Alarm Clock as a package
Hi - is this currently the best/most developed wake up alarm for Home Assistant? I couldn’t really find a great deal else.
I’m interested in using your code (thank you) is there any way to repair the YAML idents or is it just a case of going through it line by line and adding? Happy to do so if that’s the way! :slight_smile:
alarm_1.yaml (4.4 KB)
Here’s the yaml file. You need to make sure the platform time sensor is somewhere in your homeassistant setup.
  • platform: time_date
    display_options:
    • ‘time’
FYI: For persistant Settings between HA restarts, just remove initial setting:
input_number:
  alarm_weekday_hour:
    icon: mdi:timer
#    initial: 7            <--------------- disable me ;-)
    min: 0
    max: 23
    step: 1
#    mode: box
input_boolean:
  alarm_weekday_enabled:
#    initial: off           <--------------- disable me ;-)
EDIT: It may also depend if you have recorder component enabled in HA configuration:
# https://www.home-assistant.io/components/recorder/
recorder:
Struggeled with this some time myself, here is copy and paste :wink:
  - platform: time_date
    display_options:
      - 'time'
I’ve noticed the alarm is sometimes triggered on point but most of the time one minute late.
Even with:
automation:
  - id: 'alarm_clock_weekday'
    alias: Alarm Clock Weekday
    - platform: time_pattern
      minutes: /1
      seconds: 1           <--------------------------- 0, 1 or 5 makes no differents
This is my Version. No fancy Fade. Alarm Setting for Weekdays and Weekend.
Works as a package.
Tested on HA 0.88.1 - 0.89.2 and Lovelace.
automation:
      minutes: /1
      seconds: 1
    condition:
    - condition: state
      entity_id: input_boolean.alarm_weekday_enabled
      state: 'on'
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
    - condition: template
      value_template: '{{ states.sensor.time.state == states.sensor.alarm_weekday_time.state }}'
      entity_id: switch.sonoffbasic1
      service: switch.turn_on
  - id: 'alarm_clock_weekend'
    alias: Alarm Clock Weekend
      minutes: /1
      seconds: 1
    condition:
    - condition: state
      entity_id: input_boolean.alarm_weekend_enabled
      state: 'on'
    - condition: time
      weekday:
      - sat
      - sun
      value_template: '{{ states.sensor.time.state == states.sensor.alarm_weekend_time.state }}'
input_number:
  alarm_weekday_hour:
    icon: mdi:timer
#    initial: 8
    min: 0
    max: 23
    step: 1
#    mode: box
  alarm_weekday_minutes:
    icon: mdi:timer
#    initial: 0
    min: 0
    max: 59
    step: 1
#    mode: box
  alarm_weekend_hour:
    icon: mdi:timer
#    initial: 10
    min: 0
    max: 23
    step: 1
#    mode: box
  alarm_weekend_minutes:
    icon: mdi:timer
#    initial: 0
    min: 0
    max: 59
    step: 1
#    mode: box
input_boolean:
#    initial: off
    icon: mdi:calendar
  alarm_weekend_enabled:
#    initial: off
    icon: mdi:calendar
    sensors:
      alarm_weekday_time:
          friendly_name: 'Alarm Time Weekdays'
          value_template: >-
              {{ "%0.02d:%0.02d" | format(states("input_number.alarm_weekday_hour") | int, states("input_number.alarm_weekday_minutes") | int) }}
      alarm_weekend_time:
          friendly_name: 'Alarm Time Weekend'
          value_template: >-
              {{ "%0.02d:%0.02d" | format(states("input_number.alarm_weekend_hour") | int, states("input_number.alarm_weekend_minutes") | int) }}
    display_options:
      - 'time'
# Optional
#group:
#  alarm_1:
#    name: Alarm Clock
#    entities:
#      - input_boolean.alarm_weekday_enabled
#      - sensor.alarm_weekday_time
#      - input_number.alarm_weekday_hour
#      - input_number.alarm_weekday_minutes
#      - input_boolean.alarm_weekend_enabled
#      - sensor.alarm_weekend_time
#      - input_number.alarm_weekend_hour
#      - input_number.alarm_weekend_minutes
#      - sensor.time
# If not enabled elsewhere:
#  time:
#    name: Time
#    entities:
#      - time_date.time
I think you might like this :
Universal Persistent Timer
It can add a timer to anything including multiple scripts, lights etc. with separate start and stop actions, and will resume in the event of downtime and requires no programming skills once installed. All lights, switches etc can be accessed from auto populated lists; and you can specify days of the week, repetitions, intervals, and much more. Timers can be paused, backed up and give activation notifications etc.
https://youtu.be/rUeTIU1uAP0
@skalavala, I could not load your package, I get the following error:
Invalid config for [automation]: required key not provided @ data['action']. Got None
required key not provided @ data['trigger']. Got None. (See ?, line ?). Please check the docs at https://home-assistant.io/components/automation/
I added the custom component input_label.py, what could I be doing wrong?
