yep. you’re right. mindbending sometimes…
But your initial automation
Would work great, just uncomment the time trigger.
Also not directed at you, I’m Not naysaying node red, but this is a simple automation, while node red will probably handle it just fine, it seems (to me), like a lot of overhead for simple automations. I feel like when people are starting out under standing these kind of automations are a good foundation to really understanding what is going on in the background.
You could also use a “garage open for x minutes” as a trigger. This would not send an notification if the garage is opened then closed within x minutes (when coming home late for example)
But it works if the garage has been opened at 20:59 and left open for x minutes:
- id: garageopenafter
alias: "Garage door open between 9pm and 5am"
- entity_id: cover.sunsetgarage
for:
minutes: 5
platform: state
to: 'on'
condition:
- condition: time
after: '21:00:00'
before: '05:00:00'
- service: notify.telegram
message: 'Garage door open, is that correct?'
If I remember correctly, in the condition section the default is to And the values, and I believe you want to Or them.
There is no time which is after 21:00 AND before 05:00
Yes that might be a Problem indeed. Perhaps using the sun level as condition would be better? (need to have sun: somewhere in configuration.yaml)
for:
minutes: 5
platform: state
to: 'on'
condition:
- condition: state
entity_id: sun.sun
state: below_horizon
Thanks everyone, I agree with @ptdalen that it’s a good idea to understand the basics before moving onto something like Node Red. I guess based on post by @NigelL an ‘or’ wouldn’t work, per the below? I might just go for Node Red, as in this case it just seems much easier.
- platform: time
at: '21:00:00'
- platform: state
entity_id: 'cover.sunsetgarage'
condition:
condition: or
conditions:
- condition: time
after: '21:00:00'
before: '05:00:00'
- condition: state
state: 'open'
Why do you say that? After 2100 before 0500 is 9pm over the midnight then from midnight until 5am. Am I missing something somewhere else, I have many automations using that exact same logic
If I remember correctly (and this is something I have seen being talked about on here, not something I have direct experience of) the comparison is done to the current time, so it can’t be after 9PM, AND be before 5AM. The time comparison compares to the target times on the current day. (I could be misremembering, or just be flat out wrong)
So I believe the condition should be along the lines of (sorry, not testing this)
condition:
condition: or
conditions:
- condition: time
after: '21:00:00'
- condition:time
before: '05:00:00'
I hear what you’re saying and there are many, many examples exactly as you’ve said. Recently though I was shown than that is not necessary by a well trusted community member. I updated several of my automations to test, and they all still work, much simplier.
Thanks all, I’ve gone with the below, I’ll test it out tomorrow.
- platform: time
at: '21:00:00'
- platform: state
condition:
- condition: time
after: '21:00:00'
before: '05:00:00'
- condition: state
state: 'open'
Oh, I must have missed that. If it works, then great, it simplifies things
This indeed works…
Anyone able to assist on how to add a reminder every 15 minutes?
First create a 15 minute timer (I used 30 minutes):
north_garage_door:
duration: '00:30:00'
Then use an automation similar to below:
- alias: 'Notification North GD Open'
- platform: state
entity_id: sensor.n_gd_pos_template
to: 'Open'
for:
minutes: 30
- platform: event
event_type: timer.finished
event_data:
entity_id: timer.north_garage_door
condition:
condition: state
state: 'Open'
- service: notify.pushbullet_notify
message: 'The North Garage Door Is Still Open'
- service: timer.start
Another example notifying via HA App
#configurations.yaml
timer:
garage_door:
duration: '00:15:00'
#automations.yaml
- id: '0000000000000'
alias: Garage Door Left Opened
description: ''
- entity_id: binary_sensor.visonic_mct_340_e_xxxxxxxx_1_1280
platform: state
to: 'on'
- at: '20:00:00'
platform: time
- event_data: {}
platform: event
condition:
- condition: state
state: 'on'
- after: '20:00:00'
before: 06:00:00
condition: time
- data_template:
message: '{{now().strftime("%a %b %d %H:%M:%S %p")}}'
title: '{{ trigger.to_state.attributes.friendly_name }} {% if trigger.to_state.state
== ''on'' %}Detected {% endif %}'
service: notify.mobile_app_jason_note
- entity_id: timer.garage_door
IFTTT integration is working, i.e. it response from the developer test interface, but the following automations are not generating any email notifications when they should be:
automation:
- id: 'garage_open_notification'
alias: 'Garage Door Open'
- platform: state
entity_id: cover.garage_door
to: 'Open'
for:
minutes: 30
condition: []
- service: ifttt.trigger
data: {"event": "GarageLeftOpen"}
alias: "Garage door open between 9pm and 8am"
- platform: time_pattern
minutes: '/5'
condition:
- condition: time
after: '21:00:00'
before: '08:00:00'
- condition: state
entity_id: 'cover.garage_door'
state: 'Open'
- id: garage_opened
alias: 'Garage Door Opened'
- platform: state
to: 'Open'
condition:
condition: state
state: 'Open'
- id: garage_closed
alias: 'Garage Door Closed'
- platform: state
to: 'Closed'
- service: timer.cancel
- id: garage_opened_timer_finished
alias: 'Garage Opened Timer Finished'
- platform: event
event_data:
condition:
condition: state
state: 'Open'
timer:
garage_door:
