Out for a few, I have to continue testing when I return.
The easiest way (I have found) is to get the message, with SSML tags, reading correctly in AWS and then copy over to the automation yaml. From there it should read the exact same and if not the configuration of the component has an issue.
Thanks, will followup shortly, kid duties.
Didn’t have time yet to setup SSML Tags, but just check my logs and found the following for two automations ran recently.
2017-07-28 21:09:01 ERROR (MainThread) [homeassistant.components.tts] Can't write 38ae3c8144e65e8fc69a567fed96a6a33e78305a_en-us_339415901_amazon_polly.mp3
2017-07-28 21:09:37 ERROR (MainThread) [homeassistant.components.tts] Can't write f0b8307d4e618bd94bb14c74227a74c1f7a23470_en-us_339415901_amazon_polly.mp3