Would please share your configuration on the last line of the alarm_1.yaml?
  • data: {}
    service: script.bedroom_sunrise
I would like to use a similar setup whereby my light increases incrementally in brightness half an hour before the alarm :slight_smile:
i’m getting errors on the sensor from @bott0r
when checking the config i get these messages.
what can i do about it?
Invalid config for [sensor.template]: [friendly_name] is an invalid option for [sensor.template]. Check: sensor.template->friendly_name. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
Invalid config for [sensor.template]: [entity_id] is an invalid option for [sensor.template]. Check: sensor.template->entity_id. (See ?, line ?). Please check the docs at https://home-assistant.io/components/sensor.template/
someone that can help me?
I’m looking for a script similar to this… but I’m wondering how often does this check to see when the alarm goes off or if the configuration of alarms.yaml is changed. Because I’m a shift worker and my shifts are ALWAYS different, I wrote a script to calculate what time I need to leave (depending on my current location). Because this changes frequently and sometimes with little notice, my script outputs it to MQTT and a webpage with JSON, with a UNIX timestamp and the actual 24hr clock time. I was wondering if it were possible to modify this to be able to read this and trigger an alarm, then I would be able to install this into my HA.
can some past the link to all the code and package?
Thanks a lot for this post! I took your idea and made some changes/additions. Figured I’d share in case anyone is interested. The biggest difference is that I got rid of the offset. I didn’t see any use for it in my scenario. I also made some automations that automatically increases the hour when the minutes reach 60. The reason for this is to create a snooze function. I can snooze the alarm and increase the time incrementally. The hour needed to increase automatically for this to work.
I also have a couple of automations in there that checks my work schedule if I haven’t set an alarm and I have to work in less than 8 hours. Since I’m stupid and forget all the time.
input_number:
#This sets the hour value for the alarm clock. Set to max 24 to allow for automatic advancing by minutes.
  alarm_1_hour:
    icon: mdi:timer
    min: 0
    max: 24
    step: 1
#This sets the minutes value for the alarm clock. Advances hour upon reaching 60
  alarm_1_minutes:
    icon: mdi:timer
    min: 0
    max: 60
    step: 1
input_boolean:
#Alarm clock on/off switch
  alarm_1_enable:
#Returns the time the alarm is set for in hh:mm
    sensors:
      alarm_1_time:
        friendly_name: 'Alarm Time'
        value_template: >-
          {{ "%0.02d:%0.02d" | format(states("input_number.alarm_1_hour") | int, states("input_number.alarm_1_minutes") | int) }}
#Basic time/date sensors for Home Assistant
    display_options:
      - 'time'
      - 'date'
      - 'date_time'
      - 'date_time_iso'
      - 'time_date'
      - 'time_utc'
      - 'beat'
#Returns time in local hh:mm AM/PM format
    sensors:
      local_time:
        friendly_name: "Local Time"
        entity_id: sensor.time
        value_template: "{{ as_timestamp(now()) | timestamp_custom('%-I:%M %p') }}"
#Returns today's date in a compact format (Jun10)
    sensors:
      formatted_date:
        friendly_name: "Formatted Date"
        entity_id: sensor.date
        value_template: "{{(now().strftime('%a%b') ~ now().day)}}"
#This sensor returns the number of minutes until my next shift at work starts. the +300 is to adjust to local time and will need to be adjusted when DST starts/ends.
    sensors:
      time_til_work:
          value_template: >-
            {% if states.calendar.work_schedule.attributes.start_time %}
              {{((as_timestamp(states.calendar.work_schedule.attributes.start_time) - as_timestamp(now())) / 60 +300 ) | default(99) | int }}
            {%- else -%}
              0
            {%- endif %}
automation:
#Two automations to advance the hour if minutes go over 59
  - alias: advance hour once minnute reaches max
      platform: state
      entity_id: input_number.alarm_1_minutes
      to: '60.0'
      - service: script.turn_on
        entity_id: script.advance_hour
  - alias: reset hour to zero when it reaches max
      platform: state
      entity_id: input_number.alarm_1_hour
      to: '24.0'
        entity_id: script.reset_hour
#Work starts in 70 minutes but I am still in bed
  - alias: time until work warning
      platform: numeric_state
      entity_id: sensor.time_til_work
      below: 70
    condition:
      condition: state
      entity_id: sensor.home_mode
      state: 'Sleep Mode'
        entity_id: script.time_til_work_warning
#If work starts in less than 8 hours and there is no alarm, run the script
  - alias: work is soon but alarm is off
      below: 479
    condition:
      condition: state
      entity_id: input_boolean.alarm_1_enable
      state: 'off'
          entity_id: script.work_soon_alarm_warning
#This is the actual alarm clock automation. Compares set time to the current time and triggers when they are equal.
