it can be.
i found a script somwhere on the forum (dont know where anymore)
#!/bin/sh
# Amazon Alexa Remote Control
# alex(at)loetzimmer.de
# 2017-10-10: v0.1 initial release
# 2017-10-11: v0.2 TuneIn Station Search
# 2017-10-11: v0.2a commands on special device "ALL" are executed on all ECHO+WHA
# 2017-10-16: v0.3 added playback of library tracks
# 2017-10-24: v0.4 added playback information
# 2017-11-21: v0.5 added Prime station and playlist
# 2017-11-22: v0.6 added Prime historical queue and replaced getopts
# 2017-11-25: v0.6a cURL is now configurable
# 2017-11-25: v0.7 added multiroom create/delete, playback of library playlist
# 2017-11-30: v0.7a added US config, fixed device names containing spaces
# 2017-12-07: v0.7b added Bluetooth connect/disconnect
# 2017-12-18: v0.7c fixed US version
# 2017-12-19: v0.7d fixed AWK csrf extraction on some systems
# 2017-12-20: v0.7e moved get_devlist after check_status
# 2018-01-08: v0.7f added echo-show to ALL group, TuneIn station can now be up to 6 digits
# 2018-01-08: v0.8 added bluetooth list function
# 2018-01-10: v0.8a abort when login was unsuccessful
# 2018-01-25: v0.8b added echo-spot to ALL group
# 2018-01-28: v0.8c added configurable browser string
# 2018-02-17: v0.8d no need to write the cookie file on every "check_status"
# 2018-02-27: v0.8e added "lastalexa" option for HA-Bridge to send its command to a specific device
# (Markus Wennesheimer: https://wennez.wordpress.com/light-on-with-alexa-for-each-room/)
# 2018-02-27: v0.9 unsuccessful logins will now give a short info how to debug the login
# 2018-03-09: v0.9a workaround for login problem, force curl to use http1.1
# (no BASHisms were used, should run with any shell)
# - requires cURL for web communication
# - (GNU) sed and awk for extraction
# - jq as command line JSON parser (optional for the fancy bits)
EMAIL=email
PASSWORD=pw'
LANGUAGE="de,en"
#LANGUAGE="en-us"
AMAZON='amazon.de'
#AMAZON='amazon.com'
ALEXA='layla.amazon.de'
#ALEXA='pitangui.amazon.com'
# cURL binary
CURL='/usr/bin/curl'
# cURL options
# -k : if your cURL cannot verify CA certificates, you'll have to trust any
# --compressed : if your cURL was compiled with libz you may use compression
# --http1.1 : cURL defaults to HTTP/2 on HTTPS connections if available
OPTS='--compressed --http1.1'
#OPTS='-k --compressed --http1.1'
# browser identity
BROWSER='Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:58.0) Gecko/20100101 Firefox/58.0'
# nothing to configure below here
TMP="/tmp"
COOKIE="${TMP}/.alexa.cookie"
DEVLIST="${TMP}/.alexa.devicelist.json"
GUIVERSION=0
LIST=""
LOGOFF=""
COMMAND=""
STATIONID=""
QUEUE=""
SONG=""
TYPE=""
ASIN=""
SEEDID=""
HIST=""
LEMUR=""
CHILD=""
PLIST=""
BLUETOOTH=""
LASTALEXA=""
usage()
echo "$0 [-d <device>|ALL] -e <pause|play|next|prev|fwd|rwd|shuffle|vol:<0-100>> | -b [list|<\"AA:BB:CC:DD:EE:FF\">] | -q | -r <\"station name\"|stationid> | -s <trackID> | -t <ASIN> |"
echo " -u <seedID> | -v <queueID> | -w <playlistId> | -i | -p | -P | -S | -a | -m <multiroom_device> [device_1 .. device_X] | -lastalexa | -l | -h"
echo " -e : run command"
echo " -b : connect/disconnect/list bluetooth device"
echo " -q : query queue"
echo " -r : play tunein radio"
echo " -s : play library track"
echo " -t : play Prime playlist"
echo " -u : play Prime station"
echo " -v : play Prime historical queue"
echo " -w : play library playlist"
echo " -i : list imported library tracks"
echo " -p : list purchased library tracks"
echo " -P : list Prime playlists"
echo " -S : list Prime stations"
echo " -a : list available devices"
echo " -m : delete multiroom and/or create new multiroom containing devices"
echo " -lastalexa : print device that received the last voice command"
