Yes, no changes in the Settings/Sound & Vibration/Default alarm sound.
A few tests that I’ve performed:
My default settings: vibration only for calls, notifs and max sound for alarm → HA notification just vibration
Changed the overall setting from “vibration only” to “ring” → default alarm sound.
Changed the notification volume to vibration → just vibration
Changed the notification channel to alarm_stream_max and min notification volume → notification sound instead of alarm.
So, based on these tests, it looks like the alarm_stream still uses the alarm’s default sound but is now controlled by the notification volume instead of the alarm volume.
Unfortunately, my expertise lies in other areas and not android/mobile software dev, so I’m not sure if it can be related to e.g. some changes in the HA companion app…
Some interesting additional info:
I’ve checked my wife’s phone (same pixel 7) and it has exactly the same settings e.g. in the app notification streams, etc. However, it works as expected (vibration only mode but HA notifications play alarm sound).
The only difference is that she didn’t apply the last update (the phone says that it’s still pending) and as a result, her phone has AP3A.241105.007 build and my is AP4A.241205.013…
Edit: HA Companion app version is the same: 2024.12.1-full
Any alternative option? I would assume it will take many months before Google will fix it (if they will fix it)…
I’m using such notifications in Alarmo and a few other important places where I would need an “immediate reaction”. It would be super helpful if you have some alternative suggestions
It works! The only issue is that it “says” the text only once when the alarm keeps ringing until I acknowledge it…
Maybe I should create a loop with a check for input that would just “say” notification every few seconds until e.g. I click on an action in a notification… that would mean that I can’t use Alarmo’s built-in notifications but I guess it’s ok because I can create an automation around it.
Do you know if it is possible to play a sound instead of text via TTS?
another alternative is to use tasker if it still works, TTS is text only tahts how the service works
not quite the same as alarm stream, your other option would be to change the phones ringer mode remotely and send teh text and set t back to vibrate once acknowledged
These are good workarounds! Tested the ringer mode and it works! The only issue is that I need to “revert” it back based on action but I can have some “hooks”. That’s something what I can work with. Of course, the original alarm_stream was way more convenient but oh well…
Ooo, these are awesome suggestions!!! Did a few quick tests and looks like the Device locked sensor is not very reliable but the Interactive works like a charm. I probably will use it. Big thank you!
Actually, changed my mind: the mobile_app_notification_cleared works really good. I probably will use it instead
PS: that’s why I LOVE Home Assistant and the ecosystem! It’s so flexible and configurable!
So I can assume that there is still no fix to this? I’ve been troubleshooting the same for a while now until I just noticed this post, which explains a lot why it is not working…
Maybe I should change my automations to turn of vibrate, turn up the notification volume, do the alarm and then put everything back… It is a pain in the ass, but at least it still warns me…
Anyone know how to fix this, it used to be working on Android 15 but no longer on 16, well it works if the phone is unlocked it makes the alarm noise otherwise it does not:
action: notify.mobile_app_sm_s938b
metadata: {}
message: Battery not charging
ttl: 0
priority: high
channel: alarm_stream
importance: high
notification_stream does nothing either, it needs to be working in DND mode as well.
