I don’t use hassio, so this might not be accurate, but from the quickest of searches the correct way to reboot should hopefully be…
Hassio > System > Reboot
Ugh, that’s crap.
Can you paste the error log somewhere again?
OK, here in a box…
#automations
- alias: Holiday Lights Off At Midnight
initial_state: on
at: '23:59:59'
platform: time
service: light.turn_off
entity_id: light.holiday_lights
- alias: Holiday Lights On At Sundown
initial_state: on
event: sunset
offset: -00:45:10
platform: sun
service: input_select.select_option
entity_id: input_select.holiday_led_effect
option: Halloween
- alias: Swap led effects
initial_state: on
platform: time
seconds: '/5'
condition:
condition: state
state: 'on'
data_template:
option: >
{% if is_state('input_select.holiday_led_effect' , 'Halloween') %} Punkin
{% else %} Halloween {% endif %}
And here in a gist…
Awesome
LMK how you get on when you can post again
So, the automation will trigger every 5 minutes to toggle the input_select, but only when the light is on.
So if you turn that light on now, at some point in the next 5 minutes the input_select will change and the led effects will change, then 5 minutes later the same again, and every 5 minutes until either you switch the light off, or the automation does it for you at midnight.
Then they’ll go on again at sundown, and toggle every 5 minutes etc.
My pleasure
