Allow me to manually change the date and time
I don’t think so. But tell me where you are trying to run it and what result you get.
The suggested command is simply ignored. It doesn’t change the time. I also tried another Linux command and it wasn’t recognized.
Are you literally typing # at the start of the line? Because that would make the whole line a comment.
In addition to Nick’s suggestion, you’re typing in OUT instead of OCT for the month.
If that was the problem an error would be generated.
It is not a problem until he removes the #, because it is first then it becomes a command.
