Alert - Create a dismissible and snoozable repeating alert based on an entity's state
I have a similar usecase to @albertojbs , where I am using the alert platform to send to multiple destinations (email, a few telegram accounts) etc., depending on the alert priority and type. Is there a way to do this with the blueprint?
something equivalent to
    notifiers:
      - telegram_1
      - telegram_2
      - email_3
some other blueprint or workaround? my driver for this: telegram no longer works with the alert: platform.
I ended up writing a push notification script for different groups of users that takes parameters/input and handles telegram and email the way I wanted.
Below is a sample use case. I used claude to convert between my old alert platform syntax and the use of this blueprint.
  - alias: "Alert - Garage Door Open"
    use_blueprint:
      path: MakingNate/alert.yaml
      input:
        alert_entity: cover.garage_door
        alert_state: "open"
        idle_state: "closed"
        initial_delay:
          minutes: 30 # the next line makes the app send a push notification
        notification_device: !secret main_notification_device_id
        notification_title: "[HA] Garage Door alert" #
        notification_message: "The Garage Door is still open"
        notification_unique_id: "garage_door_alert"
        repeat_delay:
          hours: 0
          minutes: 30
          seconds: 0
        snooze_duration:
          hours: 24
          minutes: 0
          seconds: 0
        send_idle_notification: false
        alert_actions:
          - service: script.send_push_notification
              send_telegram: "true"
              send_email: "true"
        idle_actions:
              message: "The Garage Door is now closed"
              send_email: "true"
        dismiss_actions:
              message: "The Garage Door alert was dismissed"
              send_email: "true"