echo " -l : logoff"
echo " -h : help"
while [ "$#" -gt 0 ] ; do
case "$1" in
-d)
if [ "${2#-}" != "${2}" -o -z "$2" ] ; then
echo "ERROR: missing argument for ${1}"
usage
exit 1
fi
DEVICE=$2
shift
-e)
usage
exit 1
fi
COMMAND=$2
shift
-b)
if [ "${2#-}" = "${2}" -a -n "$2" ] ; then
BLUETOOTH=$2
shift
else
BLUETOOTH="null"
fi
-m)
usage
exit 1
fi
LEMUR=$2
shift
while [ "${2#-}" = "${2}" -a -n "$2" ] ; do
CHILD="${CHILD} ${2}"
shift
done
-r)
usage
exit 1
fi
STATIONID=$2
shift
# stationIDs are "s1234" or "s12345"
if [ -n "${STATIONID##s[0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9]}" -a -n "${STATIONID##s[0-9][0-9][0-9][0-9][0-9][0-9]}" ] ; then
# search for station name
STATIONID=$(${CURL} ${OPTS} -s --data-urlencode "query=${STATIONID}" -G "https://api.tunein.com/profiles?fullTextSearch=true" | jq -r '.Items[] | select(.ContainerType == "Stations") | .Children[] | select( .Index==1 ) | .GuideId')
if [ -z "$STATIONID" ] ; then
echo "ERROR: no Station \"$2\" found on TuneIn"
exit 1
fi
fi
-s)
usage
exit 1
fi
SONG=$2
shift
-t)
usage
exit 1
fi
ASIN=$2
shift
-u)
usage
exit 1
fi
SEEDID=$2
shift
-v)
usage
exit 1
fi
HIST=$2
shift
-w)
usage
exit 1
fi
PLIST=$2
shift
-l)
LOGOFF="true"
-a)
LIST="true"
-i)
TYPE="IMPORTED"
-p)
TYPE="PURCHASES"
-P)
PRIME="prime-playlist-browse-nodes"
-S)
PRIME="prime-sections"
-q)
QUEUE="true"
-lastalexa)
LASTALEXA="true"
-h|-\?|--help)
usage
exit 0
echo "ERROR: unknown option ${1}"
usage
exit 1
esac
shift
done
case "$COMMAND" in
pause)
COMMAND='{"type":"PauseCommand"}'
play)
COMMAND='{"type":"PlayCommand"}'
next)
COMMAND='{"type":"NextCommand"}'
prev)
COMMAND='{"type":"PreviousCommand"}'
fwd)
COMMAND='{"type":"ForwardCommand"}'
rwd)
COMMAND='{"type":"RewindCommand"}'
shuffle)
COMMAND='{"type":"ShuffleCommand","shuffle":"true"}'
vol:*)
VOL=${COMMAND##*:}
# volume as integer!
if [ $VOL -le 100 -a $VOL -ge 0 ] ; then
COMMAND='{"type":"VolumeLevelCommand","volumeLevel":'${VOL}'}'
else
echo "ERROR: volume should be an integer between 0 and 100"
usage
exit 1
fi
echo "ERROR: unknown command \"${COMMAND}\"!"
usage
exit 1
esac
# Amazon Login
log_in()
# following headers are required:
# Accept-Language (possibly for determining login region)
# User-Agent (cURL wouldn't store cookies without)
rm -f ${DEVLIST}
rm -f ${COOKIE}
rm -f ${TMP}/.alexa.*.list
# get first cookie and write redirection target into referer
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
https://alexa.${AMAZON} | grep "hidden" | sed 's/hidden/\n/g' | grep "value=\"" | sed -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata"
# login empty to generate session
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
-H "$(grep 'Location: ' ${TMP}/.alexa.header | sed 's/Location: /Referer: /')" -d "@${TMP}/.alexa.postdata" https://www.${AMAZON}/ap/signin | grep "hidden" | sed 's/hidden/\n/g' | grep "value=\"" | sed -r 's/^.*name="([^"]+)".*value="([^"]+)".*/\1=\2\&/g' > "${TMP}/.alexa.postdata2"
# login with filled out form
# !!! referer now contains session in URL
${CURL} ${OPTS} -s -D "${TMP}/.alexa.header2" -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "Accept-Language: ${LANGUAGE}" -H "DNT: 1" -H "Connection: keep-alive" -H "Upgrade-Insecure-Requests: 1" -L\
-H "Referer: https://www.${AMAZON}/ap/signin/$(awk "\$0 ~/.${AMAZON}.*session-id[ \\s\\t]+/ {print \$7}" ${COOKIE})" --data-urlencode "email=${EMAIL}" --data-urlencode "password=${PASSWORD}" -d "@${TMP}/.alexa.postdata2" https://www.${AMAZON}/ap/signin > "${TMP}/.alexa.login"
# check whether the login has been successful or exit otherwise
if [ -z "$(grep 'Location: https://alexa.*html' ${TMP}/.alexa.header2)" ] ; then
echo "ERROR: Amazon Login was unsuccessful. Possibly you get a captcha login screen."
