Another component for ZiGate
Ok, That was not the most helpful debug, hopefully this will help:
2018-11-21 19:06:46 WARNING (Thread-3) [zigate] No response after command 0x0120
2018-11-21 19:06:49 WARNING (Thread-3) [zigate] No response after command 0x0120
2018-11-21 19:06:52 WARNING (Thread-3) [zigate] No response after command 0x0120
2018-11-21 19:06:55 WARNING (Thread-3) [zigate] No response after command 0x0120
2018-11-21 19:06:58 WARNING (Thread-3) [zigate] No response after command 0x0100
2018-11-21 19:07:01 WARNING (Thread-3) [zigate] No response after command 0x0100
2018-11-21 19:07:04 WARNING (Thread-3) [zigate] No response after command 0x0100
2018-11-21 19:07:07 WARNING (Thread-3) [zigate] No response after command 0x0100
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 0, ‘data’: 1, ‘name’: ‘zcl_version’, ‘value’: 1}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 1, ‘data’: 2, ‘name’: ‘application_version’, ‘value’: 2}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 2, ‘data’: 1, ‘name’: ‘stack_version’, ‘value’: 1}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 3, ‘data’: 1, ‘name’: ‘hardware_version’, ‘value’: 1}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 4, ‘data’: ‘Philips’, ‘name’: ‘manufacturer’, ‘value’: ‘Philips’}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 5, ‘data’: ‘LTW010’, ‘name’: ‘type’, ‘value’: ‘LTW010’}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 6, ‘data’: ‘20161206’, ‘name’: ‘datecode’, ‘value’: ‘20161206’}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 0, ‘addr’: ‘5eb9’, ‘attribute’: 7, ‘data’: 1, ‘name’: ‘power_source’, ‘value’: 1}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 6, ‘addr’: ‘5eb9’, ‘attribute’: 0, ‘data’: False, ‘name’: ‘onoff’, ‘value’: False}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 8, ‘addr’: ‘5eb9’, ‘attribute’: 0, ‘data’: 254, ‘name’: ‘current_level’, ‘value’: 100}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 2, ‘data’: 0, ‘name’: ‘remaining_time’, ‘value’: 0}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 3, ‘data’: 29011, ‘name’: ‘current_x’, ‘value’: 0.4426727294921875}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 4, ‘data’: 26613, ‘name’: ‘current_y’, ‘value’: 0.4060821533203125}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 7, ‘data’: 343, ‘name’: ‘colour_temperature’, ‘value’: 2915}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 8, ‘data’: 2, ‘name’: ‘colour_mode’, ‘value’: 2}
2018-11-21 19:07:07 DEBUG (Thread-3) [custom_components.zigate] Update attribute for device Device 0017880103d9cfcd (5eb9) LTW010 {‘endpoint’: 11, ‘cluster’: 768, ‘addr’: ‘5eb9’, ‘attribute’: 16, ‘data’: 3, ‘name’: ‘nb_primaries’, ‘value’: 3}
@doudz
I just paired “TRADFRI control outlet” at it appears at light :frowning:
Is it a known issue ?
My Zigate.json :
            "addr": "2cd7",
            "endpoints": [
                    "clusters": [
                            "attributes": [
                                    "attribute": 0,
                                    "data": 3,
                                    "name": "zcl_version",
                                    "value": 3
                                    "attribute": 1,
                                    "data": 20,
                                    "name": "application_version",
                                    "value": 20
                                    "attribute": 2,
                                    "data": 97,
                                    "name": "stack_version",
                                    "value": 97
                                    "attribute": 3,
                                    "data": 1,
                                    "name": "hardware_version",
                                    "value": 1
                                    "attribute": 4,
                                    "data": "IKEA of Sweden",
                                    "name": "manufacturer",
                                    "value": "IKEA of Sweden"
                                    "attribute": 5,
                                    "data": "TRADFRI control outlet",
                                    "name": "type",
                                    "value": "TRADFRI control outlet"
                                    "attribute": 6,
                                    "data": "\u0000\u00000\u0001\u0000\u0000\u0000",
                                    "name": "datecode",
                                    "value": "\u0000\u00000\u0001\u0000\u0000\u0000"
                            "cluster": 0
                            "attributes": [
                                    "attribute": 0,
                                    "data": true,
                                    "name": "onoff",
                                    "value": true
                            "cluster": 6
                            "attributes": [
                                    "attribute": 0,
                                    "data": 254,
                                    "name": "current_level",
                                    "value": 100
                            "cluster": 8
                    "device": 266,
                    "endpoint": 1,
                    "in_clusters": [
                        0,
                        3,
                        4,
                        5,
                        6,
                        8,
                        64636
                    "out_clusters": [
                        5,
                        25,
                        32
                    "profile": 260
                    "clusters": [],
                    "device": 16,
                    "endpoint": 2,
                    "in_clusters": [
                        4096
                    "out_clusters": [
                        4096
                    "profile": 49246
                    "clusters": [],
                    "device": 97,
                    "endpoint": 242,
                    "in_clusters": [
                        33
                    "out_clusters": [
                        33
                    "profile": 41440
            "info": {
                "addr": "2cd7",
                "bit_field": "0100000000000001",
                "descriptor_capability": "00000000",
                "ieee": "000d6ffffe106e35",
                "last_seen": "2018-12-09 14:23:23",
                "mac_capability": "10001110",
                "manufacturer_code": 4476,
                "max_buffer": 82,
                "max_rx": 82,
                "max_tx": 82,
                "rssi": 174,
                "server_mask": 11264
How to convert it to a outlet swith ? :slightly_smiling_face:
Thnaks.
