Announcement: HADasboard beta4 - Release Candidate!
Looks like your indentation is off - target should be directly under feed, and rss_update should be at the same indentation level as rss_feeds, like this:
AppDaemon:
  rss_feeds:
     - feed: http://rss.cnn.com/rss/cnn_topstories.rss
       target: cnn
  rss_update: 600
This is just a copy-paste glitch :slight_smile: I do have correct indentation in config. My apologies for misleading.
Do the errors show up as soon as you load the dash or afterwards? Also, Do you initially get feed information?
It seems that these errors are showing up every 6 minutes which correlates with rss_update value. Initial load doesn’t generate errors but no data either.
Thanks, will try once I get it working (so far can’t start it)
I followed all the steps but I get this error.
python3 -m appdaemon.appdaemon -c home\pi\appdaemon_dashboard\appdaemon\conf
File “/usr/lib/python3.4/runpy.py”, line 170, in _run_module_as_main
main”, mod_spec)
File “/usr/lib/python3.4/runpy.py”, line 85, in _run_code
exec(code, run_globals)
File “/home/pi/appdaemon_dashboard/appdaemon/appdaemon/appdaemon.py”, line 1809, in
main()
File “/home/pi/appdaemon_dashboard/appdaemon/appdaemon/appdaemon.py”, line 1521, in main
config.read_file(open(config_file_conf))
TypeError: invalid file: None
Any idea?
conf dir is wrong.
i guess you have a Linux environment then you should use / and not
and start with /
but replacing the conf dir with just “-c conf” should work also
I might need to pick your brain on how to set this up later! (If you don’t mind).
I’ve always wanted this but don’t really know how to set this up. I thought I had to make the hostname of my server(s) the same as my external domain. And also modify the local domainname in my router. But I can do everything from the DNS?
Yes but that is only necessary if you are connecting to HASS via SSL.
Sorry if this is the wrong thread, but a feature suggestion for a future version of HADashboard: Integrate HA Floorplan (https://github.com/pkozul/ha-floorplan).
It would be more of a reinvention than an integration but it is already on my list
We never thought you were the only one to keep happy Rene, you need to keep Robert and me happy too. :slight_smile:
And as for your wife not knowing us, we would be happy to talk with her and include her in our teasing you anytime. :slight_smile:
no thanks, my life is complicated enough as it is :stuck_out_tongue:
Sure no problem. You should be able to, as DNS is just a lookup.
You just need to setup your router to push your local DNS as the main/only DNS server to your lan clients. Then your DNS server will intercept anything from your lan. DNS is just a lookup service, configure it with your external domain internally and route that to your server ip. Then just make sure that you add your isp’s dns ips as forwarding servers so that anything that doesn’t resolve locally (wan websites) get routed to the normal external dns servers.
In theory you should be able to do the same with your hosts file, but I haven’t tried that as I run a local DNS server…
conf dir is wrong.
and start with /
Thx! @ReneTode It works!
I’m trying to get mine running but it keeps telling me dashboards are disabled?
Here’s what i’m running and the output:
python3 -m appdaemon.appdaemon -c /home/homeassistant/.homeassistant/appdaemon
_dashboard/appdaemon/conf/
2017-06-28 19:08:46.445776 INFO AppDaemon Version 2.0.0beta4 starting
2017-06-28 19:08:46.446298 INFO Configuration read from: /home/homeassistant/.homeassistant/appdaemon_dashboard/appdaemon/conf/appdaemon.yaml
2017-06-28 15:08:46.629543 INFO Got initial state
2017-06-28 15:08:46.630823 INFO Loading Module: /home/homeassistant/.homeassistant/appdaemon_dashboard/appdaemon/conf/apps/hello.py
2017-06-28 15:08:46.659972 INFO Loading Object hello_world using class HelloWorld from module hello
2017-06-28 15:08:46.819059 INFO hello_world: Hello from AppDaemon
2017-06-28 15:08:46.822044 INFO hello_world: You are now ready to run Apps!
2017-06-28 15:08:46.822468 INFO App initialization complete
2017-06-28 15:08:46.823107 INFO Dashboards are disabled
2017-06-28 15:08:46.833558 INFO Connected to Home Assistant 0.47.1
please show your config.
Config is:
AppDaemon:
logfile: STDOUT
errorfile: STDERR
threads: 10
HASS:
ha_url: http://192.168.1.18:8123
ha_key: my_password
Apps
hello_world:
module: hello
class: HelloWorld
you need some extra parts
HADashboard:
  dash_url = http://192.168.1.18:5050
for additional options read the file DASHBOARD.md in the appdaemon directory.
ahh thank you! I feel like an idiot now haha.
