Alerts with conditions
is there a way to add conditions for alerts.
For example I want to be alerted if a windows is opened, but only if the outside temp is below a certain value.
I know that I could set up a binary template sensor with both conditions in it (temperatur and window).
But it would be nicer to add this directly in the alerts.
At the moment that is the only way. You could put in a feature request.
Thanks, if you want to add somethin to the request, see