It’s known issue yes, but zigbee data says there’s level control and in Home Assistant world a switch with level control is a light.
if really this device has no level control, I have to find a way to ignore the level information
Now that your componend use iee and not addr anymore, do you advice to remove devices from zigate.json and core.entity_registry to restart discover process ?
from core.entity_registry, why not to have a clean config but not from zigate.json
If you remove entry from zigate.json in many case you should consider pair again your device
Except if IEEE is missing in zigate.json.
Ok finally I have edited entities from gui to respect your new naming conventions.
But after that I’ve update the component to latest version and got this errors in logs:
2018-12-10 14:08:47 DEBUG (SyncWorker_3) [zigate] Try loading persistent file
2018-12-10 14:08:47 INFO (MainThread) [homeassistant.core] Timer:starting
2018-12-10 14:08:47 ERROR (SyncWorker_3) [zigate] Failed to eval “round(value, 2)” using “”
2018-12-10 14:08:47 ERROR (SyncWorker_3) [zigate] Traceback (most recent call last):
File “/config/deps/lib/python3.6/site-packages/zigate/clusters.py”, line 100, in update
‘self’: self})
File “”, line 1, in
TypeError: type str doesn’t define round method
‘self’: self})
File “”, line 1, in
‘self’: self})
File “”, line 1, in
‘self’: self})
File “”, line 1, in
‘self’: self})
File “”, line 1, in
‘self’: self})
File “”, line 1, in
‘self’: self})
File “”, line 1, in
2018-12-10 14:08:47 DEBUG (SyncWorker_3) [zigate] Load success
2018-12-10 14:08:47 INFO (SyncWorker_3) [zigate] Searching ZiGate port
2018-12-10 14:08:47 INFO (SyncWorker_3) [zigate] ZiGate found at /dev/ttyUSB1
Looks like you have a XIAOMI Cube, recent change provide rotation angle, so I suggest you to rotate the cube and the problem will be solved
We can’t hide anything from you :sweat_smile:
But rotate the cube did not change the error.
Do I try to pair it again ?
The problem is in the zigate.json there probably somthing like 'expire_value': '' you could try to change it to 'expire_value': 0
or pair it again
I’ve tried this:
shutdown hass
sed -i ‘s/“expire_value”: “”/“expire_value”: 0/’ zigate.json
But after restart I get the error again.
And “expire_value”: “”, is back
The issue is I don’t only have the cube with this issue.
Aqara wall switch with fireline are also impacted as they display also a movement detector (but I don’t think there’s really one )
Oh, you’ll have to replace 'data': '' by 'data': 0 for entries where you set 'expire_value': 0
Sorry but the problem is stil there with more errors:
2018-12-11 08:51:42 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2018-12-11 08:51:42 INFO (MainThread) [homeassistant.core] Timer:starting
2018-12-11 08:51:42 DEBUG (SyncWorker_8) [zigate] Try loading persistent file
2018-12-11 08:51:42 ERROR (SyncWorker_8) [zigate] Failed to eval “round(value, 2)” using “”
2018-12-11 08:51:42 ERROR (SyncWorker_8) [zigate] Traceback (most recent call last):
‘self’: self})
File “”, line 1, in
2018-12-11 08:51:42 ERROR (SyncWorker_8) [zigate] Failed to eval “cube_decode(value)” using “0”
‘self’: self})
File “”, line 1, in
File “/config/deps/lib/python3.6/site-packages/zigate/clusters.py”, line 257, in cube_decode
elif value & 0x0080 != 0: # flip180
TypeError: unsupported operand type(s) for &: ‘str’ and ‘int’
‘self’: self})
File “”, line 1, in
I think your zigate.json is incorrect, could you post it here ?
yes sure,
https://github.com/biau/HomeAssistantConfig/blob/master/zigate.json
sorry about this, and in fact everything runs fine in hass so no emergency here to be honest.
I think the problem is here : https://github.com/biau/HomeAssistantConfig/blob/master/zigate.json#L1072
You should set data: 0.0
looks better but I’ve still one error remaining even after re associate the cube:
2018-12-17 14:22:06 DEBUG (SyncWorker_18) [zigate] Try loading persistent file
2018-12-17 14:22:06 ERROR (SyncWorker_18) [zigate] Failed to eval “cube_decode(value)” using “0”
2018-12-17 14:22:06 ERROR (SyncWorker_18) [zigate] Traceback (most recent call last):
‘self’: self})
File “”, line 1, in
Same problem here :
https://github.com/biau/HomeAssistantConfig/blob/master/zigate.json#L1148
replace "data": "0" by "data": 0.0
Were’s the donate link ?? :wink:
One last question: are you on 0.84 ?
Yes, I’m using 0.84.3, since few minutes :grin:
(And now there’s a donate button, feel free to buy me a beer :wink: )
Excellent ! I’ll upgrade tonight thanks.
