Announcement - AppDaemon 3.0!
Just checked and my sunset automation didn’t fire again. No error in the error log, but my info.log is filling up fast with the following.This is just a snipet, these continue for atleast 800 lines with the ques size number growning
2018-03-25 19:12:27.732652 WARNING AppDaemon: Queue size is 230, suspect thread starvation
2018-03-25 19:12:28.773436 WARNING AppDaemon: Queue size is 230, suspect thread starvation
2018-03-25 19:12:29.808488 WARNING AppDaemon: Queue size is 230, suspect thread starvation
2018-03-25 19:12:36.275667 WARNING AppDaemon: Excessive time spent in utility loop: 2297.0ms
2018-03-25 19:15:31.267863 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:32.301872 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:33.335441 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:34.369107 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:35.425597 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:36.460891 WARNING AppDaemon: Queue size is 240, suspect thread starvation
2018-03-25 19:15:37.502538 WARNING AppDaemon: Queue size is 240, suspect thread starvation
there are also a lot of instance of these message in the log
2018-03-25 19:26:03.690843 INFO AppDaemon: --------------------------------------------------
2018-03-25 19:26:03.691846 INFO AppDaemon: Threads
2018-03-25 19:26:03.692689 INFO AppDaemon: --------------------------------------------------
2018-03-25 19:26:03.693609 INFO AppDaemon: Currently busy threads: 0
2018-03-25 19:26:03.694579 INFO AppDaemon: Most used threads: 2 at 2018-03-25 10:37:08.302074
2018-03-25 19:26:03.695517 INFO AppDaemon: Last activity: 2018-03-25 16:32:42.302074
2018-03-25 19:26:03.696387 INFO AppDaemon: --------------------------------------------------
2018-03-25 19:26:03.698500 INFO AppDaemon: thread-1 - current callback: idle since 2018-03-25 15:00:20.302074, alive: False
2018-03-25 19:26:03.699611 INFO AppDaemon: thread-2 - current callback: idle since 2018-03-25 14:55:12.302074, alive: False
2018-03-25 19:26:03.700607 INFO AppDaemon: thread-3 - current callback: idle since 2018-03-24 23:18:58, alive: False
2018-03-25 19:26:03.701596 INFO AppDaemon: thread-4 - current callback: idle since 2018-03-25 14:28:36.302074, alive: False
2018-03-25 19:26:03.702646 INFO AppDaemon: thread-5 - current callback: idle since 2018-03-25 16:32:42.302074, alive: False
2018-03-25 19:26:03.703612 INFO AppDaemon: thread-6 - current callback: idle since 2018-03-25 12:10:06.302074, alive: False
2018-03-25 19:26:03.704536 INFO AppDaemon: thread-7 - current callback: idle since 2018-03-25 15:22:03.302074, alive: False
2018-03-25 19:26:03.705504 INFO AppDaemon: thread-8 - current callback: idle since 1970-01-01 10:00:00, alive: False
2018-03-25 19:26:03.706536 INFO AppDaemon: thread-9 - current callback: idle since 2018-03-25 13:48:44.302074, alive: False
2018-03-25 19:26:03.707826 INFO AppDaemon: thread-10 - current callback: idle since 1970-01-01 10:00:00, alive: False
2018-03-25 19:26:03.708822 INFO AppDaemon: --------------------------------------------------
I am guessing this is grinding things to a halt and that is why the automation stop working. If I reboot all seems good with the other automations ( i can test sunset ones as TimeTravel doesn’t work on Hassio
appdaemon is losing connection to HA. and then it restarts, but not correctly.
also there seems to be a problem with the api.
please restart everything and show the logs from the start. i got the feeling there is something wrong from the beginning.
Yes, something is killing the worker threads, then when they are all dead everything backs up and you get the Queue warnings. I haven;t seen this before.
So lets take it step by step as Rene suggested.
Thanks with running with this guys, I appreciate the help.
Just some things i noticed.
When I got home I noticed the access log full of the following. I enabled the dashboard last night
2018-03-26 20:37:01.473769 INFO HADashboard: Dashboard disconnected
2018-03-26 20:47:02.739627 INFO HADashboard: New dashboard connected: Kitchen Dashboard
There is still nothing in my err.log ( I think this is a little strange). My info log cotains pages of the suspect thread starvation message.
The Hassio widget for AD, I did notice this inthe log display.
