Android TV Card - Universal Remote with Touchpad, Slider, and Keyboard Support
Yikes, it looks like all of the haptic toggles don’t work anymore. I’ll work on fixing it now.
Edit: Should be fixed in v3.0.3
Great card! Thank you
I’m trying to use the touchpad single click to open a web page/url
with other cards, I simply use :
tap_action:
  action: url
  url_path: https:www.google.com
how can I make it work?
are the actions limited to services?
I’ve tried shell_command / rest_command unsuccessfully
looking for something like this :
custom_keys:
  center:
    action: url
Thanks!
Actions are limited to services. If you want you can make a feature request on the GitHub page and I can look into it when I have time.
Done :crossed_fingers: thank you!
Use case fyi:
Was using buttons to flip through RSS news headlines.
Instead I’ve overlaid a transparent version of your touchpad on the news card and can now flip through hedlines by swiping left-right. Great!
However I lost the ability to open the link to the full news article by single-clicking on the headline
Thanks for considering this enhancement request,
Cheers.
Hi, the volume buttons are sort of inverted from what seems to be intuitively convenient, ie vol - is on top and vol + is at the bottom. Any way I can invert this without assigning the vol + command to the vol - button and vice versa?
Secondly, is it possible to have some now playing type info showing on the touchpad rather than an image, if thats not too much to ask
Can you make a bug for this on the repo so I can remember to reverse the volume buttons order when in a column when I come back from out of town?
@Nerwyn, great job on this card! Thank you for all the work on this, it works great.
Yeah its too awesome, I have such a fantastic remote working for all my sources now.
@Nerwyn , is it possible to use keyboard with apple tv? Not managed that yet.
Unfortunately I don’t think there is. I don’t see a way to do so in the Apple TV Home Assistant integration.
According to this thread, the underlying library does support sending text, so it would be possible if this functionality was implemented into the Home Assistant integration.
I dont get the icons for nlziet kodi and jellyfin.
how can I get those?
You’d have to add custom svg icons for them as described here. You could also use CSS to instead use an image as described here.
This card is great but i’m strugling adding a custom_source of any app installed on my Android TV, in this case SmartTube
I thought that app_id should be used com.liskovsoft.smarttubetv.beta but it doesn’t seem to work. Also looked for a source in dev tools but it doesn’t give me any hints.
Do you have an example on how to add a custom_source for any app installed on my Philips Android TV?
For Smartube I’m using the card default YouTube source vnd.youtube://. It does throw an error message at the bottom of the screen saying it can’t process the intent but it works anyway. Have you tried any of the alternates for YouTube or Smartube in the Android TV deep linking guide??
As for examples there a section in the README in custom keys and sources that has this example:
custom_sources:
  max:
    icon: hbo
    source: hbomax://deeplink
With source being found using the deep linking guide.
Thanks for your reply, i missed the deep link part my apologies.
I’ve just released v3.1.0, which adds jinja2-like templating using nunjucks.
Because this uses nunjucks to recreate Home Assistant templating, I have to reimplement some of its functions as described in the Home Assistant templating documentation. So far the following functions are implemented:
  • states
  • is_state
  • state_attr
  • is_state_attr
  • has_value
  • iif
  • match_media
Here’s some examples of using templates with this card:
rows:
  - - '{{ "navigation_buttons" if match_media("(orientation: landscape)") else "navigation_touchpad" }}'
  - - '{{ "sunroom_light" if is_state("light.sunroom_ceiling", "off") else "volume_slider" }}'
custom_keys:
  sunroom_light:
    icon: >-
      {{ iif(is_state("light.sunroom_ceiling", "on"), "mdi:ceiling-light",
      "mdi:ceiling-light-outline") }}
    service: light.toggle
      entity_id: light.sunroom_ceiling
    style:
      color: |
        {% if is_state("light.sunroom_ceiling", "on") %}
        rgb({{ state_attr("light.sunroom_ceiling", "rgb_color") }})
        {% endif %}
Note: You still need to use VALUE for slider service call data.
