And thanks for the mention of my repo in the nice post in your signature - congrats on your website!
I use the Linkwarden addon.
There is an info “All other options can be configured using the config.yaml file found in /config/db21ed7f_filebrowser/config.yaml using the Filebrowser addon.”
In /config/ there is no folder. Only the config.yaml.
And also the config.yaml is in:
- addon_configs → db21ed7f_filebrowser
- addon_configs → db21ed7f_linkwarden
I inserted the code for “registration = disabled” in all files and restarted the addon. But it won’t work. How can I use the code?
NEXT_PUBLIC_DISABLE_REGISTRATION=true
Thank you and best regards!
Hi, indeed normally the config.yaml location should have been described in the log : it is mounted to /config within the add-on, but in filebrowser accessed in addon_configs/ or homeassistant/addons_config/
Perhaps the key element is that it is a yaml format, so KEY: value and not KEY=value
In theory the log starting the add-on should show you the messages telling if the file is correctly read and if there are errors
how can I open the new “user administration” in Linkwarden 2.6?
The changelog says: “Server administrators can now manage user addition and deletion with greater ease. This feature is especially useful for organizations that need to manage multiple users.”
I think I only have a “normal” user.
Thanks in advance!
I think Firefly iii addon currently does not support SSL. I’m using own certificate on local network and this produces error. Can you update this to support SSL?
Hi, just reinstalled the app and I see it directly in top right just below ‘switch to light’
Hi, I think you could use the addon “proxy manager” to manage ssl certificates for add-ons without needing to have it implemented in each individual add-ons. I think that’s how the “official” add-ons are now built but i could be wrong. If yes, I can look to add an additional nginx layer to handle ssl. I’m not doing it as first step to avoid complexifying the add-on if it is not required
I’m using [Let’s Encrypt] addon from official repo and you know it creates /ssl/fullchain.pem
and /ssl/privkey.pem
. And I found that there is no way to define that certificate and key in firefly iii addon.
I’m also using Mealie addon from your repo, it can use ssl: true
and define cert and key from config.json
. I wish I could do so in firefly iii. Point me if I’m wrong, since I’m not a coder.
Thank you! I deleted the plugin + files (+ database) and now it works fine!
Actually it depends on a function not implemented yet : Enable FPM in docker image · Issue #5443 · firefly-iii/firefly-iii (github.com)
I’ll try to add it myself but had failed when I initially tried
Hello again,
Unfortunately, the addon (Linkwarden) crashes after a few hours.
It only works again after a restart.
Do you have any ideas?
Thank you!
[0] Error: socket hang up
[0] at connResetException (node:internal/errors:720:14)
[0] at Socket.socketOnEnd (node:_http_client:525:23)
[0] at Socket.emit (node:events:529:35)
[0] at endReadableNT (node:internal/streams/readable:1368:12)
[0] at process.processTicksAndRejections (node:internal/process/task_queues:82:21) {
[0] code: ‘ECONNRESET’
[0] }
[0] }
[0] }
what is the migration trick by the latest update?
When updating addon cannot start. by removing the folder it will, but I cannot upload en restore the backup in mealie.
what’s the workflow?
Alas there is no easy solution to move back from Mealie 2.0 to 1.2 now that the upstream image has cause the database to migrate.
- If you had a backup from mealie :
- make a clean install (rename folder
/homeassistant/addons_config/mealie_data
to mealie_data.bak)
- restart the latest version of the addon (which will fully reset) and restore your backup
- If you have a backup from homeassistant of the /config folder :
- you should rename the folder
to mealie_data.bak
- extract your backup
- Copy the
folder from your backup to the same path in homeassistant
- Copy the
- Wait for the addon to move back to 2.0 to use your database that was upgraded…
If you have neither, alas Mealie has no way to way back from the upgrade that occurred… For info, I’ve improved the system to make sure that the data is backuped in the future (this function did not exist when I created the addon) but this doesn’t help for this specific issue.
thanks for your answer. Maybe I did something wrong:
made a backup in mealie and in home assistant
stoppen
renamed the data folder
installed new one.
logged in with default credentials
uploaded backup
restored backup
error
yield
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/base.py", line 458, in _upgrade_revs
return self.get_revisions(target)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 565, in get_revisions
return tuple(
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 566, in <genexpr>
for script in reversed(list(revs))
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 814, in iterate_revisions
revisions, heads = fn(
self._revision_for_ident(rev_id, branch_label)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 1447, in _collect_upgrade_revisions
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 637, in _revision_for_ident
raise ResolutionError(
alembic.script.revision.ResolutionError: No such revision or branch 'feecc8ffb956'
for rev in self._parse_upgrade_target(
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/revision.py", line 1234, in _parse_upgrade_target
return tuple(
File "/app/mealie/routes/admin/admin_backups.py", line 105, in import_one
backup.restore(file)
File "/app/mealie/services/backups_v2/backup_v2.py", line 101, in restore
self.db_exporter.restore(database_json)
File "/app/mealie/services/backups_v2/alchemy_exporter.py", line 164, in restore
command.upgrade(alembic_cfg, alembic_version)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/command.py", line 406, in upgrade
script.run_env()
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/base.py", line 582, in run_env
util.load_python_file(self.dir, "env.py")
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/util/pyfiles.py", line 95, in load_python_file
module = load_module_py(module_id, path)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/util/pyfiles.py", line 113, in load_module_py
script.run_env()
spec.loader.exec_module(module) # type: ignore
File "<frozen importlib._bootstrap_external>", line 883, in exec_module
File "<frozen importlib._bootstrap>", line 241, in _call_with_frames_removed
File "/app/alembic/env.py", line 81, in <module>
run_migrations_online()
File "/app/alembic/env.py", line 75, in run_migrations_online
context.run_migrations()
File "<string>", line 8, in run_migrations
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/runtime/environment.py", line 946, in run_migrations
self.get_context().run_migrations(**kw)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/runtime/migration.py", line 616, in run_migrations
for step in self._migrations_fn(heads, self):
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/command.py", line 395, in upgrade
return script._upgrade_revs(revision, rev)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/base.py", line 446, in _upgrade_revs
with self._catch_revision_errors(
File "/usr/local/lib/python3.10/contextlib.py", line 153, in __exit__
self.gen.throw(typ, value, traceback)
File "/opt/pysetup/.venv/lib/python3.10/site-packages/alembic/script/base.py", line 282, in _catch_revision_errors
raise util.CommandError(resolution) from re
alembic.util.exc.CommandError: Can't locate revision identified by 'feecc8ffb956'
INFO 2024-08-27T19:36:33 - [192.168.0.1:0] 500 Internal Server Error "POST /api/admin/backups/mealie_2024.08.27.05.42.06.zip/restore HTTP/1.1"
Hi Alex
I have a problem with xTeve. Locally everything works, however when I do a redirect on the router and connect from another network the ip of the xTeVe server remains local. Using xteve-project/xTeVe: M3U Proxy for Plex DVR and Emby Live TV (github.com) running on my QNAP this problem is not there. How in HA do I set it to work properly?
Am I the only one experiencing issues with Linkwarden? Even after reinstalling, the add-on crashes shortly after being used.