File "/usr/lib/python3.6/asyncio/selector_events.py", line 724, in _read_ready
    data = self._sock.recv(self.max_size)
TimeoutError: [Errno 110] Operation timed out
Fatal read error on socket transport
protocol: <RequestHandler none:none connected>
transport: <_SelectorSocketTransport fd=13 read=polling write=<idle, bufsize=0>>
transport: <_SelectorSocketTransport fd=12 read=polling write=<idle, bufsize=0>>
It is repeated several times. not sure why this isn’t going to my err.log
here is my current appdaemon.yaml
secrets: /config/secrets.yaml
log:
  logfile: /config/appdaemon/apps/logs/info.log
  errorfile: /config/appdaemon/apps/logs/err.log
  accessfile: /config/appdaemon/apps/logs/access.log
  logsize: 100000
  log_generations: 4
appdaemon:
  disable_apps: 0
  threads: 10
  api_port: 5000
  api_key: !secret http_password
  api_ssl_certificate: /ssl/fullchain.pem
  api_ssl_key: /ssl/privkey.pem
  log_thread_actions: 0
  plugins:
    HASS:
      type: hass
      ha_url: !secret ha_url
      ha_key: !secret http_password
hadashboard:
  dash_url: http://127.0.0.1:5050
  dash_dir: /config/appdaemon/dashboards
As requested, I restarted AD
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: AppDaemon3 v1.0.0
 Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
 By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
INFO: You are running the latest version of this add-on
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
INFO: Supervisor version requirements checks passed.
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing...
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing...
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 30-auto-password.sh: executing...
[cont-init.d] 30-auto-password.sh: exited 0.
[cont-init.d] 31-ha-url.sh: executing...
WARNING: You are using an non-recommended Home Assistant URL!
WARNING: Setting the "ha_url" option in your AppDaemon config to
WARNING: "http://hassio/homeassistant" is recommended!
[cont-init.d] 31-ha-url.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing...
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing...
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
starting version 3.2.4
The following was added to my info.log after the restart of AD
2018-03-26 21:13:44.508477 INFO AppDaemon Version 3.0.0 starting
2018-03-26 21:13:44.509901 INFO Configuration read from: /config/appdaemon/appdaemon.yaml
2018-03-26 21:13:44.514552 INFO AppDaemon: Starting Apps
2018-03-26 21:13:44.532498 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-03-26 21:13:44.658561 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-03-26 21:13:44.660670 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-03-26 21:13:44.662582 INFO Starting Dashboards
2018-03-26 21:13:44.701289 INFO Starting API
2018-03-26 21:13:44.711975 WARNING AppDaemon: ------------------------------------------------------------
2018-03-26 21:13:44.713216 WARNING AppDaemon: Unexpected error in api thread
2018-03-26 21:13:44.715804 WARNING AppDaemon: ------------------------------------------------------------
2018-03-26 21:13:44.723924 WARNING AppDaemon: Traceback (most recent call last):
  File "/usr/lib/python3.6/site-packages/appdaemon/adapi.py", line 43, in __init__
    f = loop.create_server(handler, "0.0.0.0", int(self.api_port), ssl=context)
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'
2018-03-26 21:13:44.725359 WARNING AppDaemon: ------------------------------------------------------------
2018-03-26 21:13:46.007312 INFO AppDaemon: HASS: Connected to Home Assistant 0.65.6
2018-03-26 21:13:47.725443 INFO AppDaemon: Got initial state from namespace default
2018-03-26 21:13:48.659758 INFO AppDaemon: Reading config
2018-03-26 21:13:49.455132 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2018-03-26 21:13:49.456491 INFO AppDaemon: /config/appdaemon/apps/apps.yaml added or modified
2018-03-26 21:13:49.457727 INFO AppDaemon: App 'utils' added
2018-03-26 21:13:49.458754 INFO AppDaemon: App 'auto_turnoff_in_five' added
2018-03-26 21:13:49.459635 INFO AppDaemon: App 'auto_turnoff_in_ten' added
2018-03-26 21:13:49.460476 INFO AppDaemon: App 'auto_turrn_off_time' added
2018-03-26 21:13:49.461306 INFO AppDaemon: App 'auto_turnoff_front_garden' added
2018-03-26 21:13:49.462148 INFO AppDaemon: App 'auto_turn_on_off_backyard_lights' added
