I am now getting the same errors as sbmlat. Also running on Docker Ubuntu.
Anyone else seeing the same thing? or could it be with the docker image?
In my case, itâs this directory
/conf -> /mnt/user/appdata/appdaemon
Itâs definitely not the docker image, works fine here. Can you please show your appdaemon.yaml file?
@sbmlat and @berniebl
you both have errors in the log setup.
please read here how to setup logging:
https://appdaemon.readthedocs.io/en/latest/CONFIGURE.html#log-configuration
I have to say ⌠I am at a loss with this setup. I had no issues getting the previous version running but now I canât get anything to show in my web page with the error: Safari canât open the page â192.168.xx.xx:/dashboard?skin=minimâ because Safari canât connect to the server â192.168.xx.xxâ.
Here are some of my issues:
- I canât figure out how to get the logs to work, I have tried different paths from full qualified path to local to appdeamon and I always get the âfile or directory does not existâ even if I have a directory and blank file created. Since itâs optional, I commented it to bypass it for now, but wouldnât mind having logs available at some point.
- Disabled app with âdisable_apps: 1â even though I would like to have apps at some point. I looked at the example apps on github and did not see a direct replacement for HelloWorld so copied the alexa.py app. This is what I am getting for an error, seems like I need to define it somewhere, I can look at this later on. My main objective is to get my dashboard running.
DOCKER LOG:
2020-01-28 08:39:54.873113 INFO HASS: Connected to Home Assistant 0.104.3
2020-01-28 08:39:54.891873 INFO AppDaemon: App âhello_worldâ added
2020-01-28 08:39:54.893659 INFO AppDaemon: Found 1 total apps
2020-01-28 08:39:54.894688 INFO AppDaemon: Starting Apps with 1 workers and 1 pins
2020-01-28 08:39:55.196999 INFO HASS: Evaluating startup conditions
2020-01-28 08:39:55.461201 INFO AppDaemon: Got initial state from namespace default
2020-01-28 08:39:56.899862 INFO AppDaemon: Scheduler running in realtime
2020-01-28 08:39:56.906643 INFO AppDaemon: Adding /conf/apps to module import path
2020-01-28 08:39:56.910431 WARNING AppDaemon: No app description found for: /conf/apps/alexa.py - ignoring
2020-01-28 08:39:56.912463 INFO AppDaemon: App initialization complete
DOCKER-COMPOSE
appdaemon:
container_name: homeassistant_appdaemon
image: acockburn/appdaemon:latest
restart: unless-stopped
labels:
com.centurylinklabs.watchtower.enable: "true"
depends_on:
- homeassistant
links:
- homeassistant
ports:
- 5050:5050
volumes:
- ${USERDIR}/docker/homeassistant/appdaemon:/conf
- /etc/localtime:/etc/localtime:ro
environment:
# - HA_URL="http://192.168.xx.xx:8123"
# - HA_KEY="LongStringTokenInsertedHere"
# - DASH_URL="http://192.168.xx.xx:5050"
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
APPDAEMON.YAML
# logs:
# main_log:
# filename: /home/hass/docker/homeassistant/appdaemon/logs/appdaemon.log
# error_log:
# filename: /home/hass/docker/homeassistant/appdaemon/logs/error.log
appdaemon:
latitude: !secret latitude
longitude: !secret longitude
elevation: 70
time_zone: America/New_York
threads: '10'
disable_apps: 1
plugins:
HASS:
type: hass
ha_url: "http://192.168.xx.xx:8123"
token: !secret token
hadashboard:
# dash_url: "http://192.168.xx.vv:5050"
I have tried the URLs with and without quotes as I have seen some examples that didnât have the quotes in the online manual.
Is there anyone one that could point me to a solution? I have never used apps in the past, but wouldnât mind trying some at some point, but I really like the dashboard and would like to keep this feature in my setup. Thanks
to get dashboard working you need the http section now:
https://appdaemon.readthedocs.io/en/latest/CONFIGURE.html#configuring-the-http-component
that replaces the dashurl.
an app is always 2 parts.
first its py file, and secondly its accompanying yaml in the same dir (can be in apps.yaml or any yaml file, as long as it is in the apps dir
from your logs you can see that the hello_world app is there.
if you create a dir for the logs, then make sure that the filerights are correct.
the user that starts appdaemon needs reading and writing rights in thar dir.
the docker log shows you if the directory you use has the right filerights or not.
i have no clue about docker (never used it) but i believe the urls need to be in the environment, but i am not sure if dash_url stayed as dash_url, if that doesnt work then try url instead
Thank you, @ReneTode
I added those entries but still, itâs failing to start. I donât have appdaemon.cfg file.
2020-01-28 08:20:23.571287 INFO AppDaemon: AppDaemon Version 4.0.1 starting
2020-01-28 08:20:23.571431 INFO AppDaemon: Python version is 3.8.1
2020-01-28 08:20:23.571643 INFO AppDaemon: Configuration read from: /conf/appdaemon.yaml
2020-01-28 08:20:23.571793 INFO AppDaemon: Added log: AppDaemon
2020-01-28 08:20:23.571906 INFO AppDaemon: Added log: Error
2020-01-28 08:20:23.572010 INFO AppDaemon: Added log: Access
2020-01-28 08:20:23.572112 INFO AppDaemon: Added log: Diag
2020-01-28 08:20:23.572220 ERROR AppDaemon: time_zone not specified in appdaemon.cfg
logs:
main_log:
filename: /conf/logs/appdaemon.log
logsize: 100000
log_generations: 3
error_log:
filename: /conf/logs/appdaemonerr.log
logsize: 100000
log_generations: 3
From Docker log:
File "/usr/local/bin/appdaemon", line 8, in <module>
sys.exit(main())
File "/usr/local/lib/python3.8/site-packages/appdaemon/__main__.py", line 384, in main
admain.main()
File "/usr/local/lib/python3.8/site-packages/appdaemon/__main__.py", line 330, in main
self.logging = logging.Logging(logs, args.debug)
File "/usr/local/lib/python3.8/site-packages/appdaemon/logging.py", line 244, in __init__
for arg in config[log]:
TypeError: 'int' object is not iterable
appdaemon.cfg is from the past (needs to be changed)
that is now appdaemon.yaml
so you need to add time_zone
Thatâs already defined in appdaemon.yaml file.
