@mikeg1130 I can confirm that the silent arming implementation in the HA custom component matches in the one in the Homebridge node. Unfortunately, closer inspection of the notes in the README indicate there is an issue with that feature in the Alarm.com Web API:
“armingModes”: Object of objects with arming mode options of boolean choices ( WARNING: the Alarm.com webAPI does not support setting silent arming to true and this feature does not work at this time)
The files https://github.com/aechelon/pyalarmdotcomajax in the folder are the older ones. I used the latest ones circled, and not the ones in the folder alarmdotcomajax . Just copy them to the folder on your machine.
@Markus99 does the alarm state for each come up properly (i.e. can one be armed while the other one isn’t?)
I don’t have 2 systems so debugging the issue would take some poking in the dark.
@mikeg1130 I tested silent arming with the python web api example and it works properly, so something must be happening when the ajax implementation pushes the parameter to Alarm.com. There’s hope!
The original Alarm.com integration handled this ok, fwiw (with the same configuration.yaml setup). I also ensure that I have two separate logins, each with ONLY access to only ONE of the systems.
For now I’ve switched and am using BOTH the WEBAPI and AJAX versions. Also, appears that arming to STAY is working w/ the AJAX version, which is a great!
I’ll check for more details when I get a chance to switch back to BOTH using AJAX and let you know. As always, thanks for your hard work @aechelon!
You answered your own question Carlton. All the sensor is doing is looking for an EXACT MATCH to ‘Office Window is Open’ in the ‘sensor_status’ attribute of the alarm_control_panel.alarm_com entity.
As you can see in the states that the Office Window (14) is open, but the binary states show it as off (or closed).
Therefore you need to regex_search for Office Window (14) is Open, not just ‘Office Window is open’
Note that while the platform name remains unchanged, the parameters values are slightly different. Specifically, the flags force_bypass, no_entry_delay, and silent_arming accept strings, not boolean (true/false) values.
Accepted values are “home”, “away”, “false” (never), “true” (always)
Where “home” means only enable the feature when arming home and “away” means only enable the feature when arming away.
Also, from what I’m seeing, the name: home instance (the lower of the two) from configuration.yaml is completely ignored. I tested setting our home alarm only and the status in HA didn’t change at all. So it’s using/duplicating the WORK credentials for the HOME sensor apparently…
As mentioned, the (now removed? / original) version was able to have multiple instances/locations of the alarmdotcom integration and allowed them to operate independently. Unsure if anything in that code would be helpful? Let me know if I can assist further!