2018-03-26 21:13:49.463039 INFO AppDaemon: App 'auto_turnoff_motion_upstairs_gallery' added
2018-03-26 21:13:49.463883 INFO AppDaemon: App 'auto_turnon_off_motion_front_porch' added
2018-03-26 21:13:49.464715 INFO AppDaemon: App 'auto_turnoff_motion_light_study' added
2018-03-26 21:13:49.465637 INFO AppDaemon: App 'auto_turn_on_off_presence_scott' added
2018-03-26 21:13:49.466507 INFO AppDaemon: App 'auto_turn_on_off_presence_lia' added
2018-03-26 21:13:49.467399 INFO AppDaemon: App 'auto_turn_on_off_presence_emily' added
2018-03-26 21:13:49.468455 INFO AppDaemon: App 'auto_turn_on_off_presence_laura' added
2018-03-26 21:13:49.469324 INFO AppDaemon: App 'auto_turn_on_off_presence_zara' added
2018-03-26 21:13:49.470545 INFO AppDaemon: App 'auto_turn_on_off_front_garden_lights' added
2018-03-26 21:13:49.471770 INFO AppDaemon: App 'auto_turn_on_off_sunset_test' added
2018-03-26 21:13:49.472843 INFO AppDaemon: App 'study_motion_scene' added
2018-03-26 21:13:49.473755 INFO AppDaemon: App 'front_sprinkler_state_change' added
2018-03-26 21:13:49.474602 INFO AppDaemon: App 'back_sprinkler_state_change' added
2018-03-26 21:13:49.475542 INFO AppDaemon: App 'notify_door_open_closed_garage' added
2018-03-26 21:13:49.476477 INFO AppDaemon: App 'notify_door_open_closed_front' added
2018-03-26 21:13:49.478137 INFO AppDaemon: Adding /config/appdaemon/apps to module import path
2018-03-26 21:13:49.481344 INFO AppDaemon: Adding /config/appdaemon/apps/logs to module import path
2018-03-26 21:13:49.483168 INFO AppDaemon: Adding /config/appdaemon/apps/message to module import path
2018-03-26 21:13:49.496133 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/notify_state_change.py
2018-03-26 21:13:49.609266 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_on_off_presence.py
2018-03-26 21:13:49.636740 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/notify_door_open_closed.py
2018-03-26 21:13:49.643028 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_on_off_motion.py
2018-03-26 21:13:49.651762 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/xiaomi_switch.py
2018-03-26 21:13:49.658120 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_on_off_motion_lumens.py
2018-03-26 21:13:49.666999 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/notify_calendar_event.py - ignoring
2018-03-26 21:13:49.668771 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/utils.py
2018-03-26 21:13:49.677433 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_off_time.py
2018-03-26 21:13:49.683530 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/sunset.py
2018-03-26 21:13:49.689395 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_on_off_sunset.py
2018-03-26 21:13:49.695563 WARNING AppDaemon: No app description found for: /config/appdaemon/apps/sound.py - ignoring
2018-03-26 21:13:49.697039 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_on_off.py
2018-03-26 21:13:49.713101 INFO AppDaemon: Loading App Module: /config/appdaemon/apps/auto_turn_off_delay.py
2018-03-26 21:13:49.726047 INFO AppDaemon: Initializing app auto_turnoff_in_five using class AutoTurnOffLightsDelay from module auto_turn_off_delay
2018-03-26 21:13:49.729580 INFO AppDaemon: Initializing app auto_turnoff_in_ten using class AutoTurnOffLightsDelay from module auto_turn_off_delay
2018-03-26 21:13:49.734281 INFO AppDaemon: Initializing app auto_turrn_off_time using class AutoTurnOffLightsTime from module auto_turn_off_time
2018-03-26 21:13:49.738795 INFO AppDaemon: Initializing app auto_turnoff_front_garden using class AutoTurnOffLightsDelay from module auto_turn_off_delay
2018-03-26 21:13:49.741572 INFO AppDaemon: Initializing app auto_turn_on_off_backyard_lights using class AutoTurnOnOffLights from module auto_turn_on_off
2018-03-26 21:13:49.744462 INFO AppDaemon: Initializing app auto_turnoff_motion_upstairs_gallery using class AutoTurnOnOffLightsMotion from module auto_turn_on_off_motion
2018-03-26 21:13:49.746724 INFO AppDaemon: Initializing app auto_turnon_off_motion_front_porch using class AutoTurnOnOffLightsMotion from module auto_turn_on_off_motion
2018-03-26 21:13:49.749083 INFO AppDaemon: Initializing app auto_turnoff_motion_light_study using class AutoTurnOnOffLightsMotionLumens from module auto_turn_on_off_motion_lumens