  - id: alarm_1
    alias: 'Work Alarm'
        minutes: '/1'
        seconds: 00
    condition:
        value_template: "{{ states.sensor.time.state == states.sensor.alarm_1_time.state  }}"
      - condition: state
        state: 'on'
        entity_id: script.bedroom_sunrise
#Turn off the alarm when I wake up
  - alias: alarm turn off
      platform: state
      to: 'Home Mode'
        entity_id: script.alarm_clock_off
#Warn if I enable sleep mode without having an alarm set within 2 minutes
  - alias: alarm warning sleep mode
      platform: state
      to: 'Sleep Mode'
    condition:
      condition: state
      state: 'off'
          entity_id: script.alarm_off_warning
script:
#Sleep mode is on but the alarm clock is not enabled
  alarm_off_warning:
    sequence:
      - wait_template: "{{ is_state('input_boolean.alarm_1_enable', 'on') }}"
        timeout: '00:02:00'
        continue_on_timeout: 'true'
      - condition: state
        state: 'off'
      - service: tts.amazon_polly_say
          entity_id: media_player.volumio_mpd
          message: "Warning: Sleep mode is on but the alarm clock is not enabled."
#Work starts in less than 8 hours but no alarm has been set
  work_soon_alarm_warning:
    sequence:
      - service: switch.turn_on
          entity_id: switch.home_speakers
      - service: notify.tasker
          message: "Pausepod"
      - service: media_player.media_stop
          entity_id: media_player.spotify
      - service: media_player.media_pause
          entity_id: media_player.shield2019
      - delay: '00:00:03'
          message: "Warning: Work starts in less than 8 hours but no alarm has been set."
#Alarm sounding script
  bedroom_sunrise:
    sequence:
      - service: light.turn_on
          entity_id: light.master_bedroom
          brightness: 30
      - delay: '00:00:45'
      - service: media_player.turn_on
      - delay: '00:00:03'
      - service: media_player.select_source
          source: Speakers
          source: Speakers
      - service: media_player.volume_set
          volume_level: 0.9
      - delay: '00:00:02'
      - service: spotify.play_playlist
          media_content_id: spotify:playlist:37i9dQZF1DWWEJlAGA9gs0
          random_song: true
          brightness: 90
      - delay: '00:00:45'
          entity_id: light.master_bath
          brightness: 255
      - delay: '00:00:30'
          volume_level: 0.3
      - delay: '00:00:01'
          message: "Kyle, it is time to wake up. Please enable Home Mode to stop the alarm."
          volume_level: 0.9
      - wait_template: "{{ is_state('media_player.spotify', 'playing') }}"
        timeout: '00:00:10'
          brightness: 255
      - condition: state
        state: 'idle'
          source: Speakers
      - delay: '00:00:02'
          random_song: true
#Snooze the alarm: turn lights back off, stop music, add 7 minutes to the alarm time.
  alarm_clock_snooze:
    sequence:
      - service: input_boolean.turn_off
      - service: script.turn_off
      - service: light.turn_off
#      - delay: '00:00:01'
      - service: input_number.increment
#Disable the alarm clock when I wake up
  alarm_clock_off:
    sequence:
#Advance the hour when the minutes reach 60 and reset the minutes to 0
  advance_hour:
    sequence:
      - service: input_number.set_value
          value: 0
#Reset hour to 0 if the alarm hour goes past 11pm
  reset_hour:
    sequence:
          value: 0
#Wake me up if I have snoozed too many times and work is starting soon
  time_til_work_warning:
    sequence:
          brightness: 255
          message: "Warning! Sleep mode is still enabled but Work starts in less than 70 minutes. You must wake up now!"
