@cerebrate I think you’ve nailed the two concepts of staging and “sub-alerts”. Both have a lot of value and well described. Also your skip_first use case makes sense to me (I’m also trying to think if there’s any broader abstraction there but haven’t found one yet).
Been thinking about alerting more in relation to everything we’re doing and my own use cases.
Providing the ability to call an arbitrary set of services when a condition/stage occurs and not just a notifier is valuable. For example, if I get a leak alert, I want to shut off my water valves. If I get a fire alert, I want to shut down boilers. And I actually think calling the services each reminder interval is fine (make sure the valves are off for example), once I don’t care about the alert redoing things I can ack it. I could see an option to call services only on the alert being fired the first time.
Equally, there could be optional services to fire when the alert is over. In a leak condition I might want to keep the valve off until I figure out the problem, but if there was just temporary smoke that cleared I may want to just fire up the boilers automatically because I don’t want the buildings to freeze.
Again, this would be wonderfully simple yet materially powerful to link to alerts because we already have delays to start, hysterisis, etc. And with staging, I could have a first stage notification that a problem exists, then a second stage action to shut down the valves and/or boilers. That is big.
Automations alone would be pretty hard to do the above actually (notably the staging), and then we’d have disjoint action taking in the system from alerting to the user - which means you actually can’t know for certain if an action has been taken when you see an alert (you have to know the underlying automation code vs. alert code). For my use cases, having them exactly aligned would be the best, for example a staged message can be “Smoke has progressed, shutting down boilers” and reduces emergency condition code in my system to being in one place: alert checks fire notifications and take actions.
EDIT: Also @redstone99 with logging, could you ensure there is an INFO level log statement that is detailed for each alert creation and deletion, as well as each activiation, deactivation and notification (and unified across generator and not)? I’ve found some inconsistencies with what is at debug vs. info, and the problem with the debug level is every condition and trigger check gets logged which spams the logs when I’m not trying to debug at that level. I actually think that’s a fine set of info to log at debug as when you really need to figure out why an alert is not firing, you want that detail. But I want to be able to confidently go into the log when it’s at a normal Info level and check the major events related to alerts, like making sure they were created in the first place, fired, deactivated, etc. Each should have a full set of info to be able to go back and diagnose if something went wrong given the mission criticalness of the component. Thanks!!
EDIT2: As I’ve expanded my usage of Alert2, found more and more use cases. I now have it sending alerts for nice to know conditions (e.g. I’ve started to warm up a building, tell me when it’s gotten warm enough) vs. emergencies (smoke alarm or leak). A way to designate severity on an alert and in the UI would be great, I know you are doing UI work and we referenced some form of severity in the past so just reraising now as you’re doing the work.