echo " Try logging in to https://alexa.${AMAZON} with your browser. In your browser"
echo " make sure to have all Amazon related cookies deleted and Javascript disabled!"
echo
echo " (For more information have a look at ${TMP}/.alexa.login)"
rm -f ${COOKIE}
rm -f "${TMP}/.alexa.header"
rm -f "${TMP}/.alexa.header2"
rm -f "${TMP}/.alexa.postdata"
rm -f "${TMP}/.alexa.postdata2"
exit 1
fi
# get CSRF
${CURL} ${OPTS} -s -c ${COOKIE} -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
-H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
https://${ALEXA}/api/language > /dev/null
rm -f "${TMP}/.alexa.login"
# get JSON device list
get_devlist()
${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L\
-H "Content-Type: application/json; charset=UTF-8" -H "Referer: https://alexa.${AMAZON}/spa/index.html" -H "Origin: https://alexa.${AMAZON}"\
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})"\
"https://${ALEXA}/api/devices-v2/device?cached=false" > ${DEVLIST}
check_status()
# bootstrap with GUI-Version writes GUI version to cookie
# returns among other the current authentication state
AUTHSTATUS=$(${CURL} ${OPTS} -s -b ${COOKIE} -A "${BROWSER}" -H "DNT: 1" -H "Connection: keep-alive" -L https://${ALEXA}/api/bootstrap?version=${GUIVERSION} | sed -r 's/^.*"authenticated":([^,]+),.*$/\1/g')
if [ "$AUTHSTATUS" = "true" ] ; then
return 1
fi
return 0
# set device specific variables from JSON device list
set_var()
DEVICE=$(echo ${DEVICE} | sed -r 's/%20/ /g')
if [ -z "${DEVICE}" ] ; then
# if no device was supplied, use the first Echo(dot) in device list
echo "setting default device to:"
DEVICE=$(jq -r '[ .devices[] | select(.deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" ) | .accountName] | .[0]' ${DEVLIST})
echo ${DEVICE}
fi
DEVICETYPE=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceType' ${DEVLIST})
DEVICESERIALNUMBER=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .serialNumber' ${DEVLIST})
MEDIAOWNERCUSTOMERID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .deviceOwnerCustomerId' ${DEVLIST})
if [ -z "${DEVICESERIALNUMBER}" ] ; then
echo "ERROR: unkown device dev:${DEVICE}"
exit 1
fi
# list available devices from JSON device list
list_devices()
jq -r '.devices[].accountName' ${DEVLIST}
# execute command
run_cmd()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d ${COMMAND}\
"https://${ALEXA}/api/np/command?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}"
# play TuneIn radio station
play_radio()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST\
"https://${ALEXA}/api/tunein/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&guideId=${STATIONID}&contentType=station&callSign=&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play library track
play_song()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"trackId\":\"${SONG}\",\"playQueuePrime\":true}"\
"https://${ALEXA}/api/cloudplayer/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}&shuffle=false"
# play library playlist
play_playlist()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"playlistId\":\"${PLIST}\",\"playQueuePrime\":true}"\
# play PRIME playlist
play_prime_playlist()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"asin\":\"${ASIN}\"}"\
"https://${ALEXA}/api/prime/prime-playlist-queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME station
play_prime_station()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"seed\":\"{\\\"type\\\":\\\"KEY\\\",\\\"seedId\\\":\\\"${SEEDID}\\\"}\",\"stationName\":\"none\",\"seedType\":\"KEY\"}"\
"https://${ALEXA}/api/gotham/queue-and-play?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}"
# play PRIME historical queue
play_prime_hist_queue()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"deviceType\":\"${DEVICETYPE}\",\"deviceSerialNumber\":\"${DEVICESERIALNUMBER}\",\"mediaOwnerCustomerId\":\"${MEDIAOWNERCUSTOMERID}\",\"queueId\":\"${HIST}\",\"service\":null,\"trackSource\":\"TRACK\"}"\
"https://${ALEXA}/api/media/play-historical-queue"
# show library tracks
show_library()
OFFSET="";
SIZE=50;
TOTAL=0;
FILE=${TMP}/.alexa.${TYPE}.list
if [ ! -f ${FILE} ] ; then