      - delay: '00:00:03'
          source: Speakers
          source: Speakers
          volume_level: 1.0
      - delay: '00:00:02'
          media_content_id: spotify:playlist:186HKLGj6De3DNSsVPjL3p
          random_song: true
in a couple of the automations, you turn on sensor.home_mode , but i don’t see the code to create it…Could you please share that?/
thanks
Sure! One of my favorite packages actually. I set the mode using a mix of manual switches on kiosks and automations tied to other things in other parts of my config. The automations ensure that once one mode is activated the others are deactivated, which allows the sensor to always return only one value. Here’s the home mode package:
input_boolean:
  home_mode:
    icon: mdi:home
  away_mode:
    icon: mid:home-circle
  tv_mode:
    icon: mdi:television-classic
  pc_mode:
    icon: mdi:desktop-classic
  sleep_mode:
    icon: mdi:bed-empty
  guest_mode:
    icon: mdi:account-group
    sensors:
      home_mode:
        friendly_name: "Home Mode"
        value_template: >-
          {% if is_state('input_boolean.home_mode', 'on') %}
            Home Mode
          {% elif is_state('input_boolean.away_mode', 'on') %}
            Away Mode
          {% elif is_state('input_boolean.pc_mode', 'on') %}
            PC Mode
          {% elif is_state('input_boolean.tv_mode', 'on') %}
            TV Mode
          {% elif is_state('input_boolean.sleep_mode', 'on') %}
            Sleep Mode
          {% else %}
            Error
          {% endif %}
automation:
  - alias: home mode enable
      platform: state
      entity_id: input_boolean.home_mode
      to: 'on'
        entity_id: input_boolean.away_mode
        entity_id: input_boolean.tv_mode
        entity_id: input_boolean.pc_mode
        entity_id: input_boolean.sleep_mode
  - alias: away mode enable
      platform: state
      to: 'on'
  - alias: tv mode enable
      platform: state
      to: 'on'
  - alias: pc mode enable
      platform: state
      to: 'on'
  - alias: sleep mode enable
      platform: state
      to: 'on'
  - alias: notify on mode error
      platform: state
      to: 'Error'
      service: persistent_notification.create
      data_template:
        notification_id: "kyle_{{  states.sensor.random_sensor.state }}"
        message: "Home Mode sensor is in Error state!"
switch:
    switches:
      home_mode:
        value_template: "{{ is_state('input_boolean.home_mode', 'on') }}"
        turn_on:
        turn_off:
    switches:
      away_mode:
        value_template: "{{ is_state('input_boolean.away_mode', 'on') }}"
        turn_on:
        turn_off:
    switches:
      sleep_mode:
        value_template: "{{ is_state('input_boolean.sleep_mode', 'on') }}"
        turn_on:
        turn_off:
    switches:
      tv_mode:
        value_template: "{{ is_state('input_boolean.tv_mode', 'on') }}"
        turn_on:
        turn_off:
    switches:
      pc_mode:
        value_template: "{{ is_state('input_boolean.pc_mode', 'on') }}"
        turn_on:
        turn_off:
I wrote this a while back and looking at it now you may be able to do it without using the input booleans and instead only use switches. The reason I need the switches at all is so I get the color coding on my kiosks for which mode is active.
Thanks for share
Hi, getting this error
expected a dictionary for dictionary value @ data[‘packages’][‘sensor’]
Here’s my code
input_number:
    alarm_1_hour:
        icon: mdi:timer
        initial: 7
        min: 0
        max: 23
        step: 1
    alarm_1_minutes:
        icon: mdi:timer
        initial: 0
        min: 0
        max: 59
        step: 1
    alarm_1_offset:
        icon: mdi:blur-linear
        initial: 15
        min: 0
        max: 60
        step: 15
input_boolean:
    alarm_1_weekday:
        initial: on
        icon: mdi:calendar
    alarm_1_weekend:
        initial: off
        icon: mdi:calendar
      friendly_name: sensor.alarm_1_time
      sensors:
         alarm_1_time:
              value_template: >-
      entity_id: sensor.alarm_1_time_minus_offset
      sensors:
         alarm_1_time_minus_offset:
              friendly_name: 'Offset Time'
              value_template: >-
                  {{ '%0.02d:%0.02d' | format( ((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset'))| int)/60)| int),(((((((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset')) | int)/60)) - ((((states('input_number.alarm_1_hour') | int)*60 + (states('input_number.alarm_1_minutes') | int) - (states('input_number.alarm_1_offset')) | int)/60)| int))*100) | int)*60/100) | round) ) }}
group:
    alarm_1:
        name: Wake Me Up
        entities:
            - sensor.time