2018-03-26 21:13:50.587689 INFO auto_turnoff_motion_light_study: Motion on binary_sensor.study_motion working
2018-03-26 21:13:50.589182 INFO AppDaemon: Initializing app auto_turn_on_off_presence_scott using class AutoTurnOffPresence from module auto_turn_on_off_presence
2018-03-26 21:13:50.592063 INFO AppDaemon: Initializing app auto_turn_on_off_presence_lia using class AutoTurnOffPresence from module auto_turn_on_off_presence
2018-03-26 21:13:50.594767 INFO AppDaemon: Initializing app auto_turn_on_off_presence_emily using class AutoTurnOffPresence from module auto_turn_on_off_presence
2018-03-26 21:13:50.597693 INFO AppDaemon: Initializing app auto_turn_on_off_presence_laura using class AutoTurnOffPresence from module auto_turn_on_off_presence
2018-03-26 21:13:50.599912 INFO AppDaemon: Initializing app auto_turn_on_off_presence_zara using class AutoTurnOffPresence from module auto_turn_on_off_presence
2018-03-26 21:13:50.602379 INFO AppDaemon: Initializing app auto_turn_on_off_front_garden_lights using class AutoTurnOnOffSunset from module auto_turn_on_off_sunset
2018-03-26 21:13:50.605782 INFO AppDaemon: Initializing app auto_turn_on_off_sunset_test using class TurnOnOffSunset from module sunset
2018-03-26 21:13:50.608714 INFO AppDaemon: Initializing app study_motion_scene using class xiaomiSwitch from module xiaomi_switch
2018-03-26 21:13:50.623905 INFO study_motion_scene: binary_sensor.switch_158d0002109f0e
2018-03-26 21:13:50.626491 INFO AppDaemon: Initializing app front_sprinkler_state_change using class NotifyStateChange from module notify_state_change
2018-03-26 21:13:50.628718 INFO AppDaemon: Initializing app back_sprinkler_state_change using class NotifyStateChange from module notify_state_change
2018-03-26 21:13:50.630384 INFO AppDaemon: Initializing app notify_door_open_closed_garage using class NotifyDoorOpenClosed from module notify_door_open_closed
2018-03-26 21:13:50.633335 INFO AppDaemon: Initializing app utils using class utils from module utils
2018-03-26 21:13:50.635813 INFO AppDaemon: Initializing app notify_door_open_closed_front using class NotifyDoorOpenClosed from module notify_door_open_closed
2018-03-26 21:13:50.639295 INFO AppDaemon: App initialization complete
2018-03-26 21:13:58.922966 INFO auto_turnoff_motion_light_study: Motion on binary_sensor.study_motion detected
2018-03-26 21:13:58.967032 INFO auto_turnoff_motion_light_study: light 785 detected
2018-03-26 21:14:00.861534 INFO auto_turnoff_motion_light_study: Motion on binary_sensor.study_motion detected
2018-03-26 21:14:00.870390 INFO auto_turnoff_motion_light_study: light 764 detected
Please let me know if you need anymore info
thanks again.
the api port error was because you had an empty api_port in your appdaemon.yaml
that could cause trouble.
i wouldnt put logfiles in your apps dir.
the apps dir gets checked for changed files every second.
and logfiles there is very bad.
so please put them in another dir and restart your RPI.
Noticed another issue when reloading apps and not getting the new changes to be reflected after the write. This is probably related to the issue I reported from this post from one of the earlier betas here.
Consider the following app:
import globals
class switches(hass.Hass):
# testing
     def initialize(self):
        self.log("Initializing Test4")   <<=== Watch the number after Test
        self.listen_state(self.dummy,globals.office_heater,new="off", old="on")
     def dummy(self, entity, attribute, old, new, kwargs):
        self.log("dummy")
        return
I get the following in my log:
2018-03-26 11:07:36.423509 INFO AppDaemon: Removing module /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:36.425505 INFO AppDaemon: Terminating t2
2018-03-26 11:07:37.435671 INFO AppDaemon: Loading App Module: /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:37.437211 INFO AppDaemon: Initializing app t2 using class switches from module t2
2018-03-26 11:07:37.440724 INFO t2: Initializing Test0  <====Initial write
2018-03-26 11:07:43.495556 INFO AppDaemon: Terminating t2
2018-03-26 11:07:43.496551 INFO AppDaemon: Reloading Module: /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:43.499903 INFO AppDaemon: Initializing app t2 using class switches from module t2
2018-03-26 11:07:43.503533 INFO t2: Initializing Test1  <==== Update to Test1 and write - Works as expected!