Hi @Nerwyn, thanks a lot for your amazing card, works like a charm!
Here my custom config for a Samsung SmartTV, integrated with HA using ha-samsungtv-smart (GitHub - ollo69/ha-samsungtv-smart: 📺 Home Assistant SamsungTV Smart Component with simplified SmartThings API Support configurable from User Interface.).
Hope it can help other using this amazing card!
type: custom:android-tv-card
media_player_id: media_player.samsung_tv_75_salotto_ci
custom_icons:
  dazn: >-
    m14.774 8.291.772-2.596.79 2.596zm3.848
    2.268-2.025-6.128c-.045-.135-.097-.224-.154-.266a.497.497 0 0
    0-.28-.063h-1.12a.485.485 0 0 0-.284.068c-.06.045-.11.132-.149.261l-2.045
    6.128c-.025.032-.038.096-.038.192 0 .149.09.223.27.223h.84c.076 0
    .139-.003.187-.01a.207.207 0 0 0 .116-.048.326.326 0 0 0
    .077-.116c.022-.051.046-.119.072-.202l.318-1.071h2.306l.327
    1.051c.026.09.051.16.077.213a.395.395 0 0 0
    .087.12c.031.028.07.047.114.053h.002c.045.006.103.01.173.01h.897c.18 0
    .27-.074.27-.223a.59.59 0 0 0-.005-.09.878.878 0 0
    0-.036-.108l.003.006zm-.994 2.467h-.646c-.168
    0-.279.024-.333.072-.055.049-.082.147-.082.295v3.638l-1.91-3.647c-.076-.155-.152-.253-.226-.295-.074-.041-.204-.063-.39-.063h-.599c-.167
    0-.278.025-.332.073-.055.048-.082.147-.082.294v6.138c0
    .148.025.246.077.294.052.048.16.072.328.072h.656c.167 0
    .278-.024.332-.072.055-.048.082-.146.082-.294v-3.648l1.91
    3.657c.077.155.152.253.227.295.073.042.204.062.39.062h.598c.167 0
    .278-.024.333-.072.054-.048.082-.146.082-.294v-6.138c0-.148-.028-.246-.082-.294-.055-.048-.166-.073-.333-.073zm3.203-.581
    1.665 1.665v8.385H1.505V14.11l1.663-1.664a.63.63 0 0 0 0-.89L1.504
    9.891V1.505h20.991v8.384l-1.665 1.666a.63.63 0 0 0 0 .89zM24
    0H0v10.613L1.387 12 0 13.387V24h24V13.387L22.613 12 24 10.613zM10.67
    18.469H7.96l2.855-4.014a.67.67 0 0 0 .087-.155.425.425 0 0 0
    .019-.135v-.772c0-.148-.028-.246-.082-.294-.055-.048-.166-.073-.334-.073H6.382c-.149
    0-.245.028-.29.082-.045.055-.068.169-.068.343v.58c0
    .172.023.287.068.341.045.055.141.083.29.083h2.545L6.11 18.469a.438.438 0 0
    0-.107.27v.792c0 .148.027.245.082.294.055.048.167.072.334.072h4.25c.148 0
    .245-.027.29-.081.045-.055.068-.17.068-.344v-.579c0-.173-.023-.287-.068-.342-.045-.055-.142-.082-.29-.082zM9.408
    8.233c0 .264-.017.484-.052.661a1.08 1.08 0 0 1-.174.43.648.648 0 0
    1-.318.231 1.523 1.523 0 0 1-.487.068h-.79v-4.17h.79c.366 0
    .63.11.79.324.16.215.241.571.241
    1.067v1.389zm1.38-2.789c-.225-.457-.533-.795-.921-1.013-.39-.219-.88-.328-1.47-.328H6.418c-.167
    0-.278.024-.333.072-.054.049-.082.147-.082.294v6.138c0
    .148.028.246.082.295.055.048.166.072.333.072h2.218c1.048 0 1.765-.447
    2.15-1.342.09-.205.153-.413.188-.622a4.91 4.91 0 0 0
    .054-.796V6.911c0-.367-.018-.656-.054-.868a2.2 2.2 0 0 0-.193-.612l.006.013z
custom_keys:
  '0':
    icon: mdi:numeric-0
    service: media_player.play_media
      entity_id: media_player.samsung_tv_75_salotto_ci
      media_content_type: send_key
      media_content_id: KEY_0
  '1':
    icon: mdi:numeric-1
      media_content_id: KEY_1
  '2':
    icon: mdi:numeric-2
      media_content_id: KEY_2
  '3':
    icon: mdi:numeric-3