            - sensor.alarm_1_time
            - sensor.alarm_1_time_minus_offset
            - input_number.alarm_1_hour
            - input_number.alarm_1_minutes
            - input_number.alarm_1_offset
            - input_boolean.alarm_1_weekday
            - input_boolean.alarm_1_weekend
automation:
  - id: 'alarm_1_weekday'
    alias: Wake me up (weekday)
      minutes: /1
      seconds: 0
    condition:
    - condition: state
      entity_id: input_boolean.alarm_1_weekday
      state: 'on'
    - condition: time
      weekday:
      - mon
      - tue
      - wed
      - thu
      - fri
      value_template: '{{ states.sensor.time.state == states.sensor.alarm_1_time_minus_offset.state  }}'
    #- data:
    #    message: Alarm ! Current time is {{ states.sensor.time.state }} and alarm is set to {{ states.sensor.alarm_1_time.state }} with an offset of {{ states.input_number.alarm_1_offset.state }} set to {{ states.sensor.alarm_1_time_minus_offset.state }} Weekdays ({{ states.input_boolean.alarm_1_weekday.state }} ) and Weekends ({{ states.input_boolean.alarm_1_weekend.state }} ) test {{ "%0.02d:%0.02d" | format(states("input_number.alarm_1_hour") | int, states("input_number.alarm_1_minutes") | int) }}
    #  service: notify.zchat
    - data: {}
      service: script.wakeup_sequence
  - id: 'alarm_1_weekend'
    alias: Wake me up (weekend)
      minutes: /1
      seconds: 0
    condition:
    - condition: state
      entity_id: input_boolean.alarm_1_weekend
      state: 'on'
    - condition: time
      weekday:
      - sat
      - sun
    #- data:
    - data: {}
script:
  'wakeup_dim':
    alias: wakeup_dim
    sequence:
    - data:
        brightness: '0'
        entity_id:
        - light.lamp_kitchen1
        - light.lamp_kitchen2
        - light.lamp_kitchen3
        - light.lamp_dinning1
        - light.lamp_dinning2
        - light.lamp_dinning3
        - light.office_lamp_new
        - light.lamp_couch
        - light.bedroom_lamp1
        - light.bedroom_lamp2
        - light.hallway_lamp_new
        kelvin: '2200'
        transition: '0'
    - data:
        brightness: '0'
        entity_id:
        - light.gateway_light_286c07fa2642
        - light.yeelight_rgb_34ce008d0d2f
        rgb_color:
        - 255
        - 169
        - 92
    - data:
        brightness_pct: '0'
        entity_id:
        - light.colour_bulb
        rgb_color:
        - 255
        - 169
        - 92
        transition: '0'
  'wakeup_bright':
    alias: wakeup_bright
    sequence:
    - data_template:
        brightness: '255'
        kelvin: '2700'
        transition: '{{(states(''input_number.alarm_1_offset'') | int ) *60}}'
        entity_id:
        - light.lamp_couch
    - data_template:
        brightness: '255'
        entity_id:
        - light.colour_bulb
        rgb_color:
        - 255
        - 169
        - 92
  'wakeup_sequence':
    alias: wakeup_sequence
    sequence:
    - data:
        message: Alarm ! Current time is {{ states.sensor.time.state }} and alarm is set to {{ states.sensor.alarm_1_time.state }} with an offset of {{ states.input_number.alarm_1_offset.state }} set to {{ states.sensor.alarm_1_time_minus_offset.state }} Weekdays ({{ states.input_boolean.alarm_1_weekday.state }} ) and Weekends ({{ states.input_boolean.alarm_1_weekend.state }} ) 00:{{ states.input_number.alarm_1_offset.state | int }}:00
    - data: {}
      service: script.wakeup_dim
    - delay: 00:00:02
    - service: script.wakeup_bright
    - delay: '00:{{ states.input_number.alarm_1_offset.state | int }}:00'
    - data: {}
      service: script.play_wakeup_music
Modify this section to include the dashes and remove the duplicate ‘friendly names’. (plus you can trim down the code a little)
    sensors:
      - alarm_1_time:
        value_template: >-
      -  alarm_1_time_minus_offset:
         value_template: >-
thanks for the help. still getting that same error
      sensors:
       - alarm_1_time:
         value_template: >-
          value_template: >-
There are still spacing issues in your code, unless that was just caused by pasting into the forum
Thanks for this great topic.
Here is what i created with it:
It’s a grid card with:
  • Time picker card
  • button card for the next alarm and an icon (template sensor)
  • input booleans for alarm on/off, wake-up lights and input booleans for each day of the week.
  • load of template sensors for determing the next alarm, determing if its on, showing a notification from 9 hours before the alarm is on
Nodered is used for the automation part. My setup doesnt rely on HA, everything is set to global vars in nodered. The schedex-node is what is really controlling this thing.
