }}'
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_isha"), "%Y-%m-%dT%H:%M:%S")) }}'
I offset Asr by 50min to adjust for HAnafi time. its not exact, but close enough for at least 3 months in my location
I offset Magrib by 3 min because the Magrib sensor seems to actually calculate sunset. I allowed for the usual 3 minutes to allow the sundisk to fully clear the horizon at my altitude
for the Fajr automation, the only reason I separated was to find the appropriate Azaan MP3 file. haven’t yet found one that I like, but herewith the code in the automations.yaml (same as your code):
but I found your supplemental code works just as well, but I cannot find a way to offset the time in this code:
      value_template: "{{ states('sensor.salah_fajr') == states('sensor.time') }}"
Hope this helps:
Its all your work though, Thank you
so on raspberry pi u can turn that thing off after all have been set correctly?
No. Anything you installed hassio on should need to be running all the time. Raspberry pi consume less electricity that why many people prefer it. You can buy raspberry pi zero W which only costs few bucks .
Jazakallah khayr
One more request, probably an easy one but I’m new to hassio so getting my head around it.
I want to automate Surah kahf every Friday at 11am etc
Possibly play Surah baqarah after Isha adhan to protect the house
Would appreciate if you can provide code. May Allah increase you and accept your khayr. I’m delighted as been looking into this for so long.
There’s is a USA company called masjidal who have created a system based on adhan playing at home, all cloud based. Worth looking into
Worked great for me. May Allah Bless you with health, wealth and happiness. for those interested i setup hassio on a Ubuntu Server within Docker.
Ubuntu and Docker Guide
Installing Hassio on Ubuntu/Docker Guide
My config
homeassistant:
  latitude: 53.4333542
  longitude: -2.1790891
  unit_system: metric
  time_zone: Europe/London
default_config:
discovery:
media_extractor:
sun:
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
    calculation_method: mwl
    sensors:
      - fajr
      - sunrise
      - dhuhr
      - asr
      - maghrib
      - isha
      - midnight
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
````Preformatted text`
My automation
# Automation for 5 times Azan
- action:
  - alias: 'Azan'
      entity_id: media_player.family_room_speaker
      media_content_id: https://sndup.net/63kw/Azan.mp3
  - data:
      volume_level: '0.9'
  alias: Adhan
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S")) }}'
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_maghrib"), "%Y-%m-%dT%H:%M:%S")) }}'
### Restart HA to force update Islamic Time Sensors at 1AM ###
- alias: Restart HA
    platform: time
    at: "01:00:00"
    - service: homeassistant.restart
Great work @Atif_Javaid
JazakAllah
Amended automation to take account of Hanafi Asr time calculation (set to an hour offset). I’m am not sure if this has worked yet as it is not time for Asr yet in the UK. I will update if it worked. Also the amended automation has now been amended to play a different Adhaan for Fajr.
# Automation for 4 times Azan
- action:
  - alias: 'Azan'
  - data:
      volume_level: '0.9'
  alias: Adhan
      value_template: '{{ as_timestamp(strptime(states("sensor.time_date"), "%H:%M, %Y-%m-%d")) == as_timestamp(strptime(states("sensor.islamic_prayer_time_asr"), "%Y-%m-%dT%H:%M:%S"))+3600 }}'
- action:
  - alias: 'Azan Fajr'
      media_content_id: https://sndup.net/7wzz/adhanfajr.mp3
  - data:
      volume_level: '0.9'
  alias: AdhanFajr
- alias: Restart HA
    platform: time
    at: "01:00:00"
setting the offset worked great.
Jazakallah Kheir to all for their wonderfull work with the automation of the athan.
I have set the automation to run on a number of Google home mini and google displays.
My question is, isnt the audio suppose to be synced between them all? I mean when the athan starts which is running as an mp3 file from the www there is a nano sec delay between the devices so the are out of syncs. Something I am doing wrong?
@taimur
the automation’s run in sequence. the delay you are seeing is a result of this. i.e. if it takes a nano second between running each automation then the delay between each speaker will be a nano second. you could try adding a delay. for example
device 1 delay 0.3s
device 2 delay 0.2s
device 3 delay 0.3s
i don’t have multiple devices so cannot check this.
How many devices are you running? Please share your automation file.
there is 3 in total, I wanna add more but only if its synced.
- action:
  - alias: 'Azan'
      entity_id: media_player.bedroom_speaker
      media_content_id: http://www.taimur.co.uk/software/Athan.mp3
  - data:
      volume_level: '0.9'
      entity_id: media_player.living_room_display
  - data:
      volume_level: '0.9'
      entity_id: media_player.kitchen_speaker
  - data:
      volume_level: '0.9'
  alias: Adhan
- alias: Restart HA
    platform: time
    at: "01:00:00"
