@gazzaman2k looking for some help. I’ve set up Lannouncer and tested it with the developer tool. I can see the message on the lannouncer app on the android box, but no sound comming out. I’ve connected via BT to alexa, but also tried with headphones in the headphone jack just to test. Nothing
I noticed that in the settings>audio volume the “volume for text to speach” is not highlighted. Should this be available?
thank you
im pretty sure it should be lit up, are you sure you have installed language speech packs?
@gazzaman2k thank you. you mean speech packs on the android box?
I continued trying and installed this https://www.home-assistant.io/components/notify.llamalab_automate/
it works when the box is connected directly to a speaker. the Lannouncer didnt work at all.
Hello.
I was able to successfully load the notify.rest component, but I do not know how to enter an action in the automation that will trigger this notification. Could You please show an example how to send notification when the switch change the state?
Assuming you used notify as the name in the configuration as above, the action in your automation would look something like this:
service: notify.notify
message: Whatever you wanted to happen has happened.
If you used a different name in your rest notify configuration other than notify you would replace notify.notify with notify.your name
If you want a dynamic message, you would need to use data_template instead of data - refer to the documentation on templating here.
I wrote something like this in my notify.yaml:
- platform: rest
message_param_name: notification
resource: https://api.notifymyecho.com/v1/NotifyMe
accessCode: amzn1.ask.account
and then the test automation:
- alias: test
platform: state
entity_id: switch.microwave
to: 'on'
- service: notify.notify
message: "Microwave ON"
title: "Custom subject"
but when the switch.microwave is in ON state the notification goes to my iPhone not to my Alexa What is wrong?
I think your problem is that, if you don’t specify a name, the default name for the rest notify platform is notify.notify, which is probably conflicting with another platform you have setup.
Try specifying a name like this (which would make it notify.alexa):
- name: alexa
platform: rest
accessCode: my_code
Then you would be able to change the automation to use that name, like this:
- alias: test
platform: state
to: 'on'
- service: notify.alexa
Works great! Thank you
do you need to have cloud subscription for alexa to do this?
how do get access?
You don’t need a cloud subscription, just an Amazon account (which you would already have for your Alexa device). To set this up you:
- Enable the Notify Me Alexa skill by Thomptronics (there now appears to be another unrelated skill with the same name from a different developer so make sure you pick the right one)
- Link the skill to your Amazon account (in the Alexa app or website)
- You get an email with your access code and details of how to post notifications. This access code is what you need in the configuration.
I’ve been using the Alexa Media Player integration from HACS. It works great. Here is an example script I am using:
welcome_home:
alias: Welcome Home
sequence:
- condition: state
entity_id: device_tracker.life360_MyDevice
state: 'home'
- wait_template: "{{ is_state('binary_sensor.back_door', 'on') }}"
timeout: '00:05:00'
continue_on_timeout: 'false'
- service: notify.alexa_media
- media_player.kitchen_dot
type: announce
message: "Welcome Home Human"
Enjoy!
Thanks! Works perfectly!
Here’s one to notify me of new HA version when motion is detected in my office:
alias: HA Update Notification (Announce)
description: ''
- type: motion
platform: device
device_id: e8bf9866093a11eb91e14fbce81191bd
entity_id: binary_sensor.motion_office
domain: binary_sensor
condition:
- condition: state
entity_id: binary_sensor.updater
state: 'on'
- service: media_player.volume_set
volume_level: 0.5
entity_id: media_player.echo_dot
- service: notify.alexa_media_echo_dot
message: >-
I've noticed that a new version of Home Assistant {{
state_attr('binary_sensor.updater', 'newest_version') }} is now
available.
type: announce
mode: single