echo -n '{"playlist":{"entryList":[' > ${FILE}
while [ 50 -le ${SIZE} ] ; do
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X GET \
"https://${ALEXA}/api/cloudplayer/playlists/${TYPE}-V0-OBJECTID?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&size=${SIZE}&offset=${OFFSET}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}.tmp
OFFSET=$(jq -r '.nextResultsToken' ${FILE}.tmp)
SIZE=$(jq -r '.playlist | .trackCount' ${FILE}.tmp)
jq -r -c '.playlist | .entryList' ${FILE}.tmp >> ${FILE}
echo "," >> ${FILE}
TOTAL=$((TOTAL+SIZE))
done
echo "[]],\"trackCount\":\"${TOTAL}\"}}" >> ${FILE}
rm -f ${FILE}.tmp
fi
jq -r '.playlist.trackCount' ${FILE}
jq '.playlist.entryList[] | .[]' ${FILE}
# show Prime stations and playlists
show_prime()
FILE=${TMP}/.alexa.${PRIME}.list
"https://${ALEXA}/api/prime/{$PRIME}?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" > ${FILE}
if [ "$PRIME" = "prime-playlist-browse-nodes" ] ; then
for I in $(jq -r '.primePlaylistBrowseNodeList[].subNodes[].nodeId' ${FILE} 2>/dev/null) ; do
"https://${ALEXA}/api/prime/prime-playlists-by-browse-node?browseNodeId=${I}&deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}&mediaOwnerCustomerId=${MEDIAOWNERCUSTOMERID}" >> ${FILE}
done
fi
fi
jq '.' ${FILE}
# current queue
show_queue()
PARENT=""
PARENTID=$(jq --arg device "${DEVICE}" -r '.devices[] | select(.accountName == $device) | .parentClusters[0]' ${DEVLIST})
if [ "$PARENTID" != "null" ] ; then
PARENTDEVICE=$(jq --arg serial ${PARENTID} -r '.devices[] | select(.serialNumber == $serial) | .deviceType' ${DEVLIST})
PARENT="&lemurId=${PARENTID}&lemurDeviceType=${PARENTDEVICE}"
fi
"https://${ALEXA}/api/np/player?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}${PARENT}" | jq '.'
"https://${ALEXA}/api/media/state?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
"https://${ALEXA}/api/np/queue?deviceSerialNumber=${DEVICESERIALNUMBER}&deviceType=${DEVICETYPE}" | jq '.'
# deletes a multiroom device
delete_multiroom()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X DELETE \
"https://${ALEXA}/api/lemur/tail/${DEVICESERIALNUMBER}"
# creates a multiroom device
create_multiroom()
JSON="{\"id\":null,\"name\":\"${LEMUR}\",\"members\":["
for DEVICE in $CHILD ; do
set_var
JSON="${JSON}{\"dsn\":\"${DEVICESERIALNUMBER}\",\"deviceType\":\"${DEVICETYPE}\"},"
done
JSON="${JSON%,}]}"
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "${JSON}" \
"https://${ALEXA}/api/lemur/tail"
# list bluetooth devices
list_bluetooth()
"https://${ALEXA}/api/bluetooth?cached=false" | jq --arg serial "${DEVICESERIALNUMBER}" -r '.bluetoothStates[] | select(.deviceSerialNumber == $serial) | "\(.pairedDeviceList[]?.address) \(.pairedDeviceList[]?.friendlyName)"'
# connect bluetooth device
connect_bluetooth()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST -d "{\"bluetoothDeviceAddress\":\"${BLUETOOTH}\"}"\
"https://${ALEXA}/api/bluetooth/pair-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# disconnect bluetooth device
disconnect_bluetooth()
-H "csrf: $(awk "\$0 ~/.${AMAZON}.*csrf[ \\s\\t]+/ {print \$7}" ${COOKIE})" -X POST \
"https://${ALEXA}/api/bluetooth/disconnect-sink/${DEVICETYPE}/${DEVICESERIALNUMBER}"
# device that sent the last command
# (by Markus Wennesheimer)
last_alexa()
${CURL} ${OPTS} -s -b ${COOKIE} -A "Mozilla/5.0" -H "DNT: 1" -H "Connection: keep-alive" -L\
"https://${ALEXA}/api/activities?startTime=&size=1&offset=1" | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# Serial number: | jq -r '.activities[0].sourceDeviceIds[0].serialNumber'
# Device name: | jq -r '.activities[0].sourceDeviceIds[0].serialNumber' | xargs -i jq -r --arg device {} '.devices[] | select( .serialNumber == $device) | .accountName' ${DEVLIST}
# logout
log_off()
https://${ALEXA}/logout > /dev/null
rm -f ${DEVLIST}
rm -f ${COOKIE}
if [ -z "$LASTALEXA" -a -z "$BLUETOOTH" -a -z "$LEMUR" -a -z "$PLIST" -a -z "$HIST" -a -z "$SEEDID" -a -z "$ASIN" -a -z "$PRIME" -a -z "$TYPE" -a -z "$QUEUE" -a -z "$LIST" -a -z "$COMMAND" -a -z "$STATIONID" -a -z "$SONG" -a -n "$LOGOFF" ] ; then
echo "only logout option present, logging off ..."
