While I would love this, I believe the founder once mentioned how difficult it was to keep this integration alive due to constant changes, I assume, on Amazon’s side.
Given all we use our dozen+ echos is for timers, announcements and above all home control via HA, I am looking forward to a good looking, well built/packaged HA Assist solution. Just like I de-applefied my household years ago, I will also de-amazon my house as well.
Confirmed working with --country CA and using \$ rather than S in my password.
OTP came from Bitwarden.
Also tested library_test.json (which does need the $ in the password escaped).
First, using Visual Studio Code (or any other file editor of your choice), open this file: /homeassistant/custom_components/alexa_media/manifest.json
Then, locate the line within that file that says requirements: and change that line to this: "requirements": ["alexapy>=1.28.2", "packaging>=20.3", "wrapt>=1.14.0"],
I only see one temporary solution and that is to go back to the July OS version. The problem is to see if someone can offer that version for downgrade.
i have HO version 2024.9.2 and Alexa version 4.13.1 installed.
When i try to add the integration, i’m forwarded to the Alexa webpage for login, but every time i log in it refreshes the site and nothing happens.
Does anyone have this issue and does anyone have a solution?
P.S. i had the integration working for a couple of months and it stopped working, so i tried to reconfigure it.
@petro Make it sence that someone create a PR with the “Open source compliance” from 2024.9 so we dont need the old creater? Or i miss understand the function from that?
Are there more specific how to get involved instructions? @petro just posted a link to the github repo, which is a good start. But I guess I’m looking for a planning thread or something. Who’s working on what, what’s needed, what are the biggest issues, what’s the long term direction, etc.
Amazon-JP returns the first request response with an error screen, so the command fails in the form data parsing process (KeyError: ‘method’).
For Amazon-JP, the request parameter “openid.asset_handle=amzn_dp_project_dee_ios” needs to be replaced with “openid.asset_handle=jpflex”.
Non-existent account.
Before:
An error occurs and the command is aborted.
After:
processing As a result of command execution, “Cannot authenticate with [email protected] credentials” is displayed.
Correct account.
Before:
After:
the command is executed, device information is displayed.
Does anyone know if there is a GoFundme or similar page started, for we who can’t code, that we can contribute money to this project? I use this integration too much to let it die
