I use the integrated schedule. The integration tries everything to wake up the mower.
Then it is a newer model, which does not work with the integration because it is not manufactured by ZCS. Stiga and ZCS have been going their separate ways for a while now.
Iām in trouble to use xiaomi-vacuum-map-card now, when camera entity is replaced with image entity.
I canāt figure out right configuration for image calibration_source
The following configuration works perfectly for me:
card:
type: custom:xiaomi-vacuum-map-card
entity: vacuum.mower_imei
vacuum_platform: send_command
map_source:
camera: image.mower_imei_map
calibration_source:
camera: true
Thankās, exactly what I needed.
Love the integration, much appreciate all the work you put into this. Just a question, I own a Techline S-25i and have not found a way to define/change my P1-P2-P3 programs from the integration (maybe I didnāt look in the right place)⦠Could you tell me if the functionality exists, or is in the making? Thanks, Z
Unfortunately, no configuration can be carried out remotely. The cloud control does not (yet) offer this. According to my dealer, however, all functions that are available via bluetooth will soon be controllable via the cloud.
Only one of the configured profiles can currently be activated via the cloud. See zcsmower.set_profile in the services:
A workaround would be to set the robot to manual mode and use the services via automation to send it to work in the zones and to mow the borders. But I donāt (yet) have a blueprint for this.
Music to my ears: āall functions that are available via bluetooth will soon be controllable via the cloudā. Thanks for coming back to me, take care!
Iāve managed to get the keep_out command working, but only when using index = 1.
When I try adding two keep_out zones (with index = 1 and index = 2), the mower only respects the zone with index = 1.
Am I missing something about how the indexes are supposed to work?
Also, is there any official API documentation available?
Then your model may only support a no-go zone. There is no API documentation because all API requests have been reverse engineered.
āall functions that are available via bluetooth will soon be controllable via the cloudā Any update?