2018-03-26 11:07:47.540311 INFO AppDaemon: Terminating t2
2018-03-26 11:07:47.541017 INFO AppDaemon: Reloading Module: /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:47.544780 INFO AppDaemon: Initializing app t2 using class switches from module t2
2018-03-26 11:07:47.548303 INFO t2: Initializing Test2 <===== Update to Test 2 and write - Works as expected!
2018-03-26 11:07:51.587811 INFO AppDaemon: Terminating t2
2018-03-26 11:07:51.588573 INFO AppDaemon: Reloading Module: /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:51.592440 INFO AppDaemon: Initializing app t2 using class switches from module t2
2018-03-26 11:07:51.595894 INFO t2: Initializing Test3 <===== Update to Test3 and write - Works as expected!
2018-03-26 11:07:56.641097 INFO AppDaemon: Removing module /home/homeassistant/conf/apps/t2.py  <===== hmmmm... - REMOVING not RELOADING????????
2018-03-26 11:07:56.642789 INFO AppDaemon: Terminating t2
2018-03-26 11:07:57.652842 INFO AppDaemon: Loading App Module: /home/homeassistant/conf/apps/t2.py
2018-03-26 11:07:57.654414 INFO AppDaemon: Initializing app t2 using class switches from module t2
2018-03-26 11:07:57.657848 INFO t2: Initializing Test3 <===== Update to Test4 and write - DID NOT UPDATE AS EXPECTED!
Somewhat random when this will occur - but I can reproduce at will.
Let me know if you need any further clarification.
Can you confirm what version you are running?
AppDaemon 3.0.0
HASS 0.65.5
2018-03-26 11:27:16.036952 INFO AppDaemon Version 3.0.0 starting
2018-03-26 11:27:16.037686 INFO Configuration read from: /home/homeassistant/conf/appdaemon.yaml
2018-03-26 11:27:16.040031 INFO AppDaemon: Starting Apps
2018-03-26 11:27:16.047776 INFO AppDaemon: Loading Plugin HASS using class HassPlugin from module hassplugin
2018-03-26 11:27:16.069757 INFO AppDaemon: HASS: HASS Plugin Initializing
2018-03-26 11:27:16.071412 INFO AppDaemon: HASS: HASS Plugin initialization complete
2018-03-26 11:27:16.073170 INFO Dashboards are disabled
2018-03-26 11:27:16.073626 INFO API is disabled
2018-03-26 11:27:16.091621 INFO AppDaemon: HASS: Connected to Home Assistant 0.65.5
After a dive through the code, I suspect that this might be caused by the way the file is being rewritten. If it is momentarily deleted, then recreated, but AD does it’s check at the exact moment it is deleted, you would observe the behavior above (unloading vs reloading), with the exception that is should have picked up the new version of the code which it clearly didn’t.
What are you using to edit the apps?
Vi - just making changes and then hitting :w
Also editing on the local machine … (same machine with HASS and AD)
Old school - I approve :slight_smile:
I know Vi saves .swp files and makes backups etc. so it’s possible my theory is correct - I’ll give it a try locally and see if I can reproduce it.
Hahaha - yeah I can run circles around them kids with their fancy GUI editors …:grin:
Can;t seem to get it to happen here, even using vi - I tried about 20 times in a row.
What hardware are you using? Might be related to speed of filesystems.
Running Ubuntu on a VM on a Synology NAS. I get the delete and reloading if the file system is slow - but sure seems off that it would reload the old version of the app.
Yes, that part is clearly wrong …
I also use vim and I think I have seen similar problems, but not often enough to tie it down.
i also noticed that it wasnt 100% reliable, but i didnt want to mention it untill i had more info (and didnt come around to it yet)
so once again eboon saves me some time :wink:
and you know already about my filesystem :wink:
Thanks @ReneTode.
Have added the port and checked it matched the hassio AD value. Alos moved the location of the log files. Will see if this makes difference
thanks again
Revisiting this again after giving up for a few days.
When I add the parameters as you’ve written above, I get the following error in my AppDaemon add-on log and AD fails to start:
ERROR:
while parsing a block mapping
  in "<unicode string>", line 8, column 3:
      threads: 10
expected <block end>, but found '<scalar>'
  in "<unicode string>", line 20, column 36:
      wife_tracker: "device_tracker.{}".format(wife_tracker_id)
Does it have something to do with escaping characters? I’ve tried looking up YAML references but can’t find my answer.
@aimc are there any breaking updates to the example Presence app that require changes?
Not that I am aware of