      media_content_id: KEY_3
  '4':
    icon: mdi:numeric-4
      media_content_id: KEY_4
  '5':
    icon: mdi:numeric-5
      media_content_id: KEY_5
  '6':
    icon: mdi:numeric-6
      media_content_id: KEY_6
  '7':
    icon: mdi:numeric-7
      media_content_id: KEY_7
  '8':
    icon: mdi:numeric-8
      media_content_id: KEY_8
  '9':
    icon: mdi:numeric-9
      media_content_id: KEY_9
  up:
      media_content_id: KEY_UP
  down:
      media_content_id: KEY_DOWN
  left:
      media_content_id: KEY_LEFT
  right:
      media_content_id: KEY_RIGHT
  center:
      media_content_id: KEY_ENTER
  power:
    icon: mdi:power
    service: media_player.toggle
  home:
      media_content_id: KEY_HOME
  back:
      media_content_id: KEY_RETURN
  volume_mute:
      media_content_id: KEY_MUTE
  ch_up:
    icon: mdi:arrow-up-bold
      media_content_id: KEY_CHUP
  ch_down:
    icon: mdi:arrow-down-bold
      media_content_id: KEY_CHDOWN
  DAZN:
    icon: dazn
    service: media_player.select_source
      source: DAZN
  netflix:
    icon: mdi:netflix
      source: Netflix
  youtube:
    icon: mdi:youtube
      source: YouTube
  light_off:
    icon: mdi:lightbulb-group-off
    service: light.turn_off
      entity_id: light.all_lights
  light_on:
    icon: mdi:lightbulb
    service: light.turn_on
      entity_id: light.soggiorno
rows:
  - - power
    - null
    - volume_mute
    - null
    - light_on
    - light_off
  - - volume_slider
  - - null
  - - ch_up
    - ch_down
  - - null
  - - netflix
    - youtube
    - DAZN
    - primevideo
    - spotify
  - - navigation_touchpad
  - - back
    - home
  - - 1
    - 2
    - 3
    - 4
    - 5
  - - 6
    - 7
    - 8
    - 9
    - 0
Searched a bit and am having trouble with one thing. Is there a way to define a source button for Kodi? I haven’t managed to figure it out yet.
I’ve got a Sony XR 65a83j, and it has the function to turn off the screen (while leaving the TV itself on) in the TV hotbar, a very handy function for using TV to play music. Do you know if and how it would be possible to configure this to have it as a dedicated button I can press on my phone to turn off the screen?
Also I have an app “TV Bro”, which is essentially a browser on my TV. Any idea how I can pull this browser app source, and also navigate inside of it via my mobile phone (is there even a way to just navigate via “mouse”, but via mobile?)
Hello Nerwyn
Thanks for the great work. I started using your card a few weeks ago. I tried your latest nunchuck update to animate buttons. I dont know why the new buttons work on my galaxy tab-s3 tablet but they don’t work on my laptop and s22ultra phone. Actually the icons dont show up on the card but they work when you touch on their supposed places on the screen.
Can you please advice how can I solve this problem
This is a picture from the non working version from my laptop, Normally the card is full of buttons but the buttons with conditional icons with nunchucks dont show up. only buttons with normal icons show up.
99% of the time Inconsistent behavior between modern devices is a caching issue. Have you tried clearing browser cache on or restarting the non-working devices?
