HI, lots of google searching!
I’m not sure about the 2 button thing as I only have 1. Perhaps the spec will tell you if that’s a possibility. I’m sure with the notations in the spec you should be able to relate that to my instructions and work out how to do it (if it’s possible).
I Looked at the spec, and it looks like Endpoint 3 is remote 1, and Endpoint 4 is remote 2, so I would assume that individual tones and volumes could be set by specifying the appropriate endpoints when sending commands via Z-Wave to the doorbell6.
I had read the tech manual a while back and saw those endpoints but I wasn’t smart enough to dig thru the hex codes and break down what parts needed sent for which functions.
Maybe I’ll give it another try when I get a chance.