log_off
exit 0
fi
if [ ! -f ${COOKIE} ] ; then
echo "cookie does not exist. logging in ..."
log_in
fi
check_status
if [ $? -eq 0 ] ; then
echo "cookie expired, logging in again ..."
log_in
check_status
echo "log in failed, aborting"
exit 1
fi
fi
if [ ! -f ${DEVLIST} ] ; then
echo "device list does not exist. downloading ..."
get_devlist
echo "failed to download device list, aborting"
exit 1
fi
fi
if [ -n "$COMMAND" -o -n "$QUEUE" ] ; then
if [ "${DEVICE}" = "ALL" ] ; then
for DEVICE in $(jq -r '.devices[] | select( .deviceFamily == "ECHO" or .deviceFamily == "KNIGHT" or .deviceFamily == "ROOK" or .deviceFamily == "WHA") | .accountName' ${DEVLIST} | sed -r 's/ /%20/g') ; do
set_var
if [ -n "$COMMAND" ] ; then
echo "sending cmd:${COMMAND} to dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}"
run_cmd
else
echo "queue info for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}"
show_queue
fi
done
else
set_var
run_cmd
else
show_queue
fi
fi
elif [ -n "$LEMUR" ] ; then
DEVICESERIALNUMBER=$(jq --arg device "${LEMUR}" -r '.devices[] | select(.accountName == $device and .deviceFamily == "WHA") | .serialNumber' ${DEVLIST})
if [ -n "$DEVICESERIALNUMBER" ] ; then
delete_multiroom
else
if [ -z "$CHILD" ] ; then
echo "ERROR: ${LEMUR} is no multiroom device. Cannot delete ${LEMUR}".
exit 1
fi
fi
echo "Deleted multi room dev:${LEMUR} serial:${DEVICESERIALNUMBER}"
else
echo "Creating multi room dev:${LEMUR} member_dev(s):${CHILD}"
create_multiroom
fi
rm -f ${DEVLIST}
get_devlist
elif [ -n "$BLUETOOTH" ] ; then
if [ "$BLUETOOTH" = "list" -o "$BLUETOOTH" = "List" -o "$BLUETOOTH" = "LIST" ] ; then
set_var
echo "bluetooth devices for dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER}:"
list_bluetooth
done
else
set_var
list_bluetooth
fi
elif [ "$BLUETOOTH" = "null" ] ; then
set_var
echo "disconnecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} from bluetooth"
else
set_var
echo "connecting dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} to bluetooth device:${BLUETOOTH}"
connect_bluetooth
fi
elif [ -n "$STATIONID" ] ; then
set_var
echo "playing stationID:${STATIONID} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_radio
elif [ -n "$SONG" ] ; then
set_var
echo "playing library track:${SONG} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_song
elif [ -n "$PLIST" ] ; then
set_var
echo "playing library playlist:${PLIST} on dev:${DEVICE} type:${DEVICETYPE} serial:${DEVICESERIALNUMBER} mediaownerid:${MEDIAOWNERCUSTOMERID}"
play_playlist
elif [ -n "$LIST" ] ; then
echo "the following devices exist in your account:"
list_devices
elif [ -n "$TYPE" ] ; then
set_var
echo -n "the following songs exist in your ${TYPE} library: "
show_library
elif [ -n "$PRIME" ] ; then
set_var
echo "the following songs exist in your PRIME ${PRIME}:"
show_prime
elif [ -n "$ASIN" ] ; then
set_var
echo "playing PRIME playlist ${ASIN}"
play_prime_playlist
elif [ -n "$SEEDID" ] ; then
set_var
echo "playing PRIME station ${SEEDID}"
play_prime_station
elif [ -n "$HIST" ] ; then
set_var
echo "playing PRIME historical queue ${HIST}"
elif [ -n "$LASTALEXA" ] ; then
last_alexa
else
echo "no alexa command received"
fi
if [ -n "$LOGOFF" ] ; then
echo "logout option present, logging off ..."
log_off
fi
if you save that script as an shl file you can use commandlineswitches and automations to start and stop music on any echo you like.
