All good, as long as it’s solved!
And thanks for reporting back, that’s unfortunately not the standard behaviour!
Same here error solved after submit repair🙂
Great blueprint. What would be the best way to send a notification to parents phones based on the action selected from the alert based off this blueprint?
You can check the state of the input_boolean, if it’s still off at x hours, you can trigger a notification ?
Thanks, but would that show taken, skipped, remind later though?
I dont understand, you want send a notification to your parents according to what is answered on a notification on your phone?
Or just send the notification on your parents’ phone?
What I am trying to accomplish is a notification to send to my phone when my kid takes their medication. So I get a notification if they took it, skipped it or delayed it. So the Blueprint notification goes to their phone. They select taken. I get a notification on my phone based on the answer they selected on their phones notification.
This is great, thank you. Would it be possible please to have the option to specify the notification channel for android so that I can set different notification sounds for each med/water?
you can add an action for each statement (https://github.com/Aohzan/hass-blueprints/blob/87209ae2617b8523e5779a02214a19a946252ed6/blueprints/medication_reminder_android.yaml#L153 , 162, 172)
you can edit the blueprint to customize it
Is it possible to have this only notify you if you’re in the home zone?
This has been a very useful blueprint. I like the “optional” items which makes it quite expandable for doing something after the automation has run through (it seems to me)
Instead - how would I change the blueprint such that “optional” happens after “taken” is pressed on the notification" rather than after the automation has run?
I tried created an “optional_action_2” and putting it under
conditions: '{{ wait.trigger and wait.trigger.event.data.action == ''taken''}}'
but could not figure out how to place it in a sequence.
Anyway - thanks
hello, you can put the action before the choose : https://github.com/Aohzan/hass-blueprints/blob/87209ae2617b8523e5779a02214a19a946252ed6/blueprints/medication_reminder_android.yaml#L143
Thanks.
I also got it to work by adding a service call to a script under taken.
Lovely blueprint - thanks
Actually after some testing, if I move the the optional iems to the location you indicated, the actions listed as optional fire for all the wait triggers - taken, later and skip.
Where would I put it just for the taken trigger?
between 153 and 154
Thanks - Sorry. That’s what I was thinking when I started as ‘taken’ was the conditions trigger I was waiting for. But I couldn’t figure out how to put the optional_action_rtaken choose/condition stament inside the trigger taken choose/conditions - if that makes sense.
But your first suggestion worked when I placed it like code below which runs the optional_action_taken (eg increment counter) for all the taken, later and skip
- choose:
- conditions: '{{ true }}'
sequence: !input optional_action_taken
- choose:
- conditions: '{{ wait.trigger and wait.trigger.event.data.action == ''taken''
sequence:
entity_id: !input input_boolean
- service: logbook.log
name: !input notification_title
message: !input logbook_message_taken
What I can’t figure out is how do I put it between 153-154 to run . The whole choose staement inside the choose statement gives me an error
- choose:
sequence:
... as above
How does this go here which is line 153-154? This doesn't work
again thanks for your help. This is my first crack at blueprints and just trying to get my head around them.
In the meantime I have added an input
script_target:
description: Script to run when pill has been taken
selector:
entity:
filter:
- domain: script
and added it to the waittrigger taken like this
- choose:
sequence:
- service: !input script_target
metadata: {}
message: !input input_boolean
depending on the boolean passed in I can fire off different actions from the script.
But it would be nice to do it in the UI with the optional_action_token ![]()
I also use HA to track my medication stocks. For example I created a sensor named ‘counter.medication_1’ using helpers function, so whenever I press ‘taken’ it decrements 1 medication from total medications I set manually. This way I can tell when to call my pharmacy!
Great idea. Going to give it a go right now. What card is that?
