Alexa: Problem with roller shutters
I use this: https://github.com/AlexxIT/SonoffLAN
I installed it via HACS
Well, your problem is that you do not have the attribute position, which defines the position of the cover. Either your cover physically doesn’t support a position, or that custom repo that you’re using isn’t setting up cover properly.
Your only recourse to get the utterances to work is:
  1. create a template cover that implements position_template and set_position and expose that to alexa
  2. Have the creator of SonoffLAN fix his integration (if it’s a bug, unclear on that without looking at his code).
By your first option, do you mean this?
cover:
    covers:
      tapprella_cucina:
        device_class: tapparella
        friendly_name: "Tapparella cucina"
        value_template: "{{ states('sensor.garage_door')|float > 0 }}"  (here would there be something that reads the position of the shutter?)
        open_cover:
          service: script.tapparella_cucina_aperta
        close_cover:
          service: script.tapparella_cucina_chiusa
        stop_cover:
          service: script.tapparella_cucina_ferma
I got it from here: Template Cover - Home Assistant
the most concise way to make this work…
Add a input number through the UI or in yaml. Make the range 0 to 100. Name it Tapparella cucina
then…
cover:
    covers:
      tapprella_cucina:
        position_template: "{{ states('input_number.tapparella_cucina') | int(0) > 0 }}"
        set_cover_position:
        - service: >
            {% if position == 0 %}
            {% if position == 100 %}
            {% else %}
            {% endif %}
        - service: input_number.set_value
            value: "{{ position }}"
        open_cover:
        - service: script.tapparella_cucina_aperta
            value: 100
        close_cover:
        - service: script.tapparella_cucina_chiusa
            value: 0
        stop_cover:
        - service: script.tapparella_cucina_ferma
            value: 50
keep in mind, this attempts to keep the input_number in sync with the garage state. If you restart home assistant and it’s reversed, you’ll get odd behavior. But this is the only way to enable the utterances for raise and lower.
The other option is to use your other cover as the position state. Is it the cover listed above? If yes…
cover:
    covers:
      tapprella_cucina:
        position_template: "{{ 100 if is_state('cover.sonoff_10012b8b18', 'on') else 0 }}"
        set_cover_position:
        - service: cover.{{ 'open' if position > 0 else 'close' }}_cover
            entity_id: cover.sonoff_10012b8b18
        open_cover:
        - service: cover.open_cover
        close_cover:
        - service: cover.close_cover
        stop_cover:
        - service: cover.stop_cover
Ok, I put:
input_number:
  slider1:
    min: 0
    max: 100
cover:
    covers:
      tapprella_cucina:
        set_cover_position:
        - service: >
            {% else %}
            {% endif %}
        open_cover:
            value: 100
        close_cover:
            value: 0
        stop_cover:
            value: 50
But putting your code gives me this error:
Invalid config for [cover.template]: Service {% if position == 0 %}
{% else %}
{% endif %}
does not match format <domain>.<name> for dictionary value @ data['covers']['tapprella_cucina']['set_cover_position'][0]['service']. Got '{% if position == 0 %}\n script.tapparella_cucina_chiusa\n{% if position == 100 %}\n script.tapparella_cucina_aperta\n{% else %}\n script.tapparella_cucina_ferma\n{% endif %}\n'
expected CoverDeviceClass for dictionary value @ data['covers']['tapprella_cucina']['device_class']. Got 'tapparella'. (See ?, line ?).
Even with the other you wrote it gives me an error.