appdaemon:
elevation: 224
time_zone: America/Chicago
shows that appdaemon didnt see it.
so or that logline is from before, or there is something else wrong in appdaemon.yaml
Every time when I try to restart the container, I notice this error in the docker log file. There are no entries logged to AD log files. I think âtime_zoneâ entry error was before I added that to appdaemon.yaml file.
sys.exit(main())
admain.main()
So getting a little closer. Seems like my log location is working, I just had to preface the path with â/confâ.
I am not sure if the 2 files that I have for apps are working or causing me issues.
I am getting some error messages in my docker log:
/usr/local/lib/python3.8/site-packages/appdaemon/main.py:134: DeprecationWarning: Task.all_tasks() is deprecated, use asyncio.all_tasks() instead
pending = asyncio.Task.all_tasks()
/usr/local/lib/python3.8/site-packages/aiohttp/connector.py:964: DeprecationWarning: The loop argument is deprecated since Python 3.8, and scheduled for removal in Python 3.10.
hosts = await asyncio.shield(self._resolve_host(
/usr/local/lib/python3.8/asyncio/events.py:81: DeprecationWarning: The loop argument is deprecated since Python 3.8, and scheduled for removal in Python 3.10.
self._context.run(self._callback, *self._args)
I can somewhat launch a dashboard, the main panel works and so is hello.dash but any other examples that I am copying from the site does not work such as test.dash and single.dash and so is my custom panel.
I get the error âError Getting state, check Java Console for Detailsâ .
I have cleared the cache on both Safari and Chrome as one of the treads pointed to, but that didnât help
What errors do you get in the javascript console? Just press F12 on most browsers to open the console.
It doesnât seem like I can get to it by pressing F12 as the error message is persistant even when I try to press âOKâ it just pops back up again.
It should âgive upâ after the page has gone through all errors so keep pressing ok for a while.
Yes you are right,
I pressed a number of times is this is what I got:
Failed to load resource: the server responded with a status of 404 (Not Found)
api/appdaemon/state/âŚow_temperature_1d:1 Failed to load resource: the server
So would it be safe to say that I am not getting a connection to my Home Assistant instance (on the same server)?
If so, should my references in my configuration to the HA URL be within quotes or not?
I see it both ways in the documentation.
Currently this is what I have in my appdaemon.yaml
logs:
main_log:
error_log:
filename: /conf/logs/error.log
appdaemon:
elevation: 70
threads: '10'
disable_apps: 1
plugins:
HASS:
type: hass
http:
url: "http://192.168.xx.xx:5050"
hadashboard:
Yes, it appears that you canât connect to Home Assistant. Some things to check: is your secrets file named secrets.yaml
and placed in the config folder?
Are you using a valid long-lived access token? I am not using any quotes whatsoever in my appdamon.yaml file, but qoutes or not shouldnât make any difference.
Do you get any login errors in your Home Assistant log?
Also, what browser are you using? If Chrome, you can click on network
in the console and then click XHR
and hover over the list of requests. You should then be able to see what url the page is trying to call, and also see the server response if you click on one of the requests.
Not really any progress, but do have some answers for you.
Yes, secrets.yaml file is in the config folder (same folder as appdaemon.yaml)
Yes, I still have a long-lived token that I have been using for a while now and havenât changed it in my config file.
Errors in my HA log are currently related to either Dark Sky or Zigate, so I have removed any reference to weather in my dashboard.
Restarted Appdaemon a few times and was still seeing the error above, so I decided to comment out the following lines in my docker-compose file:
I donât see any errors in the docker logs
I have checked the Network XHR and do see that itâs stopping on all entities in my dashboard. (Keep in mind that some of my dashboard is a copy of examples on github and I donât have any corresponding in HA, but still the entities that I have in HA is causing errors)
The issues that I see in XHR is the following
404: Not Found
http://192.168.xx.xx:5050/api/appdaemon/state/default/light.kitchen_right
This entity is currently in my HA
Just for reference, this is my docker-compose part for appdaemon. Maybe this will help you:
appdaemon_4:
container_name: appdaemon_4
image: acockburn/appdaemon:4.0.0
depends_on:
- hass
ports:
- 5050:5050
volumes:
- ./volumes/appdaemon_4:/conf
And my appdaemon.yaml file:
secrets: /conf/secrets.yaml
logs:
main_log:
error_log:
access_log:
filename: /conf/logs/access.log
appdaemon:
time_zone: 'Europe/Zurich'
elevation: !secret elevation
missing_app_warnings: 1
production_mode: False
app_dir: /conf/apps
plugins:
HASS:
type: hass
namespace: hass
token: !secret appdaemon_token
ha_url: http://192.168.0.5:8123
MQTT:
type: mqtt
namespace: mqtt
client_id: AD_4
client_host: 192.168.0.5
client_user: !secret mqtt_user
client_password: !secret mqtt_password
http:
url: http://192.168.0.5:5050
api:
hadashboard:
admin:
title: AppDaemon
stats_update: realtime
